FFCX compiler files size limit with petsc.assemble_matrix
Dear Fenics community: 'm building a fenicsx / dolfinx code for a physical equation built with sympy, which is very intrincate. The physics of the equation are fine but I need to emulate spectral methods and thus I need to use a high polynomial degree (I then solve an eigenvalue problem via SLEPc). My problem is that for a degree above a high enough number (let’s call it p), my ffcx compiler crashes when doing “dolfinx.fem.petsc.assemble_matrix”, because some cache files get over size limit (2 GB). Please forgive my lack of expertise - I was never very good with computers :sweat_smile:
I need to get around that somehow, because for low polynomial degrees it works wonderfully, but I need to get past p to increase my accuracy. Something like 1.5*p would work.
Here’s a list of the things I tried and did not work at all (not even reducing my cache files by 1 kB):
  • Siplifying the symbolic equation with sp.cancel term by term
  • Assembling “smaller” matrices calling dolfinx.petsc.assemble_matrix on each equation term and then adding with axpy.
  • Toggling jit compiler options
  • Writing the weak forms with ufl expressions insteand of fem.Function objects
I would be extremely grateful if anyone could suggest workarounds. Right now, I assemble the symbolic equation separately and then import it. Here’s my code from that point (I paste the ufl-expressions version which is much cleaner)
with open(f'eq_A_m_{m_mode_num}_simp.pk', 'rb') as f:  # Python 3: open(..., 'wb')
    EQN_kerr_A = pickle.load(f)
with open(f'eq_B_m_{m_mode_num}_simp.pk', 'rb') as f:  # Python 3: open(..., 'wb')
    EQN_kerr_B = pickle.load(f)
#Sort the equation terms to make SLEPc understand my problem
M_eq, C_eq, K_eq = extract_qep_coeffs(EQN_kerr_A)
M_eq_b, C_eq_b, K_eq_b = extract_qep_coeffs(EQN_kerr_B)
ufl_mapping = {
    'sigma': x[0],
    'x_coord': x[1],
    'M': M_mass_num,
    'lambda_': lambda_param,
    'psi': psi_gr,
    'Q': Q_ch,
    'm': m_mode_num,
    'psi_b': psi_em,
    'a': a_rot_num,
# Translate the SymPy expressions directly into UFL operator expressions
M_op = sympy_to_ufl(M_eq, ufl_mapping)
C_op = sympy_to_ufl(C_eq, ufl_mapping)
K_op = sympy_to_ufl(K_eq, ufl_mapping)
M_op_b = sympy_to_ufl(M_eq_b, ufl_mapping)
C_op_b = sympy_to_ufl(C_eq_b, ufl_mapping)
K_op_b = sympy_to_ufl(K_eq_b, ufl_mapping)
# Build the weak forms by taking the inner product with the test functions
M_form_gr = ufl.inner(M_op, v_test_gr)*dx_meas
M_form_em = ufl.inner(M_op_b, v_test_em)*dx_meas
C_form_gr = ufl.inner(C_op, v_test_gr)*dx_meas
C_form_em = ufl.inner(C_op_b, v_test_em)*dx_meas
K_form_gr = ufl.inner(K_op, v_test_gr)*dx_meas
K_form_em = ufl.inner(K_op_b, v_test_em)*dx_meas
M_mat = assemble_matrix(fem.form(M_form_gr+M_form_em))
M_mat.assemble()
C_mat = assemble_matrix(fem.form(C_form_gr+C_form_em))
C_mat.assemble()
K_mat = assemble_matrix(fem.form(K_form_gr+K_form_em))
K_mat.assemble()
A = [ ]
A.append(K_mat)
A.append(C_mat)
A.append(M_mat)
return A
We would need a reproducible example to be able to do some proper guidance here.
One thing you can try is to fix the quadrature degree to something specific (say 15), as shown in:
Thank you very much for your reply!
I here paste a reproducible example:
You will need the files containing the physical equations, I uploaded them to Google Drive and can be downloaded here (corrected version):
https://drive.google.com/drive/folders/1IhCmBS0manIEjtggFl-zs-NgmShIMoPZ?usp=sharing
I also attempted to reduce the quadrature degree, but I lost too much precission in exchange. Thanks a lot anyways for suggesting it.
import os
#AUXILIARY FUNCTIONS
######## SLEPC EIGENSOLVER #############
def eig_solver(A,ME,target,pep_params):
from slepc4py import SLEPc
from dolfinx import fem
nev, tol, max_it = pep_params
comm = MPI.COMM_WORLD
V_gr, dof_map_gr = ME.sub(0).collapse()
V_em, dof_map_em = ME.sub(1).collapse()
pep = SLEPc.PEP().create(comm)
pep.setOperators(A)
pep.setProblemType(SLEPc.PEP.ProblemType.GENERAL)
pep.setDimensions(nev=nev, ncv=max(15, 2\*nev + 10), mpd=max(15, 2\*nev + 10))
pep.setType(SLEPc.PEP.Type.TOAR)
st = pep.getST()
st.setType(SLEPc.ST.Type.SINVERT)
ksp = st.getKSP()
ksp.setType(PETSc.KSP.Type.PREONLY)
pep.setRefine(ref = SLEPc.PEP.Refine.SIMPLE, npart = 1, tol = 0.1\*tol, its= 3, scheme= SLEPc.PEP.RefineScheme.SCHUR)
pep.setTarget(target)
pep.setWhichEigenpairs(SLEPc.PEP.Which.TARGET_MAGNITUDE)
pep.setTolerances(tol, max_it)
*# Solver*
pep.solve()
nconv = pep.getConverged()
all_eigvals = \[\]
efuns = fem.Function(ME)
efuns_list_gr = \[\]
efuns_list_em = \[\]
error_list = \[\]
for i in range(nconv):
    eigval = pep.getEigenpair(i, efuns.x.petsc_vec)
    error = pep.computeError(i)
    error_list.append(error)
    efun_vals_gr = efuns.x.array\[dof_map_gr\]
    efun_vals_em = efuns.x.array\[dof_map_em\]
    efuns_list_gr.append(efun_vals_gr)
    efuns_list_em.append(efun_vals_em)
    all_eigvals.append(eigval)
return all_eigvals, efuns_list_gr, efuns_list_em, error_list
################ SYMPY SORTING ################
def extract_qep_coeffs(eqn):
import sympy as sp
omega = sp.symbols('omega', complex=True)
expanded_eqn = eqn
K_matrix_term = expanded_eqn.subs(omega, 0)
C_matrix_term = sp.diff(expanded_eqn, omega).subs(omega, 0)
M_matrix_term = sp.diff(expanded_eqn, omega, 2).subs(omega, 0) / 2
return (M_matrix_term), (C_matrix_term), (K_matrix_term)
######### SYMPY CONVERSION TO UFL #########
def sympy_to_ufl(expr, mapping):
import sympy as sp
Recursively walks a SymPy expression tree and builds a UFL expression.
Args:
    expr: The SymPy expression node.
    mapping: A dictionary linking SymPy variable/function names to UFL objects or numbers.
*# 1. Base Cases: Numbers and Constants*
if expr == sp.I:
    return 1**j**
if isinstance(expr, (int, float)):
    return expr
if isinstance(expr, sp.Number):
    return float(expr)
*# 2. Base Cases: Symbols and Trial Functions*
if isinstance(expr, sp.Symbol):
    if expr.name in mapping:
        return mapping\[expr.name\]
    raise ValueError(**f**"Symbol '{expr.name}' not found in mapping dictionary.")
if isinstance(expr, sp.core.function.AppliedUndef):
    func_name = expr.func.\__name_\_
    if func_name in mapping:
        return mapping\[func_name\]
    raise ValueError(**f**"Function '{func_name}' not found in mapping dictionary.")
