Hello dolfinx users, I have a problem that requires me to compute eigenvalues, so dolfinx wrappers and petsc4py are not enough, I need to leverage slepc4py.
Physically, I want to do resolvant analysis at frequency 0 on a simple shear flow. This requires linearising Navier-Stokes, but also using an extensor matrix and manually setting boundary conditions outside of FENICsx wrappers.
Mathematically, I’m solving a generalised eigenvalue problem of the like of : B^HJ^{-1H}NJBf=\sigma Mf
B is an extensor so that Bf=\left[\begin{array}{c}f\\0\end{array}\right]
J is the Jacobian of Navier-Stokes with a trivial baseflow.
N is a norm matrix that satisfies : q^HNq=[u^H\;p^H]N\left[\begin{array}{c}u\\p\end{array}\right]=\int |u|^2 dx
Likewise, M is a norm matrix. f^HMf=\int |f|^2 dx
I’ve had mixed success - my code runs in serial and produces a nice graph :
However, the same code breaks apart in parallel :
Here’s my MWE. Apologies in advance for length, I did my best to boil it down.
import dolfinx as dfx
from petsc4py import PETSc as pet
from slepc4py import SLEPc as slp
from mpi4py.MPI import COMM_WORLD as comm
mesh=dfx.UnitSquareMesh(comm,100,100)
FE_vector_1=ufl.VectorElement("Lagrange",mesh.ufl_cell(),1)
FE_vector_2=ufl.VectorElement("Lagrange",mesh.ufl_cell(),2)
FE_scalar =ufl.FiniteElement("Lagrange",mesh.ufl_cell(),1)
# Taylor Hood elements
V =dfx.FunctionSpace(mesh,FE_vector_1)
TH=dfx.FunctionSpace(mesh,FE_vector_2*FE_scalar)
# Extract velocities only
U, _ = TH.sub(0).collapse(collapsed_dofs=True)
q,l=ufl.TrialFunction(TH),ufl.TestFunction(TH)
ub=dfx.Function(V)
w,z=ufl.TrialFunction(U), ufl.TestFunction(U)
u,p=ufl.split(q); v,s=ufl.split(l)
# Baseflow
if comm.size==1:
x=mesh.geometry.x[:,:2]
ub.vector[::2]=-1+2*x[:,1]
viewer = pet.Viewer().createMPIIO("sanity_check_baseflow.dat", 'w', comm)
ub.vector.view(viewer)
viewer = pet.Viewer().createMPIIO("sanity_check_baseflow.dat", 'r', comm)
ub.vector.load(viewer)
# Mass csv
J_form = ufl.inner(ufl.div(u), s)
# Momentum (different test functions and IBP)
J_form += ufl.inner(ufl.grad(ub)*u, v) # Convection
J_form += ufl.inner(ufl.grad(u)*ub, v)
J_form += ufl.inner(ufl.grad(u),ufl.grad(v))/100 # Diffusion (Re=100)
J_form -= ufl.inner(p, ufl.div( v)) # Pressure
J_form *= ufl.dx
# Velocity norm
N_form = ufl.inner(u,v)*ufl.dx
# Forcing norm
M_form = ufl.inner(w,z)*ufl.dx
# Extensor
B_form = ufl.inner(w,v)*ufl.dx
# Assembling matrices
J = dfx.fem.assemble_matrix(J_form); J.assemble() # Jacobian
N = dfx.fem.assemble_matrix(N_form); N.assemble() # Mass matrix for q
M = dfx.fem.assemble_matrix(M_form); M.assemble() # Mass matrix for f
B = dfx.fem.assemble_matrix(B_form); B.assemble() # Extensor
# Boundary conditions
def border(x): return np.isclose(x[0],0)+np.isclose(x[0],1)+np.isclose(x[1],0)+np.isclose(x[1],1)
dofs,_=dfx.fem.locate_dofs_geometrical((TH.sub(0),U),border)
J.zeroRows(dofs); B.zeroRows(dofs,0)
# Sizes
n=B.getSize()[1]
n_local=B.getLocalSize()[1]
def setupKSP(KSP):
KSP.setType('preonly')
# Preconditioner
PC = KSP.getPC(); PC.setType('lu')
PC.setFactorSolverType('mumps')
KSP.setFromOptions()
# Compute solvers instead of inverses
KSPs = []
for Mat in [J,J.copy().hermitianTranspose()]:
# Krylov subspace
KSP = pet.KSP().create(comm)
KSP.setOperators(Mat)
setupKSP(KSP)
KSPs.append(KSP)
w,z = J.getVecs()
# Resolvent operator
class LHS_class:
def mult(cls,A,x,y):
B.mult(x,w)
KSPs[0].solve(w,z)
N.mult(z,w)
KSPs[1].solve(w,z)
B.multTranspose(z,y)
LHS=pet.Mat().create(comm)
LHS.setSizes([[n_local,n]]*2)
LHS.setType(pet.Mat.Type.PYTHON)
LHS.setPythonContext(LHS_class())
LHS.setUp()
# Eigensolver
EPS = slp.EPS(); EPS.create(comm)
EPS.setOperators(LHS,M) # Solve B^T*L^-1H*L^-1*B*f=sigma^2*M*f (cheaper than a proper SVD)
EPS.setProblemType(slp.EPS.ProblemType.GHEP) # Specify that A is hermitian (by construction), & M is semi-positive
EPS.setDimensions(1,10) # Find k eigenvalues only with max number of Lanczos vectors
EPS.setTolerances(1e-6,100) # Set absolute tolerance and number of iterations
# Spectral transform
ST = EPS.getST(); ST.setType('shift'); ST.setShift(0)
# Krylov subspace
KSP = ST.getKSP()
setupKSP(KSP)
EPS.setFromOptions()
EPS.solve()
f=dfx.Function(U)
EPS.getEigenvector(0,f.vector)
q=dfx.Function(TH)
B.mult(f.vector,w)
KSPs[0].solve(w,q.vector)
u,_=q.split()
with XDMFFile(comm, "sanity_check_response.xdmf","w") as xdmf:
xdmf.write_mesh(mesh)
xdmf.write_function(u)
Running the above code in the dolfinx 3.1.0 docker container in serial then in parallel (complex mode) should reproduce above behaviour.
I strongly suspect I’ve forgotten to ghost a vector or messed up my information-sharing between processors.
I couldn’t reproduce the issue with a single KSP so I’m stuck with considering how petsc4py and slepc4py interact…
