Ffcx compilation error
My current goal is to iterate through all the units which involves using assemble_scalar to perform boundary integration . I have encountered some problems. Here is MWE
from dolfinx import *
# from dolfinx import default_scalar_type, default_real_type
from dolfinx.fem import (Constant,  Function, functionspace, assemble_scalar,
                         dirichletbc, form, locate_dofs_topological)
# from dolfinx.fem.petsc import LinearProblem
# from dolfinx.io import XDMFFile
from dolfinx.mesh import create_unit_square, locate_entities, meshtags
# from dolfinx.plot import vtk_mesh
# import basix
# from mpi4py import MPI
from joblib import Parallel, delayed
from ufl import (FacetNormal, Measure, SpatialCoordinate, TestFunction, TrialFunction,
                 div, dot, dx, dS, grad, inner, lhs, rhs,jump, avg)
from pathlib import Path
import time
from time import sleep
N = 100
L = 100
# Generating mesh
msh = mesh.create_rectangle(comm = MPI.COMM_WORLD, points = ((0, 0), (L, L)), n = (N, N),
                            cell_type = mesh.CellType.triangle)
DG1 = fem.FunctionSpace(msh, ("Discontinuous Lagrange", 0))
RT  =  fem.FunctionSpace(msh, ("RT", 1))
u_f = fem.Function(RT)
def f(x):
    return (np.sin(np.pi*x[0]), np.sin(np.pi*x[1]))
u_f.interpolate(f)
u = fem.Function(DG1)
for i in range(0, u.vector.size):
    u.vector[i] = i
num_cells = msh.topology.index_map(msh.topology.dim).size_local+ msh.topology.index_map(msh.topology.dim).num_ghosts
num_edges = msh.topology.index_map(1).size_local + msh.topology.index_map(1).num_ghosts
cell_list = np.arange(num_cells, dtype=np.int32)
edge_list = np.arange(num_edges, dtype=np.int32)
tdim = msh.topology.dim # Topology dimension
fdim = tdim - 1            # Facet dimension
e4c_list = msh.topology.connectivity(tdim, fdim)
boundary_facets = dolfinx.mesh.exterior_facet_indices(msh.topology)
edge_list1 = np.delete(edge_list, boundary_facets)
sort_index = np.argsort(edge_list1)
cell_tag = meshtags(msh, msh.topology.dim, cell_list, cell_list)
edge_tag = meshtags(msh, 1, edge_list1[sort_index], edge_list1[sort_index])
de = Measure("dS", domain=msh, subdomain_data = edge_tag)
dx = Measure("dx", domain=msh, subdomain_data = cell_tag)
n = FacetNormal(msh)
# for i in range(num_cells):
h = ufl.CellDiameter(msh)
h_avg = avg(h)
lmbda = ufl.conditional(ufl.gt(dot(u_f, n), 0), 1, 0)
epsilons = 1e-16
c_uw = lmbda("+") * u("+") + lmbda("-") * u("-")
h_avg = avg(h)
# start_time = time.time()
cache_dir = f"{str(Path.cwd())}/.11cache_test"
cffi_options = ["-Ofast", "-march=native"]
jit_options = {"cffi_extra_compile_args": cffi_options, "cache_dir": cache_dir,
                    "cffi_libraries": ["m"]}
t_DG0 = []
    ap = 0
    an = 0
    cp = 0
    cn = 0
    # t_DG0 = []
    for j in e4c_list.links(i):
        if j in boundary_facets:
            continue
        a = assemble_scalar(form(inner(c_uw, dot(u_f, n)("+")) * de(j), jit_options=jit_options))
        c1 = assemble_scalar(form(1/h_avg * jump(u) * de(j), jit_options=jit_options))
        if a > 0:
            ap += a
            an += a
        c1 += 1
        if  c1 > 0:
            cp += c1
            cn += c1
    t_DG0.append(min(ap, cp, 100))
Below is the problem I encountered
  File "/export/home/chenyux/Phi_Stable/111.py", line 85, in <module>
  File "/export/home/chenyux/.conda/envs/fenicsx-env/lib/python3.11/site-packages/dolfinx/fem/forms.py", line 188, in form
    return _create_form(form)
  File "/export/home/chenyux/.conda/envs/fenicsx-env/lib/python3.11/site-packages/dolfinx/fem/forms.py", line 183, in _create_form
    return _form(form)
  File "/export/home/chenyux/.conda/envs/fenicsx-env/lib/python3.11/site-packages/dolfinx/fem/forms.py", line 141, in _form
  File "/export/home/chenyux/.conda/envs/fenicsx-env/lib/python3.11/site-packages/dolfinx/jit.py", line 56, in mpi_jit
  File "/export/home/chenyux/.conda/envs/fenicsx-env/lib/python3.11/site-packages/dolfinx/jit.py", line 204, in ffcx_jit
  File "/export/home/chenyux/.conda/envs/fenicsx-env/lib/python3.11/site-packages/ffcx/codegeneration/jit.py", line 201, in compile_forms
    obj, module = _load_objects(cache_dir, module_name, form_names)
  File "/export/home/chenyux/.conda/envs/fenicsx-env/lib/python3.11/site-packages/ffcx/codegeneration/jit.py", line 319, in _load_objects
    compiled_module = importlib.util.module_from_spec(spec)
  File "<frozen importlib._bootstrap>", line 573, in module_from_spec
  File "<frozen importlib._bootstrap_external>", line 1233, in create_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
ImportError: /export/home/chenyux/Phi_Stable/.11cache_test/libffcx_forms_68d2a57526bb8713ce83b3d0b0538ee916ae33cc.cpython-311-x86_64-linux-gnu.so: failed to map segment from shared object
double free or corruption (!prev)
When I used MPI parallelism, I encountered the following error. Following the prompts, I deleted the failed file and increased the compilation time, but the error persisted.