*# 3. Recursive Cases: Arithmetic Operations*
if isinstance(expr, sp.Add):
    return sum(sympy_to_ufl(arg, mapping) for arg in expr.args)
if isinstance(expr, sp.Mul):
    result = 1
    for arg in expr.args:
        result = result \* sympy_to_ufl(arg, mapping)
    return result
if isinstance(expr, sp.Pow):
    base = sympy_to_ufl(expr.args\[0\], mapping)
    exponent = sympy_to_ufl(expr.args\[1\], mapping)
    return base \*\* exponent
if isinstance(expr, sp.exp):
    return ufl.exp(argum)
if isinstance(expr, sp.sin):
    argum = sympy_to_ufl(expr.args\[0\], mapping)
    return ufl.sin(argum)
if isinstance(expr, sp.log):
    return ufl.ln(argum)
if isinstance(expr, sp.cot):
    return ufl.cos(argum)/ufl.sin(argum)
if isinstance(expr, sp.cos):
if isinstance(expr, sp.tan):
    return ufl.tan(argum)
    return ufl.cot(argum)
if isinstance(expr, sp.Abs):
    return ufl.algebra.Abs(argum)
*# 4. Calculus: Derivatives*
if isinstance(expr, sp.Derivative):
    ufl_func = sympy_to_ufl(expr.args\[0\], mapping)
    for var, count in expr.variable_count:
        if var.name == 'sigma':
            dim = 0
        elif var.name == 'x_coord':
            dim = 1
            raise ValueError(**f**"Unknown derivative variable: {var.name}")
        *# Apply the UFL derivative .dx(dim) the correct number of times*
        for \_ in range(count):
            ufl_func = ufl_func.dx(dim)
    return ufl_func
*# 5. Math Functions*
if isinstance(expr, sp.conjugate):
    return ufl.conj(sympy_to_ufl(expr.args\[0\], mapping))
*# Catch-all for unsupported operations*
raise NotImplementedError(**f**"SymPy node type {type(expr)} is not implemented in the AST walker.")
############ PROBLEM ASSEMBLER ########################
def assembler(phys_params, poly_degree, eps, debug_mode):
import dill as pickle
from dolfinx.fem.petsc import assemble_matrix
from dolfinx import mesh
import basix
from basix import CellType, ElementFamily, LagrangeVariant
*#Physical parameters*
M_mass_num, alpha, q_ch = phys_params\[:\]
Q_ch = q_ch\*M_mass_num
a_rot_num = alpha\*M_mass_num
r_p = M_mass_num + np.sqrt(M_mass_num\*\*2 - a_rot_num\*\*2 - Q_ch\*\*2)
lambda_param = r_p
*#Mesh creation*
N_x = 1
N_y = 1
*# general cell type*
cell_type = CellType.quadrilateral
*# spectral element*
ufl_nodal_element = basix.ufl.element(ElementFamily.P,
                                    cell_type,
                                    poly_degree,
                                    LagrangeVariant.gll_warped)
*# mesh: we "chop-off" by a small eps to avoid coordinate singularities*
domain = mesh.create_rectangle(MPI.COMM_WORLD,
                            \[\[eps, eps\], \[1-eps, 1-eps\]\],
                            \[N_x, N_y\],
                            mesh.CellType.quadrilateral)
tdim = domain.topology.dim
fdim = tdim - 1
*#Function space: needs to be mixed since we're solving a coupled PDE system*
ME_element = basix.ufl.mixed_element(\[ufl_nodal_element, ufl_nodal_element\])
ME = fem.functionspace(domain, ME_element)
*#Trial and test functions*
v_test_gr, v_test_em = ufl.TestFunctions(ME)
psi_gr, psi_em = ufl.TrialFunctions(ME)
*# Spatial coordinate*
*# create the quadrature rule and measure*
metadata = {
    "quadrature_rule": "GLL",
    "quadrature_degree": 2 \* poly_degree - 1
dx_meas = ufl.dx(domain=domain, metadata=metadata)
*# Getting back the objects:*
with open(**f**'eq_A.pk', 'rb') as f:  *# Python 3: open(..., 'wb')*
with open(**f**'eq_B.pk', 'rb') as f:  *# Python 3: open(..., 'wb')*
*# Extract into mass, stiffness...*
*#Map for the UFL converter*
ufl_mapping = {
    'sigma': x\[0\],
    'x_coord': x\[1\],
    'M': M_mass_num,
    'lambda\_': lambda_param,
    'psi': psi_gr,
    'Q': Q_ch,
    'm': 0,
    'psi_b': psi_em,
    'a': a_rot_num,
*# Translate the SymPy expressions directly into UFL operator expressions*
*# Build the weak forms by taking the inner product with the test functions*
M_form_gr = ufl.inner(M_op, v_test_gr)\*dx_meas
M_form_em = ufl.inner(M_op_b, v_test_em)\*dx_meas
C_form_gr = ufl.inner(C_op, v_test_gr)\*dx_meas
C_form_em = ufl.inner(C_op_b, v_test_em)\*dx_meas
K_form_gr = ufl.inner(K_op, v_test_gr)\*dx_meas
K_form_em = ufl.inner(K_op_b, v_test_em)\*dx_meas
jit_options = {
"cffi_extra_compile_args": \["-O1", "-fno-inline"\]}
M_1 = assemble_matrix(fem.form(M_form_gr+M_form_em, jit_options = jit_options))
M_1.assemble()
M_mat = M_1
C_1 = assemble_matrix(fem.form(C_form_gr+C_form_em, jit_options = jit_options))
C_1.assemble()
C_mat = C_1
K_1 = assemble_matrix(fem.form(K_form_gr+K_form_em, jit_options = jit_options))
K_1.assemble()
K_mat = K_1
A = \[ \]
A.append(K_mat)
A.append(C_mat)
A.append(M_mat)
return A, ME
############ INITIALIZE
phys_params = [0.5, 0, 0]
poly_degree = 18
eps = 2.5e-7
debug_mode = 0
A, ME = assembler(phys_params, poly_degree, eps, debug_mode = 0)
for i, mat in enumerate(A): # PEP matrices
viewer = PETSc.Viewer().createASCII("/dev/null")
arr = mat.convert("dense").getDenseArray()
print(**f**"A\_{i}: max={np.max(np.abs(arr))**:.2e**}, "
    **f**"has_nan={np.any(np.isnan(arr))}, "
    **f**"has_inf={np.any(np.isinf(arr))}")
#PARAMETERS FOR SLEPC
target = 0.85
nev = 12
tol = 1e-7
max_it = 2000
pep_params = [nev, tol, max_it]
all_eigvals, efuns_list_gr, efuns_list_em, error_list = eig_solver(A,ME,target,pep_params)
print(“\n— Sorted eigenvalues —”)
print(f"Found {len(all_eigvals)} physical eigenpairs after sorting.")
for i, eigval in enumerate(all_eigvals):
print(**f**"QNM {i}: {eigval.real**:.6e**} + {eigval.imag**:.6e**}i, error {error_list\[i\]}")
Please note that your code formatting is not correct.
Please use
```python
#add code here
Are you saying that using
and
gives you a loss of precision?
Edit
Right, you are trying to do a spectral method. At what polynomial degree does your problem currently fail?
