Fenics sample code for channel flow blows up if run with different parameters
this Fenics sample code for the Navier-Stokes equations with boundary conditions on the pressure runs fine with the default parameters set on the webpage, i.e., L=h=1, \mu = 1, where L and h are the width and the height of the rectangle, and \mu the viscosity.
However, if I let the exact same code run with the same parameters as this other Navier Stokes sampe program, i.e., L= 2.2, h=0.41, \mu = 0.001, it blows up (the velocity has gigantic values).
Please see this minimal working example:
#generate_mesh.py
import numpy
import pygmsh
import argparse
parser = argparse.ArgumentParser()
parser.add_argument("resolution")
args = parser.parse_args()
#mesh resolution
resolution = (float)(args.resolution)
# Channel parameters
L = 2.2
h = 0.41
# Initialize empty geometry using the build in kernel in GMSH
geometry = pygmsh.geo.Geometry()
model = geometry.__enter__()
#add the points that define the boundary of the mesh
points = [model.add_point((0, 0, 0), mesh_size=resolution),
          model.add_point((L, 0, 0), mesh_size=resolution),
          model.add_point((L, h, 0), mesh_size=resolution),
          model.add_point((0, h, 0), mesh_size=resolution)
channel_lines = [model.add_line(points[0], points[1]),
                   model.add_line(points[1], points[2]),
                   model.add_line(points[2], points[3]),
                   model.add_line(points[3], points[0])]
channel_loop = model.add_curve_loop(channel_lines)
plane_surface = model.add_plane_surface(channel_loop, holes=[])
model.synchronize()
model.add_physical([plane_surface], "Volume")
model.add_physical([channel_lines[3]], "Inflow")
model.add_physical([channel_lines[1]], "Outflow")
geometry.generate_mesh(64)
gmsh.write("membrane_mesh.msh")
gmsh.clear()
geometry.__exit__()
mesh_from_file = meshio.read("membrane_mesh.msh")
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={
                           "name_to_read": [cell_data]})
    return out_mesh
line_mesh = create_mesh(mesh_from_file, "line", prune_z=True)
meshio.write("line_mesh.xdmf", line_mesh)
triangle_mesh = create_mesh(mesh_from_file, "triangle", prune_z=True)
meshio.write("triangle_mesh.xdmf", triangle_mesh)
#ft07_navier_stokes_channel.py
FEniCS tutorial demo program: Incompressible Navier-Stokes equations
for channel flow (Poisseuille) on the unit square using the
Incremental Pressure Correction Scheme (IPCS).
  u' + u . nabla(u)) - div(sigma(u, p)) = f
                                 div(u) = 0
import argparse
parser.add_argument("input_directory")
parser.add_argument("output_directory")
parser.add_argument("T")
parser.add_argument("N")
T = (float)(args.T)
num_steps = (int)(args.N)
mu = 0.001             # kinematic viscosity
rho = 1            # density
# Create XDMF files for visualization output
xdmffile_v = XDMFFile((args.output_directory) + "/v.xdmf")
xdmf_file_p = XDMFFile((args.output_directory) + "/p.xdmf")
# Create mesh and define function spaces
# mesh = UnitSquareMesh(16, 16)
#create mesh
mesh=Mesh()
with XDMFFile((args.input_directory) + "/triangle_mesh.xdmf") as infile:
    infile.read(mesh)
with XDMFFile((args.input_directory) + "/line_mesh.xdmf") as infile:
Q = FunctionSpace(mesh, 'P', 1)
# Define boundaries
inflow  = 'near(x[0], 0)'
outflow = 'near(x[0], 2.2)'
walls   = 'near(x[1], 0) || near(x[1], 0.41)'
# Define boundary conditions
bcu_noslip  = DirichletBC(V, Constant((0, 0)), walls)
bcp_inflow  = DirichletBC(Q, Constant(8), inflow)
bcp_outflow = DirichletBC(Q, Constant(0), outflow)
bcu = [bcu_noslip]
bcp = [bcp_inflow, bcp_outflow]
p = TrialFunction(Q)
q = TestFunction(Q)
# Define functions for solutions at previous and current time steps
u_n = Function(V)
u_  = Function(V)
p_n = Function(Q)
p_  = Function(Q)
U   = 0.5*(u_n + u)
n   = FacetNormal(mesh)
f   = Constant((0, 0))
k   = Constant(dt)
mu  = Constant(mu)
rho = Constant(rho)
# Define strain-rate tensor
    return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
    return 2*mu*epsilon(u) - p*Identity(len(u))
# Define variational problem for step 1
F1 = rho*dot((u - u_n) / k, v)*dx + \
     rho*dot(dot(u_n, nabla_grad(u_n)), v)*dx \
   + inner(sigma(U, p_n), epsilon(v))*dx \
   + dot(p_n*n, v)*ds - dot(mu*nabla_grad(U)*n, v)*ds \
   - dot(f, v)*dx
a1 = lhs(F1)
L1 = rhs(F1)
a2 = dot(nabla_grad(p), nabla_grad(q))*dx
L2 = dot(nabla_grad(p_n), nabla_grad(q))*dx - (1/k)*div(u_)*q*dx
a3 = dot(u, v)*dx
L3 = dot(u_, v)*dx - k*dot(nabla_grad(p_ - p_n), v)*dx
# Assemble matrices
A1 = assemble(a1)
A2 = assemble(a2)
A3 = assemble(a3)
# Apply boundary conditions to matrices
[bc.apply(A1) for bc in bcu]
[bc.apply(A2) for bc in bcp]
# Time-stepping
t = 0
for n in range(num_steps):
    # Write the solution to file
    xdmffile_v.write(u_n, t)
    xdmf_file_p.write(p_n, t)
    # Update current time
    b1 = assemble(L1)
    [bc.apply(b1) for bc in bcu]
    solve(A1, u_.vector(), b1)
    b2 = assemble(L2)
    [bc.apply(b2) for bc in bcp]
    solve(A2, p_.vector(), b2)
    b3 = assemble(L3)
    solve(A3, u_.vector(), b3)
    # Update previous solution
    u_n.assign(u_)
    p_n.assign(p_)
    print("\t%.2f %%" % (100.0 * (t / T)), flush=True)
I run with $python3 generate_mesh.py 0.1 to generate the mesh, and run the simulation with $python3 ft07_navier_stokes_channel.py [path where the mesh files were stored by generate_mesh.py] [path where to store the solution] 2 2048. Here is the result for the magnitude of the velocity vector at some intermediate time (notice the scale in the color bar):
Why this blow up? I wonder whether this is related to this comment by @dokken in this post
Thank you :slight_smile:
I wouldnt spend much energy on that old splitting scheme. It uses a naive explicit handling of the connectivity and as mentioned earlier; its not natural to have pressure Dirichlet on a splitting scheme.
Why? Also, what would be a suitable scheme to solve the problem above with its Dirichlert BCs on the pressure?
I wouldnt use a splitting scheme if you want strong pressure BCs.
Ive covered this in several other posts, and will not repeat all of the argumentation once again.
See for instance the references within: Splitting schemes β€” Oasisx
