Installed but looking for libsuperlu_dist.so.6
It has been a while since I have been on this site as fenics has been working great for me. I installed fenics on a new cluster recently with no problem. But I needed to write detailed instructions on how to do this and when I tried to reproduce the same result I now get an error. I have the newest versions of anaconda and conda installed currently. Below are what I did to install fenics:
$ conda create -n fenicsproject -c conda-forge Fenics
(base) [tpm92@tds-sbc2-dl local_installs]$ conda create -n fenicsproject -c conda-forge Fenics
Collecting package metadata (current_repodata.json): done
Solving environment: failed with repodata from current_repodata.json, will retry with next repodata source.
Collecting package metadata (repodata.json): done
Solving environment: done
Preparing transaction: done
Verifying transaction: done
Executing transaction: done
# To activate this environment, use
#     $ conda activate fenicsproject
# To deactivate an active environment, use
#     $ conda deactivate
(base) $ conda activate fenicsproject
(fenicsproject) $
but when I try to run a script with
or
I get the following error:
$ python test.py
  File "/data/work/tpm92/Layers_10_11/test_timing/submit_scripts/test.py", line 2, in <module>
  File "/home/tpm92/work/data/local_installs/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/fenics/__init__.py", line 7, in <module>
  File "/home/tpm92/work/data/local_installs/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/dolfin/__init__.py", line 34, in <module>
    from .cpp import __version__
ImportError: libsuperlu_dist.so.6: cannot open shared object file: No such file or directory
It appears fenics intit is looking for libsuperlu_dist.so.6 when libsuperlu_dist.so.7 has been installed in local_installs/anaconda3/envs/fenicsproject/lib/libsuperlu_dist.so.7. Can anyone suggest a simple fix to this? Any help would be greatly appreciated!
All the best,
Terrence
I have encounter the same issue
easy fix: Activate fenics enviroment and downgrade to superlu6 with conda
conda install -c conda-forge superlu_dist=6.2.0
runs fine now!
I have the same issue