I guess you could try using the tensor product element from basix (ffcx/demo/MassAction.py at 54893260dbf19a75fb15f3560e46a28c8cb73c58 · FEniCS/ffcx · GitHub)
i.e. if one considers:
"""Use tensor product elements to test high order assembly"""
import basix.ufl
P = 13
cell_type = basix.CellType.hexahedron
element = basix.ufl.wrap_element(
    basix.create_tp_element(basix.ElementFamily.P, cell_type, P, basix.LagrangeVariant.gll_warped)
c_el = basix.ufl.blocked_element(
        basix.create_tp_element(basix.ElementFamily.P, cell_type, 1, basix.LagrangeVariant.gll_warped)
    ), (3,)
mesh = ufl.Mesh(c_el)
V = ufl.FunctionSpace(mesh, element)
u = ufl.TrialFunction(V)
a = ufl.inner(u, v) * ufl.dx
w = ufl.Coefficient(V)
L = ufl.action(a, w)
which can be compiled with:
python3 -m ffcx mwe.py --sum_factorization
you get the following (seems like the quadrature weights does not use tensor products).
void tabulate_tensor_integral_54a463af79997cceebe0a7740ccc42adfa5a9ff6_hexahedron(double* restrict A,
                                    const double* restrict w,
                                    const double* restrict c,
                                    const double* restrict coordinate_dofs,
                                    const int* restrict entity_local_index,
                                    const uint8_t* restrict quadrature_permutation,
                                    void* custom_data)
// Quadrature rules
static const double weights_843[4913] = {...,
  {0.002514143263164119, 0.5310179651539475, -0.006306936264939108, 0.008673660364852594, -0.01084094025003951, 0.01309572661657724, -0.01564139383462328, 0.01869763014686473, -0.02256350657595175, 0.0277055433285752, -0.03492972494947359, 0.04577976819603195, -0.06362108595724893, 0.09732164084031523, -0.1793847948263935, 0.5884823047483395}}}};
static const double FE_TF1[1][1][17][2] = {{{{-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0}}}};
static const double FE_TF2[1][1][17][2] = {{{{0.9952877376572087, 0.004712262342791262},
  {0.9753377608843838, 0.0246622391156161},
  {0.940119576863493, 0.05988042313650699},
  {0.8907570019484007, 0.1092429980515993},
  {0.8288355796083454, 0.1711644203916546},
  {0.7563452685432385, 0.2436547314567615},
  {0.6756158817269382, 0.3243841182730618},
  {0.5892420907479239, 0.4107579092520761},
  {0.5, 0.5},
  {0.4107579092520761, 0.5892420907479239},
  {0.3243841182730618, 0.6756158817269382},
  {0.2436547314567615, 0.7563452685432385},
  {0.1711644203916547, 0.8288355796083453},
  {0.1092429980515995, 0.8907570019484006},
  {0.05988042313650704, 0.9401195768634929},
  {0.0246622391156161, 0.9753377608843838},
  {0.004712262342791262, 0.9952877376572087}}}};
for (int iq0 = 0; iq0 < 17; ++iq0)
  for (int iq1 = 0; iq1 < 17; ++iq1)
    for (int iq2 = 0; iq2 < 17; ++iq2)
      // Section: Jacobian
      // Inputs: FE_TF2, FE_TF1, coordinate_dofs
      // Outputs: J0_c5, J0_c3, J0_c1, J0_c4, J0_c8, J0_c2, J0_c0, J0_c7, J0_c6
      double J0_c0 = 0.0;
      double J0_c4 = 0.0;
      double J0_c8 = 0.0;
      double J0_c5 = 0.0;
      double J0_c7 = 0.0;
      double J0_c3 = 0.0;
      double J0_c6 = 0.0;
      double J0_c1 = 0.0;
      double J0_c2 = 0.0;
        for (int ic0 = 0; ic0 < 2; ++ic0)
          for (int ic1 = 0; ic1 < 2; ++ic1)
            for (int ic2 = 0; ic2 < 2; ++ic2)
              J0_c0 += coordinate_dofs[(4 * ic0 + 2 * ic1 + ic2) * 3] * (FE_TF1[0][0][iq0][ic0] * FE_TF2[0][0][iq1][ic1] * FE_TF2[0][0][iq2][ic2]);
              J0_c4 += coordinate_dofs[(4 * ic0 + 2 * ic1 + ic2) * 3 + 1] * (FE_TF2[0][0][iq0][ic0] * FE_TF1[0][0][iq1][ic1] * FE_TF2[0][0][iq2][ic2]);
              J0_c8 += coordinate_dofs[(4 * ic0 + 2 * ic1 + ic2) * 3 + 2] * (FE_TF2[0][0][iq0][ic0] * FE_TF2[0][0][iq1][ic1] * FE_TF1[0][0][iq2][ic2]);
              J0_c5 += coordinate_dofs[(4 * ic0 + 2 * ic1 + ic2) * 3 + 1] * (FE_TF2[0][0][iq0][ic0] * FE_TF2[0][0][iq1][ic1] * FE_TF1[0][0][iq2][ic2]);
              J0_c7 += coordinate_dofs[(4 * ic0 + 2 * ic1 + ic2) * 3 + 2] * (FE_TF2[0][0][iq0][ic0] * FE_TF1[0][0][iq1][ic1] * FE_TF2[0][0][iq2][ic2]);
              J0_c3 += coordinate_dofs[(4 * ic0 + 2 * ic1 + ic2) * 3 + 1] * (FE_TF1[0][0][iq0][ic0] * FE_TF2[0][0][iq1][ic1] * FE_TF2[0][0][iq2][ic2]);
              J0_c6 += coordinate_dofs[(4 * ic0 + 2 * ic1 + ic2) * 3 + 2] * (FE_TF1[0][0][iq0][ic0] * FE_TF2[0][0][iq1][ic1] * FE_TF2[0][0][iq2][ic2]);
              J0_c1 += coordinate_dofs[(4 * ic0 + 2 * ic1 + ic2) * 3] * (FE_TF2[0][0][iq0][ic0] * FE_TF1[0][0][iq1][ic1] * FE_TF2[0][0][iq2][ic2]);
              J0_c2 += coordinate_dofs[(4 * ic0 + 2 * ic1 + ic2) * 3] * (FE_TF2[0][0][iq0][ic0] * FE_TF2[0][0][iq1][ic1] * FE_TF1[0][0][iq2][ic2]);
      // Section: Intermediates
      // Inputs: J0_c5, J0_c3, J0_c1, J0_c4, J0_c8, J0_c2, J0_c0, J0_c7, J0_c6
      // Outputs: fw0
      double fw0 = 0;
        double sv_843_0 = J0_c4 * J0_c8;
        double sv_843_1 = J0_c5 * J0_c7;
        double sv_843_2 = -sv_843_1;
        double sv_843_3 = sv_843_0 + sv_843_2;
        double sv_843_4 = J0_c0 * sv_843_3;
        double sv_843_5 = J0_c3 * J0_c8;
        double sv_843_6 = J0_c5 * J0_c6;
        double sv_843_7 = -sv_843_6;
        double sv_843_8 = sv_843_5 + sv_843_7;
        double sv_843_9 = -J0_c1;
        double sv_843_10 = sv_843_8 * sv_843_9;
        double sv_843_11 = sv_843_4 + sv_843_10;
        double sv_843_12 = J0_c3 * J0_c7;
        double sv_843_13 = J0_c4 * J0_c6;
        double sv_843_14 = -sv_843_13;
        double sv_843_15 = sv_843_12 + sv_843_14;
        double sv_843_16 = J0_c2 * sv_843_15;
        double sv_843_17 = sv_843_11 + sv_843_16;
        double sv_843_18 = fabs(sv_843_17);
        fw0 = sv_843_18 * weights_843[289 * iq0 + 17 * iq1 + iq2];
      // Section: Tensor Computation
      // Inputs: FE_TF0, fw0
      // Outputs: A
        for (int j0 = 0; j0 < 16; ++j0)
          for (int j1 = 0; j1 < 16; ++j1)
            for (int j2 = 0; j2 < 16; ++j2)
              for (int i0 = 0; i0 < 16; ++i0)
                for (int i1 = 0; i1 < 16; ++i1)
                  for (int i2 = 0; i2 < 16; ++i2)
                    A[4096 * (256 * i0 + 16 * i1 + i2) + (256 * j0 + 16 * j1 + j2)] += fw0 * (FE_TF0[0][0][iq0][i0] * FE_TF0[0][0][iq1][i1] * FE_TF0[0][0][iq2][i2]) * (FE_TF0[0][0][iq0][j0] * FE_TF0[0][0][iq1][j1] * FE_TF0[0][0][iq2][j2]);
Here is a minimal example setting up a grid with tensor factors
import basix.ufl
P = 15
cell_type = basix.CellType.quadrilateral
    ), (2,)
eps = 2.5e-7
nodes = np.array([[eps, eps],[1-eps, eps],[eps, 1-eps],[1-eps, 1-eps]], dtype=np.float64)
connectivity = np.array([[0, 1, 2, 3]], dtype=np.int64)
mesh = dolfinx.mesh.create_mesh(MPI.COMM_WORLD, cells=connectivity, x=nodes, e=c_el)
V = dolfinx.fem.functionspace(mesh, element)
J = dolfinx.fem.assemble_matrix(dolfinx.fem.form(a, form_compiler_options={"sum_factorization": True}))
which then in turn gives the kernel
void tabulate_tensor_integral_b6ab92259bf3ae452d1f0a4bb20de89952479a6b_quadrilateral(double _Complex* restrict A,
                                    const double _Complex* restrict w,
                                    const double _Complex* restrict c,