  File "/export/home/chenyux/.conda/envs/fenicsx-env/lib/python3.11/site-packages/ffcx/codegeneration/jit.py", line 68, in get_cached_module
    open(c_filename, "x")
FileExistsError: [Errno 17] File exists: '/export/home/chenyux/Phi_Stable/test1/.cachetest_1/libffcx_forms_e4f18e2aaed336cdfddd78aa7d4f1674fe3d757d.c'
  File "/export/home/chenyux/Phi_Stable/test1/2test1.py", line 532, in <module>
    dt.value = get_time_step_adaptive(msh, DG0, u_f_l, c_n, phi_l, phi_n, mu_f, gamma2, delta1, delta2, beta, 10000)
  File "/export/home/chenyux/Phi_Stable/test1/Time_step_mpi.py", line 89, in get_time_step_adaptive
    c1 = assemble_scalar(form(gamma/h_avg * jump(mu_np) * de(j), jit_options=jit_options))
    return _form(form)
  File "/export/home/chenyux/.conda/envs/fenicsx-env/lib/python3.11/site-packages/dolfinx/jit.py", line 85, in mpi_jit
    output = local_jit(*args, **kwargs)
  File "/export/home/chenyux/.conda/envs/fenicsx-env/lib/python3.11/site-packages/ffcx/codegeneration/jit.py", line 176, in compile_forms
    obj, mod = get_cached_module(module_name, form_names, cache_dir, timeout)
  File "/export/home/chenyux/.conda/envs/fenicsx-env/lib/python3.11/site-packages/ffcx/codegeneration/jit.py", line 90, in get_cached_module
    raise TimeoutError(f"""JIT compilation timed out, probably due to a failed previous compile.
TimeoutError: JIT compilation timed out, probably due to a failed previous compile.
        Try cleaning cache (e.g. remove /export/home/chenyux/Phi_Stable/test1/.cachetest_1/libffcx_forms_e4f18e2aaed336cdfddd78aa7d4f1674fe3d757d.c) or increase timeout option.
Please note that
  1. You are using an old version of DOLFINx (please specify what version)
  2. Your implementation is very inefficient. You could for instance use:
    compile_form and create_form from v0.9.0, which would then only compile your form once: FEniCS release notes | FEniCS Project
i.e. a minimal code is shown below for parts of your problem:
from dolfinx import mesh, fem
from dolfinx.mesh import meshtags
N = 100
L = 100
# Generating mesh
    comm=MPI.COMM_WORLD,
    points=((0, 0), (L, L)),
    n=(N, N),
    cell_type=mesh.CellType.triangle,
# Define mesh independent UFL formulation
import basix.ufl
c_el = ufl.Mesh(msh.ufl_domain().ufl_coordinate_element())
el0 = basix.ufl.element("Discontinuous Lagrange", msh.basix_cell(), 0)
el1 = basix.ufl.element("RT", msh.basix_cell(), 1)
DG0_symbolic = ufl.FunctionSpace(c_el, el0)
RT1_symbolic = ufl.FunctionSpace(c_el, el1)
u_f_symb = ufl.Coefficient(RT1_symbolic)
u_symb = ufl.Coefficient(DG0_symbolic)
n = ufl.FacetNormal(c_el)
h = ufl.CellDiameter(c_el)
h_avg = ufl.avg(h)
lmbda = ufl.conditional(ufl.gt(ufl.dot(u_f_symb, n), 0), 1, 0)
epsilons = 1e-16
c_uw = lmbda("+") * u_symb("+") + lmbda("-") * u_symb("-")
integration_id = 397
de = ufl.Measure("dS", subdomain_id=integration_id)
form_0 = ufl.inner(c_uw, ufl.dot(u_f_symb, n)("+")) * de
form_1 = 1 / h_avg * ufl.jump(u_symb) * de
# Compile forms once
jit_options = {
    "cffi_libraries": ["m"],
compiled_form0 = fem.compile_form(MPI.COMM_WORLD, form_0, jit_options=jit_options)
compiled_form1 = fem.compile_form(MPI.COMM_WORLD, form_1, jit_options=jit_options)
DG1 = fem.functionspace(msh, DG0_symbolic.ufl_element())
RT = fem.functionspace(msh, RT1_symbolic.ufl_element())
def f(x):
    return (np.sin(np.pi * x[0]), np.sin(np.pi * x[1]))
u_f.interpolate(f)
for i in range(0, u.x.array.size):
    u.x.array[i] = i
num_cells = (
msh.topology.create_connectivity(msh.topology.dim - 1, msh.topology.dim)
boundary_facets = mesh.exterior_facet_indices(msh.topology)
t_DG0 = []
            continue
        facet_entities = fem.compute_integration_domains(
            fem.IntegralType.interior_facet,
            msh.topology,
            np.array([j], dtype=np.int32),
        subdomains = {
            fem.IntegralType.interior_facet: [(integration_id, facet_entities)]
        form0 = fem.create_form(
            compiled_form0, [], msh, subdomains, {u_symb: u, u_f_symb: u_f}, {}
        print(i, j, msh.comm.allreduce(fem.assemble_scalar(form0), op=MPI.SUM))
Thank you very much! I have updated to the latest version. Now the compilation speed is much faster. It is effective.
