Fenics on Jupiter notebook
I am trying to use fenics project on Jupiter notebook an am following the instruction in ’ How to add your Conda environment to your jupyter notebook in just 4 steps’ by Noopur R K. Everything goes fine until I activate the fenics environment in my terminal and run conda install -c anaconda ipykernel. I get the following error:
(fenicsproject) elizabethhawkins@Elizabeths-MacBook-Air ~ % conda install -c anaconda ipykernel
Collecting package metadata (current_repodata.json): done
Solving environment: failed with initial frozen solve. Retrying with flexible solve.
Solving environment: failed with repodata from current_repodata.json, will retry with next repodata source.
Collecting package metadata (repodata.json): done
Solving environment: |
Found conflicts! Looking for incompatible packages.
This can take several minutes.  Press CTRL-C to abort.
failed
UnsatisfiableError: The following specifications were found
to be incompatible with the existing python installation in your environment:
Specifications:
  - ipykernel -> python[version='>=2.7,<2.8.0a0|>=3.10,<3.11.0a0|>=3.7,<3.8.0a0|>=3.9,<3.10.0a0|>=3.8,<3.9.0a0|>=3.6,<3.7.0a0|>=3.5,<3.6.0a0']
Your python: python=3.11
If python is on the left-most side of the chain, that's the version you've asked for.
When python appears to the right, that indicates that the thing on the left is somehow
not available for the python version you are constrained to. Note that conda will not
change your python version to a different minor version unless you explicitly specify
that.
As you can see here, you are using Python 3.11 in your conda environment, which ipykernel does not support
What you should do is to make sure that you use another Python version in your enviroment,
and install all packages after having updated Python.