                                    void* custom_data)
// Quadrature rules
static const double weights_06e[289] = {0.0001457851328577798, 0.0003348133780675438, 0.0005133696660845011, 0.0006754512570311628, 0.0008158284885834105, 0.0009299859235246961, 0.001014253485508105, 0.001065922421123082, 0.001083331928713395, 0.001065922421123082, 0.001014253485508105, 0.0009299859235246961, 0.0008158284885834105, 0.0006754512570311648, 0.0005133696660845011, 0.0003348133780675425, 0.0001457851328577798, 0.0003348133780675438, 0.0007689398495960406, 0.001179016191361836, 0.001551256377474323, 0.001873649849143541, 0.002135826352844399, 0.002329357109624001, 0.00244802113616285, 0.002488004198444595, 0.00244802113616285, 0.002329357109624001, 0.002135826352844399, 0.001873649849143541, 0.001551256377474328, 0.001179016191361836, 0.0007689398495960377, 0.0003348133780675438, 0.0005133696660845011, 0.001179016191361836, 0.001807786630155326, 0.002378542856058727, 0.002872869068033629, 0.003274864546640099, 0.003571605437217603, 0.0037535531002175, 0.003814859167051171, 0.0037535531002175, 0.003571605437217603, 0.003274864546640099, 0.002872869068033629, 0.002378542856058734, 0.001807786630155326, 0.001179016191361832, 0.0005133696660845011, 0.0006754512570311628, 0.001551256377474323, 0.002378542856058727, 0.003129498815699238, 0.003779894200001008, 0.004308808098277363, 0.004699236323384317, 0.004938628686833649, 0.005019290367182374, 0.004938628686833649, 0.004699236323384317, 0.004308808098277363, 0.003779894200001008, 0.003129498815699247, 0.002378542856058727, 0.001551256377474317, 0.0006754512570311628, 0.0008158284885834105, 0.001873649849143541, 0.002872869068033629, 0.003779894200001008, 0.004565459520715274, 0.005204296182472571, 0.005675866063309457, 0.005965010702568406, 0.006062436084608166, 0.005965010702568406, 0.005675866063309457, 0.005204296182472571, 0.004565459520715274, 0.003779894200001019, 0.002872869068033629, 0.001873649849143534, 0.0008158284885834105, 0.0009299859235246961, 0.002135826352844399, 0.003274864546640099, 0.004308808098277363, 0.005204296182472571, 0.005932524126433432, 0.006470079945179132, 0.006799684081509751, 0.006910742024642279, 0.006799684081509751, 0.006470079945179132, 0.005932524126433432, 0.005204296182472571, 0.004308808098277375, 0.003274864546640099, 0.00213582635284439, 0.0009299859235246961, 0.001014253485508105, 0.002329357109624001, 0.003571605437217603, 0.004699236323384317, 0.005675866063309457, 0.006470079945179132, 0.007056344585348723, 0.007415814697373854, 0.007536935784334625, 0.007415814697373854, 0.007056344585348723, 0.006470079945179132, 0.005675866063309457, 0.004699236323384331, 0.003571605437217603, 0.002329357109623993, 0.001014253485508105, 0.001065922421123082, 0.00244802113616285, 0.0037535531002175, 0.004938628686833649, 0.005965010702568406, 0.006799684081509751, 0.007415814697373854, 0.007793597231627863, 0.007920888568662418, 0.007793597231627863, 0.007415814697373854, 0.006799684081509751, 0.005965010702568406, 0.004938628686833664, 0.0037535531002175, 0.00244802113616284, 0.001065922421123082, 0.001083331928713395, 0.002488004198444595, 0.003814859167051171, 0.005019290367182374, 0.006062436084608166, 0.006910742024642279, 0.007536935784334625, 0.007920888568662418, 0.008050258930825227, 0.007920888568662418, 0.007536935784334625, 0.006910742024642279, 0.006062436084608166, 0.005019290367182388, 0.003814859167051171, 0.002488004198444586, 0.001083331928713395, 0.001065922421123082, 0.00244802113616285, 0.0037535531002175, 0.004938628686833649, 0.005965010702568406, 0.006799684081509751, 0.007415814697373854, 0.007793597231627863, 0.007920888568662418, 0.007793597231627863, 0.007415814697373854, 0.006799684081509751, 0.005965010702568406, 0.004938628686833664, 0.0037535531002175, 0.00244802113616284, 0.001065922421123082, 0.001014253485508105, 0.002329357109624001, 0.003571605437217603, 0.004699236323384317, 0.005675866063309457, 0.006470079945179132, 0.007056344585348723, 0.007415814697373854, 0.007536935784334625, 0.007415814697373854, 0.007056344585348723, 0.006470079945179132, 0.005675866063309457, 0.004699236323384331, 0.003571605437217603, 0.002329357109623993, 0.001014253485508105, 0.0009299859235246961, 0.002135826352844399, 0.003274864546640099, 0.004308808098277363, 0.005204296182472571, 0.005932524126433432, 0.006470079945179132, 0.006799684081509751, 0.006910742024642279, 0.006799684081509751, 0.006470079945179132, 0.005932524126433432, 0.005204296182472571, 0.004308808098277375, 0.003274864546640099, 0.00213582635284439, 0.0009299859235246961, 0.0008158284885834105, 0.001873649849143541, 0.002872869068033629, 0.003779894200001008, 0.004565459520715274, 0.005204296182472571, 0.005675866063309457, 0.005965010702568406, 0.006062436084608166, 0.005965010702568406, 0.005675866063309457, 0.005204296182472571, 0.004565459520715274, 0.003779894200001019, 0.002872869068033629, 0.001873649849143534, 0.0008158284885834105, 0.0006754512570311648, 0.001551256377474328, 0.002378542856058734, 0.003129498815699247, 0.003779894200001019, 0.004308808098277375, 0.004699236323384331, 0.004938628686833664, 0.005019290367182388, 0.004938628686833664, 0.004699236323384331, 0.004308808098277375, 0.003779894200001019, 0.003129498815699256, 0.002378542856058734, 0.001551256377474322, 0.0006754512570311648, 0.0005133696660845011, 0.001179016191361836, 0.001807786630155326, 0.002378542856058727, 0.002872869068033629, 0.003274864546640099, 0.003571605437217603, 0.0037535531002175, 0.003814859167051171, 0.0037535531002175, 0.003571605437217603, 0.003274864546640099, 0.002872869068033629, 0.002378542856058734, 0.001807786630155326, 0.001179016191361832, 0.0005133696660845011, 0.0003348133780675425, 0.0007689398495960377, 0.001179016191361832, 0.001551256377474317, 0.001873649849143534, 0.00213582635284439, 0.002329357109623993, 0.00244802113616284, 0.002488004198444586, 0.00244802113616284, 0.002329357109623993, 0.00213582635284439, 0.001873649849143534, 0.001551256377474322, 0.001179016191361832, 0.0007689398495960349, 0.0003348133780675425, 0.0001457851328577798, 0.0003348133780675438, 0.0005133696660845011, 0.0006754512570311628, 0.0008158284885834105, 0.0009299859235246961, 0.001014253485508105, 0.001065922421123082, 0.001083331928713395, 0.001065922421123082, 0.001014253485508105, 0.0009299859235246961, 0.0008158284885834105, 0.0006754512570311648, 0.0005133696660845011, 0.0003348133780675425, 0.0001457851328577798};
// Precomputed values of basis functions and precomputations
// FE* dimensions: [permutation][entities][points][dofs]
static const double FE_TF0[1][1][17][16] = {{{{0.5310179651539434, 0.002514143263163935, 0.5884823047483387, -0.1793847948263871, 0.09732164084031325, -0.06362108595724753, 0.04577976819603085, -0.03492972494947335, 0.02770554332857452, -0.02256350657595092, 0.01869763014686472, -0.01564139383462264, 0.01309572661657683, -0.01084094025003909, 0.008673660364852842, -0.006306936264939094},
  {-0.1279643740930969, -0.003235687285707545, 0.825276019527148, 0.4016052578050424, -0.1536075508159097, 0.09097174773003154, -0.06269562416475484, 0.04675394028868764, -0.03658362653399562, 0.02953633333506332, -0.02433380644796956, 0.02027471838678221, -0.0169273774697448, 0.01398560334933942, -0.01117514119019908, 0.008119567579283157},
  {0.04506847775101008, 0.002870613041430765, -0.1492565638184692, 0.9323133249205195, 0.236219340013864, -0.1018419901991895, 0.06319363895274897, -0.04483303014671571, 0.0341130338495718, -0.02707010731090384, 0.02205080070300053, -0.01823148475814101, 0.01514049433573509, -0.01246336839301106, 0.009934557924711289, -0.007207736866162262},
  {-0.01229554036123029, -0.001507932790634431, 0.03528793100807117, -0.07476331401308049, 0.9884767900729207, 0.08944352429381004, -0.04196240826588792, 0.02688770122719832, -0.01944302869602156, 0.01497995718888914, -0.01197709268493107, 0.009780881755744455, -0.008054536715507075, 0.006592445566051996, -0.00523505612868456, 0.003789678543292256},
  {-0.003582234564908075, -0.000739774109720467, 0.00971234526043426, -0.01662921035517776, 0.03524923230686862, 0.9980461370946736, -0.03297846445881575, 0.01652159743212438, -0.01085112819950925, 0.007953873646228531, -0.006174506294946994, 0.004948273372891968, -0.004024346742651605, 0.003266432998359481, -0.002579816169174316, 0.001861588783323459},
  {0.01139891269024134, 0.003672131136338329, -0.03003351311013579, 0.04707080384154232, -0.07679234987354021, 0.1709490109412144, 0.9626287483056376, -0.1258109160332868, 0.06647574244713014, -0.04453582436867183, 0.03295929578191496, -0.02566796309725861, 0.02049754424751977, -0.01644016709043109, 0.01288579309629175, -0.009257248914506041},
  {-0.01455857691406362, -0.006990023863127238, 0.03773300702719259, -0.05645426657445396, 0.08274433532555152, -0.1348356252830777, 0.3233027662258365, 0.8858877501707699, -0.1860605036384325, 0.1027438196202606, -0.06994074440908214, 0.05206092659087528, -0.04046019944613791, 0.03190210201316634, -0.02473958412712687, 0.01766481728184915},
  {0.01476942609043248, 0.01029569794319792, -0.03788738811311202, 0.055139045998481, -0.07636531428674226, 0.1100722191402691, -0.1820572953998159, 0.4820557925418167, 0.7741419307270463, -0.2134701215720267, 0.1222953984338127, -0.08426281753751952, 0.06278183258882505, -0.04827648106171816, 0.03687498906184535, -0.02610691455479212},
  {-0.01309204101562505, -0.01309204101562488, 0.03335544248995533, -0.04768643702639053, 0.06383014874598097, -0.08627598963282575, 0.1243076624552219, -0.2105115081265031, 0.6360727221101858, 0.6360727221101865, -0.2105115081265024, 0.1243076624552216, -0.08627598963282571, 0.06383014874598111, -0.04768643702639108, 0.03335544248995551},
  {0.01029569794319817, 0.01476942609043239, -0.02610691455479202, 0.03687498906184507, -0.04827648106171822, 0.06278183258882525, -0.08426281753751999, 0.1222953984338136, -0.2134701215720279, 0.7741419307270471, 0.4820557925418165, -0.182057295399816, 0.1100722191402696, -0.07636531428674288, 0.05513904599848175, -0.03788738811311237},
  {-0.006990023863127413, -0.01455857691406353, 0.01766481728184911, -0.02473958412712672, 0.03190210201316653, -0.0404601994461381, 0.05206092659087558, -0.06994074440908271, 0.1027438196202611, -0.1860605036384328, 0.8858877501707697, 0.3233027662258372, -0.1348356252830784, 0.08274433532555206, -0.05645426657445486, 0.03773300702719305},
  {0.003672131136338363, 0.01139891269024114, -0.00925724891450588, 0.01288579309629153, -0.01644016709043094, 0.02049754424751953, -0.0256679630972587, 0.03295929578191473, -0.04453582436867162, 0.06647574244712956, -0.1258109160332856, 0.962628748305638, 0.1709490109412131, -0.07679234987353983, 0.04707080384154243, -0.0300335131101359},
  {-0.0007397741097204323, -0.003582234564907856, 0.001861588783323354, -0.002579816169174141, 0.003266432998359122, -0.004024346742651431, 0.004948273372891867, -0.006174506294946454, 0.007953873646227993, -0.01085112819950874, 0.01652159743212317, -0.03297846445881378, 0.998046137094674, 0.03524923230686623, -0.01662921035517689, 0.009712345260433847},
  {-0.001507932790634611, -0.01229554036123084, 0.003789678543292389, -0.005235056128685074, 0.006592445566052121, -0.008054536715507425, 0.009780881755745248, -0.01197709268493141, 0.01497995718889036, -0.01944302869602261, 0.0268877012271997, -0.04196240826589059, 0.08944352429381575, 0.988476790072919, -0.07476331401308516, 0.03528793100807356},
  {0.002870613041430889, 0.04506847775100992, -0.007207736866162262, 0.009934557924711391, -0.01246336839301107, 0.01514049433573512, -0.01823148475814129, 0.02205080070300094, -0.02707010731090406, 0.03411303384957206, -0.044833030146716, 0.06319363895274903, -0.1018419901991901, 0.2362193400138683, 0.9323133249205199, -0.1492565638184722},
  {-0.003235687285707548, -0.1279643740930907, 0.008119567579282649, -0.01117514119019856, 0.0139856033493392, -0.01692737746974434, 0.0202747183867812, -0.024333806447969, 0.02953633333506164, -0.03658362653399398, 0.0467539402886867, -0.06269562416475231, 0.09097174773002825, -0.1536075508159051, 0.4016052578050343, 0.8252760195271474},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0},
  {-1.0, 1.0}}}};
  {0.5, 0.5},
    // Inputs: FE_TF1, coordinate_dofs, FE_TF2
    // Outputs: J0_c3, J0_c1, J0_c0, J0_c2
    double J0_c0 = 0.0;
    double J0_c3 = 0.0;
    double J0_c1 = 0.0;
    double J0_c2 = 0.0;
          J0_c0 += coordinate_dofs[(2 * ic0 + ic1) * 3] * (FE_TF1[0][0][iq0][ic0] * FE_TF2[0][0][iq1][ic1]);
          J0_c3 += coordinate_dofs[(2 * ic0 + ic1) * 3 + 1] * (FE_TF2[0][0][iq0][ic0] * FE_TF1[0][0][iq1][ic1]);
          J0_c1 += coordinate_dofs[(2 * ic0 + ic1) * 3] * (FE_TF2[0][0][iq0][ic0] * FE_TF1[0][0][iq1][ic1]);
          J0_c2 += coordinate_dofs[(2 * ic0 + ic1) * 3 + 1] * (FE_TF1[0][0][iq0][ic0] * FE_TF2[0][0][iq1][ic1]);
    // Inputs: J0_c3, J0_c1, J0_c0, J0_c2
    // Outputs: fw0
    double _Complex fw0 = 0;
      double sv_06e_0 = J0_c0 * J0_c3;
      double sv_06e_1 = J0_c1 * J0_c2;
      double sv_06e_2 = -sv_06e_1;
      double sv_06e_3 = sv_06e_0 + sv_06e_2;
      double sv_06e_4 = fabs(sv_06e_3);
      fw0 = sv_06e_4 * weights_06e[17 * iq0 + iq1];
    // Outputs: A
              A[256 * (16 * i0 + i1) + (16 * j0 + j1)] += fw0 * (FE_TF0[0][0][iq0][i0] * FE_TF0[0][0][iq1][i1]) * (FE_TF0[0][0][iq0][j0] * FE_TF0[0][0][iq1][j1]);
Turning off tensor product factorization yields massive tables such as:
 FE2_C0_Q06e[1][1][289][256]
Dear Mr J. S. Dokken,
First of all, I am immensely grateful for your help. Please excuse my lackluster code-pasting, I’m still quite new here (I below paste the code correctly)
Exactly! I’m trying to do a spectral method (to solve an eigenvalue problem with SLEPc), based on this post here: Does Fenicsx support spectral element methods? - FEniCS Project
The ffcx c++ file (or at least that’s what I think it is, in fact they are three files called something like libffcx_forms_218d0c58cb3ff7… and with .o, .c, and .so extensions) gets over 2 GB at p => 80. Normally, I use quadrature degree = 2p - 1 (as in the example above), I tried things like int(1.5*p) but there was a significant loss in accuracy.
I will try assembling with tensor product elements - that might be my way out of this (I spent the whole evening battling with sympy and testing different workarounds :sweat_smile:)
I’ll try and come back here to poste whether it works. Once again, thanks a lot! I leave my code (now hopefully correctly pasted) here
import os
    pep.setOperators(A)
    pep.setDimensions(nev=nev, ncv=max(15, 2*nev + 10), mpd=max(15, 2*nev + 10))
    st = pep.getST()
    ksp = st.getKSP()
    pep.setRefine(ref = SLEPc.PEP.Refine.SIMPLE, npart = 1, tol = 0.1*tol, its= 3, scheme= SLEPc.PEP.RefineScheme.SCHUR)
    # Solver
    pep.solve()
    all_eigvals = []
    efuns_list_gr = []
    efuns_list_em = []
    error_list = []
        efun_vals_gr = efuns.x.array[dof_map_gr]
        efun_vals_em = efuns.x.array[dof_map_em]
    import sympy as sp
    expanded_eqn = eqn
    import sympy as sp
    Args:
    if expr == sp.I:
        return 1j
        return expr
        return float(expr)
            return mapping[expr.name]
        raise ValueError(f"Symbol '{expr.name}' not found in mapping dictionary.")
        func_name = expr.func.__name__
            return mapping[func_name]
        raise ValueError(f"Function '{func_name}' not found in mapping dictionary.")
        result = 1
            result = result * sympy_to_ufl(arg, mapping)
        return result
        base = sympy_to_ufl(expr.args[0], mapping)
        exponent = sympy_to_ufl(expr.args[1], mapping)
        return base ** exponent
        argum = sympy_to_ufl(expr.args[0], mapping)
        ufl_func = sympy_to_ufl(expr.args[0], mapping)
                dim = 0
                dim = 1
                raise ValueError(f"Unknown derivative variable: {var.name}")
            for _ in range(count):
        return ufl_func
    # 5. Math Functions
        return ufl.conj(sympy_to_ufl(expr.args[0], mapping))
    raise NotImplementedError(f"SymPy node type {type(expr)} is not implemented in the AST walker.")
    import basix
    M_mass_num, alpha, q_ch = phys_params[:]
    Q_ch = q_ch*M_mass_num
    a_rot_num = alpha*M_mass_num
    r_p = M_mass_num + np.sqrt(M_mass_num**2 - a_rot_num**2 - Q_ch**2)
    lambda_param = r_p
    #Mesh creation
    N_x = 1
    N_y = 1
    # general cell type
    # spectral element
                                        cell_type,
                                        poly_degree,
                                [[eps, eps], [1-eps, 1-eps]],
                                [N_x, N_y],
    fdim = tdim - 1
    ME_element = basix.ufl.mixed_element([ufl_nodal_element, ufl_nodal_element])
    metadata = {
        "quadrature_degree": 2 * poly_degree - 1
    with open(f'eq_A.pk', 'rb') as f:  # Python 3: open(..., 'wb')
    with open(f'eq_B.pk', 'rb') as f:  # Python 3: open(..., 'wb')
    ufl_mapping = {
        'sigma': x[0],
        'x_coord': x[1],
        'M': M_mass_num,
        'psi': psi_gr,
        'Q': Q_ch,
        'm': 0,
        'psi_b': psi_em,
        'a': a_rot_num,
    jit_options = {
    "cffi_extra_compile_args": ["-O1", "-fno-inline"]}
    M_1.assemble()
    M_mat = M_1
    C_1.assemble()
    C_mat = C_1
    K_1.assemble()
    K_mat = K_1
    A = [ ]
    A.append(K_mat)
    A.append(C_mat)
    A.append(M_mat)
    return A, ME
poly_degree = 18
eps = 2.5e-7
debug_mode = 0
    print(f"A_{i}: max={np.max(np.abs(arr)):.2e}, "
        f"has_nan={np.any(np.isnan(arr))}, "
        f"has_inf={np.any(np.isinf(arr))}")
target =  0.85
nev = 12
tol = 1e-7
max_it = 2000
print("\n--- Sorted eigenvalues ---")
    print(f"QNM {i}: {eigval.real:.6e} + {eigval.imag:.6e}i, error {error_list[i]}")
P=80 is way higher than what I would have ever expected to use in DOLFINx :stuck_out_tongue:
However, the following form is possible to compile on my laptop
import basix.ufl
P = 80
    ), (2,)
eps = 2.5e-7
print("MESH CREATED")
print("PREFORM")
form = dolfinx.fem.form(a, form_compiler_options={"sum_factorization": True})
print("POSTFORM")
J = dolfinx.fem.assemble_matrix(form)
print("ASSEMBLE")
I’m currently stuck at assembling this, as it has a loop of 82^2\cdot 81^4=289~446~152~004 sum operations in the local tensor,
Running with order 40 is fairly fast though, with form compilation taking 1.29 seconds and assembly 18.17 seconds
while the same operations took 15.88 and 18.4 seconds.
Order 50 compilation takes 3.17 seconds and assembly 97.6 seconds
Thank you very much for your working example! Unfortunately, I’ve been trying to implement it over the day, and got some (sad :smiling_face_with_tear:) conclusions:
  • The problem is the generation of a file named libffcx_forms_5b2b2baa72db4ea6cb4e41304c5e40c4338e795f.c / .o /. so, whose size skyrockets if the polynomial degree is large. If it ever gets above 2 GB (for me, that happens when p > 80), then the program crashes, returning this:
  •   File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/dolfinx/jit.py", line 215, in ffcx_jit
      File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/jit.py", line 244, in compile_forms
        raise e
      File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/jit.py", line 224, in compile_forms
        impl = _compile_objects(
      File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/jit.py", line 399, in _compile_objects
        ffibuilder.compile(tmpdir=cache_dir, verbose=True, debug=cffi_debug)
      File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/cffi/api.py", line 727, in compile
        return recompile(self, module_name, source, tmpdir=tmpdir,
      File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/cffi/recompiler.py", line 1581, in recompile
        outputfilename = ffiplatform.compile('.', ext,
      File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/cffi/ffiplatform.py", line 20, in compile
        outputfilename = _build(tmpdir, ext, compiler_verbose, debug)
      File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/cffi/ffiplatform.py", line 54, in _build
        raise VerificationError('%s: %s' % (e.__class__.__name__, e))
    cffi.VerificationError: LinkError: command '/home/mario/.conda/envs/fenicsxv11-env/bin/gcc' failed with exit code 1
  • The key that makes tensor product elements work seems to be adding ,form_compiler_options={“sum_factorization”: True} . It makes the size of that file drops from 22 MB to approximately 50 KB (for a degree ~ 20), which made me hopeful that with a degree ~ 80 the size would plummet. However…
  • If any of my forms (to which I wish to apply form_compiler_options={“sum_factorization”: True} ) contain either:
    • second derivatives of trial functions
    • Two different test functions (as in a Mixed-Element setup)
    • The ufl operator for boundary evaluation ufl.ds
I get the error:
    K_formed = fem.form(K_form, form_compiler_options={"sum_factorization": True})
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/dolfinx/fem/forms.py", line 449, in form
    return _create_form(form)
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/dolfinx/fem/forms.py", line 441, in _create_form
    return _form(form)
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/dolfinx/fem/forms.py", line 361, in _form
    ufcx_form, module, code = jit.ffcx_jit(
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/dolfinx/jit.py", line 60, in mpi_jit
    raise e
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/jit.py", line 349, in _compile_objects
    _, code_body = ffcx.compiler.compile_ufl_objects(
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/compiler.py", line 118, in compile_ufl_objects
    code = generate_code(ir, options)
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/codegeneration.py", line 49, in generate_code
    integral_generator(integral_ir, domain, options)
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/C/integrals.py", line 42, in generator
    parts = ig.generate(domain)
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/integral_generator.py", line 167, in generate
    all_preparts += self.generate_piecewise_partition(rule, cell)
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/integral_generator.py", line 309, in generate_piecewise_partition
    return self.generate_partition(arraysymbol, F, "piecewise", None, None)
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/integral_generator.py", line 337, in generate_partition
    vdef = self.backend.definitions.get(mt, tabledata, quadrature_rule, vaccess)
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/definitions.py", line 111, in get
    return handler(mt, tabledata, quadrature_rule, access)  # type: ignore
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/definitions.py", line 200, in _define_coordinate_dofs_lincomb
    FE, tables = self.access.table_access(tabledata, self.entity_type, mt.restriction, iq, ic)
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/access.py", line 468, in table_access
    iq_i = quadrature_index.local_index(i)
  File "/home/mario/.conda/envs/fenicsxv11-env/lib/python3.12/site-packages/ffcx/codegeneration/lnodes.py", line 387, in local_index
    assert idx < len(self.symbols)
AssertionError
In light of these: do you happen to know any workaround so that, either I avoid completely saving the “long-named” file, or anything similar to ,form_compiler_options={“sum_factorization”: True} that may work in a general setting?
I can probably get around the second derivative issues, by integrating by parts and modifying the math to get rid of boundary terms, but I’m tackling a coupled PDE system, so Mixed-Elements seems mandatory.
EDIT: I just learned you can build a coupled system without mixed elements, which I just tried and it works. Now I only need to get around the derivatives issue!
Once again, thank you very much for your help. I really wish there was a way to avoid so much information being saved into the cache. If you have any further ideas, I would be utterly glad to try them out :slight_smile:
There are several ways one can work around the issues of the mixed system.
For example:
  1. Instead of mixed spaces, use a blocked element. You can see this for the coordinate element in my example:
Could you make some minimal example (similar to what i showed in the post above) for each of this forms. Then I can investigate each of them.
I didn’t know about block elements; thank you very much! That takes care of the mixed-element issue.
I here attach a simple version of what I’m attempting (the spectral eigenvalue solver). This is the “raw” version, with raw second derivatives (u.dx(0).dx(0))
import datetime
debug_mode = 1
now = datetime.datetime.now()
if debug_mode == 1:
    print(f"Process started at {str(now.time())}")
from math import pi
from kerrnewman_functions import extremality
import os
import warnings
warnings.filterwarnings("ignore")
rank = comm.Get_rank()
size = comm.Get_size()
    import basix.ufl
    V_gr = ME
    pep.setOperators(A)
    st = pep.getST()
    ksp = st.getKSP()
    # Solver
    pep.solve()
    all_eigvals = []
    efuns_list_gr = []
    efuns_list_em = []
    error_list = []
        efun_vals_gr = efuns.x.array[:]
def new_assembler(phys_params, poly_degree, eps, debug_mode):
    import basix.ufl
    from ufl import inner
    import warnings
    import time
    ############## PARAMETERS UNPACKING ################
    M_mass_num, alpha, q_ch, m = phys_params[:]
    Q = q_ch*M_mass_num
    a_rot = alpha*M_mass_num
    lambda_ = r_p
    ############## MESH BUILDING ###############
        basix.create_tp_element(basix.ElementFamily.P, cell_type, poly_degree, basix.LagrangeVariant.gll_warped)
        ), (2,)
    domain = mesh.create_mesh(MPI.COMM_WORLD, cells=connectivity, x=nodes, e=c_el)
    ########## FUNCTION SPACE ###########33333
    V_gr = fem.functionspace(domain, element)
    ######## TRIAL AND TEST FUNCTIONS##########
    v_test_gr = ufl.TestFunction(V_gr)
    psi_gr = ufl.TrialFunction(V_gr)
    dx_meas = ufl.dx
    ################ COEFFICIENTS DEFINITION #####################
    M_psi_gr = 4*(a_rot**2*lambda_*x[1]**4 - a_rot**2*lambda_*x[1]**2
                                      + a_rot**2*lambda_ + a_rot**2*x[0] + lambda_**3 + 2*lambda_**2*x[0] - lambda_**2 +
                                      lambda_*x[0]**2 - 2*lambda_*x[0] + lambda_ - x[0]**2 + x[0])/lambda_
    C_psi_gr = 2*1j*(a_rot**2*x[0] + 1j*a_rot*lambda_*m - 4*1j*a_rot*lambda_*x[1]**2 + 2*1j*a_rot*lambda_ +
                                         2*1j*a_rot*m*x[0] + 2*lambda_**2*x[0] + 3*lambda_*x[0]**2 - 2*lambda_*x[0] + 2*lambda_ - 3*x[0]**2)/lambda_
    C_dpgr_dsigma = fem.Function(V_gr)
    C_dpgr_dsigma.interpolate(lambda x: 2*1j*(a_rot**2*x[0]**2 + 2*lambda_**2*x[0]**2 - lambda_**2 + 2*lambda_*x[0]**3 - 2*lambda_*x[0]**2 - 2*x[0]**3 + 2*x[0]**2)/lambda_)
    K_psi_gr =  -1j*(8*a_rot*m_mode*x[0]*x[1]**4 - 8*a_rot*m_mode*x[0]*x[1]**2 + 1j*lambda_*m_mode**2 - 8*1j*lambda_*m_mode*x[1]**2 +
                                       4*1j*lambda_*m_mode - 8*1j*lambda_*x[0]**2*x[1]**4 + 8*1j*lambda_*x[0]**2*x[1]**2 - 16*1j*lambda_*x[1]**4 +
                                       32*1j*lambda_*x[1]**2 - 12*1j*lambda_ + 8*1j*x[0]**2*x[1]**4 - 8*1j*x[0]**2*x[1]**2 + 4*1j*x[0]*x[1]**4
                                       - 4*1j*x[0]*x[1]**2)/(4*lambda_*x[1]**2*(x[1] - 1)*(x[1] + 1))
    n = ufl.FacetNormal(domain)
    ds_meas = ufl.ds(domain=domain)
    K_dpgr_dx = -(11*x[1]**2 - 9)/(4*x[1])
    K_dpgr_sigma = -1j*x[0]*(2*a_rot*m_mode*x[0] - 4*1j*lambda_*x[0]**2 - 2*1j*lambda_ + 4*1j*x[0]**2 - 1j*x[0])/lambda_
    K_d2p_gr_xx =  -(x[1] - 1)*(x[1] + 1)/4
    K_d2p_gr_sigma =  -x[0]**2*(x[0] - 1)*(lambda_*x[0] + lambda_ - x[0])/lambda_
    Kdev = (x[0]*(2*lambda_ - 3*x[0] - 4*lambda_*x[0]**2 + 4*x[0]**2))/lambda_
    # BOUNDARY ITEMS (unused in this version)
    ########## EQUATION BUILDING
    K_form = K_d2p_gr_sigma * ufl.inner(psi_gr.dx(0).dx(0), v_test_gr) * dx_meas
    K_form +=  K_d2p_gr_xx * ufl.inner(psi_gr.dx(1).dx(1), v_test_gr) * dx_meas
    K_form += K_dpgr_dx * ufl.inner(psi_gr.dx(1), v_test_gr) * dx_meas \
               + K_psi_gr * ufl.inner(psi_gr, v_test_gr) * dx_meas \
               + K_dpgr_sigma * ufl.inner(psi_gr.dx(0), v_test_gr) * dx_meas
    C_form = C_dpgr_dsigma*inner(psi_gr.dx(0),v_test_gr)*dx_meas + C_psi_gr*inner(psi_gr, v_test_gr)*dx_meas
    M_form = M_psi_gr*inner(psi_gr,v_test_gr)*dx_meas
    time_seq = time.time()
    if debug_mode == 1:
        print("assembling forms and matrices...")
    K_formed = fem.form(K_form, form_compiler_options={"sum_factorization": False}) # If true, an error is returned
    C_formed = fem.form(C_form, form_compiler_options={"sum_factorization": True})
    M_formed = fem.form(M_form, form_compiler_options={"sum_factorization": True})
    K_mat = assemble_matrix(K_formed)
    K_mat.assemble()
    C_mat = assemble_matrix(C_formed)
    C_mat.assemble()
    M_mat = assemble_matrix(M_formed)
    M_mat.assemble()
    # Add them together in PETSc
    if debug_mode == 1:
        print(f"Time of assembly: {time.time() - time_seq}")
    A = [ ]
    A.append(K_mat)
    A.append(C_mat)
    A.append(M_mat)
    return A, V_gr
############   START
M_mass = 0.5
m_mode = 2
alpha_rot = 0
q_charge = 0
print(f"extremality is {100*extremality(alpha_rot*M_mass, q_charge*M_mass, M_mass)} %")
Q_ch = q_charge*M_mass
a_rot_num = alpha_rot*M_mass
r_p = M_mass + np.sqrt(M_mass**2 - a_rot_num**2 - Q_ch**2)
phys_params = [M_mass, alpha_rot, q_charge, m_mode]
poly_degree = 18
# No need to cut the domain to avoid singularities in this case
eps = 0
debug_mode = 0
target =  0.85
if rank == 0:
    print(f"Physical parameters: (M,a,Q) = ({M_mass}, {a_rot_num}, {Q_ch})")
    print(f"Event horizon located at {2*r_p} M")
    if a_rot_num > 0:
        print(f"Computing QNMs for m = {m_mode}, at polynomial degree {poly_degree}")
        print(f"Computing QNMs for any m, at polynomial degree  {poly_degree}")
    print(f"Target magnitude is {target}")
A, ME = new_assembler(phys_params, poly_degree, eps, debug_mode = 1)
for i, mat in enumerate(A):  # your PEP matrices
target =  0.85
nev = 12
tol = 1e-7
max_it = 2000
if rank == 0:
    print("\n--- Sorted Quasinormal Modes (QNMs) ---")
If I turn form_compiler_options={“sum_factorization”: True} for my K_form (the one including second derivatives, I get the following error:
  File "/home/mmisas/PhD/eigenvalues/local_kn/prueba_2nd.py", line 228, in <module>
  File "/home/mmisas/PhD/eigenvalues/local_kn/prueba_2nd.py", line 171, in new_assembler
    K_formed = fem.form(K_form, form_compiler_options={"sum_factorization": True}) # If true, an error is returned
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/dolfinx/fem/forms.py", line 449, in form
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/dolfinx/fem/forms.py", line 441, in _create_form
    return _form(form)
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/dolfinx/fem/forms.py", line 361, in _form
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/dolfinx/jit.py", line 60, in mpi_jit
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/dolfinx/jit.py", line 215, in ffcx_jit
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/codegeneration/jit.py", line 244, in compile_forms
    raise e
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/codegeneration/jit.py", line 224, in compile_forms
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/codegeneration/jit.py", line 349, in _compile_objects
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/compiler.py", line 118, in compile_ufl_objects
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/codegeneration/codegeneration.py", line 49, in generate_code
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/codegeneration/C/integrals.py", line 42, in generator
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/codegeneration/integral_generator.py", line 167, in generate
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/codegeneration/integral_generator.py", line 309, in generate_piecewise_partition
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/codegeneration/integral_generator.py", line 337, in generate_partition
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/codegeneration/definitions.py", line 111, in get
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/codegeneration/definitions.py", line 200, in _define_coordinate_dofs_lincomb
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/codegeneration/access.py", line 468, in table_access
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/codegeneration/lnodes.py", line 387, in local_index
AssertionError
I have also tried to integrate by parts, coding integration over the boundaries explicitly. It’s the same code as before, but substituting the equation block with this other:
    K_form = K_d2p_gr_sigma * ufl.inner(psi_gr.dx(0), v_test_gr) * n[0] * ds_meas \
              + K_d2p_gr_xx * ufl.inner(psi_gr.dx(1), v_test_gr) * n[1] * ds_meas
    # Derivative of the K_d2p_gr_sigma term with respect to x[0], the derivative of
    # K_d2p_gr_xx with respect to x[1] is just -(x[1]/2)
    K_form = -(x[1]/2) * ufl.inner(psi_gr.dx(1), v_test_gr) * dx_meas \
              - Kdev * ufl.inner(psi_gr.dx(0), v_test_gr) * dx_meas
    K_form += -K_d2p_gr_sigma * ufl.inner(psi_gr.dx(0), v_test_gr.dx(0)) * dx_meas \
               - K_d2p_gr_xx * ufl.inner(psi_gr.dx(1), v_test_gr.dx(1)) * dx_meas
    # 4. Compile them separately
And what I get is
  File "/home/mmisas/PhD/eigenvalues/local_kn/prueba.py", line 307, in <module>
  File "/home/mmisas/PhD/eigenvalues/local_kn/prueba.py", line 231, in new_assembler
    K_bnd_form = fem.form(K_bnd_ufl, form_compiler_options={"sum_factorization": True})
    return _form(form)
    raise e
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/compiler.py", line 113, in compile_ufl_objects
    ir = compute_ir(analysis, _object_names, _prefix, options, visualise)
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/ir/representation.py", line 151, in compute_ir
    _compute_integral_ir(
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/ir/representation.py", line 402, in _compute_integral_ir
    integral_ir = compute_integral_ir(
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/ir/integral.py", line 170, in compute_integral_ir
    mt_table_reference = build_optimized_tables(
  File "/home/mmisas/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ffcx/ir/elementtables.py", line 557, in build_optimized_tables
    raise RuntimeError("Sum factorization not available for this quadrature rule.")
RuntimeError: Sum factorization not available for this quadrature rule.
I’ll try to come up with a workaround and let you know if I can get by somehow. Thanks again :slightly_smiling_face:
It finally worked!!! :confetti_ball: :confetti_ball:
I just had to define function spaces for auxiliary variables like this
V_main_a = fem.functionspace(domain, element)
V_main_b = fem.functionspace(domain, element)
V_aux_a = fem.functionspace(domain, element)
V_aux_b = fem.functionspace(domain, element)
p_a =  ufl.TrialFunction(V_main_a) #solutions
p_b = ufl.TrialFunction(V_main_b) #solutions
u_a  =  ufl.TrialFunction(V_aux_a) #Derivative of p_a
u_a  =  ufl.TrialFunction(V_aux_b) #Derivative of p_b
w_aux_a = ufl.TestFunction(V_aux_a)
########### .... defining other test functions, etc ...... #####
EQ_aux = ufl.inner(u_a,w_aux_a)*ufl.dx
And performing block assembly. I’ll be posting the final working code soon in an edit!
Now not only does it go far beyond p >= 80, but it also compiles much faster
I am immensely thankful! :blush:
