Find cell tags from two overlapped meshes with different resolutions
I try to mark all the overlapped region from two meshes with different resolutions. Here I use collision related functions in dolfinx.geometry and meshtag, but the number of overlapped elements is much less than the expected. The following is the code and screenshot with DOLFINx v0.6.0:
from dolfinx import fem, io, mesh, geometry
def mark_cells(msh, cell_index):
    num_cells = msh.topology.index_map(
        msh.topology.dim).size_local + msh.topology.index_map(
        msh.topology.dim).num_ghosts
    cells  = np.arange(0, num_cells)
    values = np.full(cells.shape, 0, dtype=np.int32)
    values[cell_index] = np.full(len(cell_index), 1, dtype=np.int32)
    cell_tag = mesh.meshtags(msh, msh.topology.dim, cells, values)
    return cell_tag
mesh_big = mesh.create_unit_square(MPI.COMM_WORLD, 64, 64)
mesh_big.geometry.x[:, :2] -= 0.51
mesh_big.geometry.x[:, :2] *= 4
mesh_small = mesh.create_unit_square(MPI.COMM_WORLD, 1, 1)
mesh_small.geometry.x[:, :2] -= 0.5
bb_tree         = geometry.BoundingBoxTree(mesh_big, mesh_big.topology.dim)
cell_candidates = geometry.compute_collisions(bb_tree, mesh_small.geometry.x)
colliding_cells = geometry.compute_colliding_cells(mesh_big, cell_candidates, mesh_small.geometry.x)
cell_indices = []
for i, point in enumerate(mesh_small.geometry.x):
    if len(colliding_cells.links(i))>0:
        cell_indices.append(colliding_cells.links(i)[0])
cell_tags = mark_cells(mesh_big, cell_indices)
with io.XDMFFile(MPI.COMM_WORLD, "cell_tags.xdmf", "w") as file:
    file.write_mesh(mesh_big)
    file.write_meshtags(cell_tags)
with io.XDMFFile(MPI.COMM_WORLD, "mesh_small.xdmf", "w") as file:
    file.write_mesh(mesh_small)
# Validation with the area of the overlapped region
dxs = ufl.Measure("dx", domain=mesh_big, subdomain_data=cell_tags)
f = 1*dxs(1)
area = MPI.COMM_WORLD.allreduce(
    fem.assemble_scalar(fem.form(f)), op=MPI.SUM)
print("Area:", area)
This is because you are computing the intersection between the nodes (mesh geometry, in your case the vertices), and the mesh, not the cells itself.
The following code runs in dolfinx v0.7.x (Only minor changes to adapt it to 0.6.x required):
from dolfinx import fem, io, mesh, geometry, cpp
    cells = np.arange(0, num_cells, dtype=np.int32)
    return cell_tag
num_big_cells = mesh_big.topology.index_map(mesh_big.topology.dim).size_local + \
    mesh_big.topology.index_map(mesh_big.topology.dim).num_ghosts
num_small_cells = mesh_small.topology.index_map(mesh_small.topology.dim).size_local + \
    mesh_small.topology.index_map(mesh_small.topology.dim).num_ghosts
bb_tree = geometry.bb_tree(
    mesh_big, mesh_big.topology.dim, np.arange(num_big_cells, dtype=np.int32))
bb_small = geometry.bb_tree(
    mesh_small, mesh_small.topology.dim, np.arange(num_small_cells, dtype=np.int32))
collisions = geometry.compute_collisions_trees(bb_tree, bb_small)
def extract_cell_geometry(input_mesh, cell: int):
    mesh_nodes = cpp.mesh.entities_to_geometry(
        input_mesh._cpp_object, input_mesh.topology.dim, np.array([cell], dtype=np.int32), False)[0]
    return input_mesh.geometry.x[mesh_nodes]
tol = 1e-13
big_cells = []
small_cells = []
for i, (big_cell, small_cell) in enumerate(collisions):
    geom_small = extract_cell_geometry(mesh_small, small_cell)
    geom_big = extract_cell_geometry(mesh_big, big_cell)
    distance = geometry.compute_distance_gjk(geom_big, geom_small)
    if np.linalg.norm(distance) <= tol:
        big_cells.append(big_cell)
        small_cells.append(small_cell)
cell_tags_big = mark_cells(mesh_big, np.asarray(big_cells, dtype=np.int32))
cell_tags_small = mark_cells(
    mesh_small, np.asarray(small_cells, dtype=np.int32))
    file.write_meshtags(cell_tags_big, mesh_big.geometry)
    file.write_meshtags(cell_tags_small, mesh_small.geometry)
dxs = ufl.Measure("dx", domain=mesh_big, subdomain_data=cell_tags_big)
f = 1*dxs(1)
Note that to get this to work in parallel, you need to do slightly more work than this, as the bounding boxes only work on the given process, no parallel communication internally.
It is not the most complicated thing to add, but as I’m not sure you need it I won’t add it here.
I get that you used two bounding box trees of cells to find colliding cells with compute_collisions_trees (or compute_collisions in v0.6.0). As you have already found the colliding cells in two meshes respectively, why you further compute the gjk distance between two colliding cells? The result looks equivalent if I replace the following code
with
big_cells = [x for x, y in collisions]
small_cells = [y for x, y in collisions]
The cell_tag shows only a part if I run in parallel as you said. I am wondering how to adapt it to the parallel version.
A off-topic question: The calling of input_mesh._cpp_object returns a dolfinx.cpp.mesh.Mesh_float64 object while input_mesh gives dolfinx.mesh.Mesh object. The API of cpp.mesh.entities_to_geometry in v0.7.x gives one more calling method than that in v0.6.x. What is the goal of this design?
This is because your grids are axis aligned. The first computation is between bounding boxes (not triangular cells), thus will in most cases give more results than computing the collisions between the cells. We first use the collisions between the trees as it is much faster than computing than the collision between all cells.
All core structures of DOLFINx are written in C++.
These are often templated (for instance over mesh geometry precision). In Python, you do not have the templating notion, a mesh is a mesh irregardless of the floating precision. Additionally, the mesh has to interact with other packages written in pure Python (ufl).
Thanks, and how can get it to work in parallel when the bounding box tree only works on the given process?
This is quite more elaborate, and I’ve published a code under MIT license that does exactly this.
Eventually, I might refine it and make an extension to DOLFINx that performs these operations.
In a parallel run with mpirun -n 2 python .. (v0.7.2), the program stucks with the following message. Looks like the MPI alltoall issue?
WARNING: Linux kernel CMA support was requested via the
btl_vader_single_copy_mechanism MCA variable, but CMA support is
not available due to restrictive ptrace settings.
The vader shared memory BTL will fall back on another single-copy
mechanism if one is available. This may result in lower performance.
  Local host: *****
  File "*****/chenyongxin/test/fenicsx/parallel_celltags.py", line 111, in <module>
    small_to_big_comm.Neighbor_alltoall(send_geom_size, recv_geom_size)
  File "mpi4py/MPI/Comm.pyx", line 2154, in mpi4py.MPI.Topocomm.Neighbor_alltoall
mpi4py.MPI.Exception: MPI_ERR_TRUNCATE: message truncated
[*****:1221478] 1 more process has sent help message help-btl-vader.txt / cma-permission-denied
[*****:1221478] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Additionally, the Linux kernel warning pops up in every parallel run even if those programs complete successfully.
I cannot reproduce this with the docker images for v0.7.2 or v0.7.3
docker run -ti --network=host -e DISPLAY=$DISPLAY -v /tmp/.X11-unix:/tmp/.X11-unix -v $(pwd):/root/shared -w /root/shared --rm ghcr.io/fenics/dolfinx/dolfinx:v0.7.3
docker run -ti --network=host -e DISPLAY=$DISPLAY -v /tmp/.X11-unix:/tmp/.X11-unix -v $(pwd):/root/shared -w /root/shared --rm ghcr.io/fenics/dolfinx/dolfinx:v0.7.2
How did you install DOLFINx?
I installed dolfinx with conda:
conda install -c conda-forge fenics-dolfinx=0.7.2
This is actual an issue with openmpi. I’ve pushed some updates that should fix this issue.
Thanks to @minrk for discussing these issues.
Minimal failing example with openmpi (works with mpich)
comm = MPI.COMM_WORLD
assert (comm.size == 2)
dtype = np.int64
if comm.rank == 0:
    outgoing_edges = np.array([], dtype=dtype)
elif comm.rank == 1:
    outgoing_edges = np.array([0], dtype=dtype)
sub_comm = comm.Create_dist_graph(
    list([comm.rank]), [len(np.unique(outgoing_edges))], outgoing_edges, reorder=False)
source, dest, _ = sub_comm.Get_dist_neighbors()
send_data = np.full(len(dest), comm.rank, dtype=dtype)
recv_data = np.full(len(source), -1, dtype=dtype)
print(comm.rank, source, dest,
      send_data, recv_data, flush=True)
sub_comm.Neighbor_alltoall(send_data, recv_data)
comm.Barrier()
Corrected code to work with openmpi
dtype = np.int64
if comm.rank == 0:
send_data = np.full(max(len(dest), 1), comm.rank, dtype=dtype)
recv_data = np.full(max(len(source), 1), -1, dtype=dtype)
send_data = send_data[:len(dest)]
recv_data = recv_data[:len(source)]
comm.Barrier()
In case this is useful for others, I have attached an updated version of the gist above that works with the dolfinx v0.9.0 mesh interface (kudos to @dokken) .
  • The argument to create_mesh is changed from mesh_small.ufl_domain() to ufl.Mesh(mesh_small.ufl_domain().ufl_coordinate_element())
  • mesh_small.topology.cell_types[0] is changed to mesh_small.topology.cell_type.
def find_colliding_cells(mesh_big, mesh_small):
    # Get number of cells for each mesh
    big_process = bb_tree.create_global_tree(mesh_big.comm)
    process_collisions = geometry.compute_collisions_trees(
        bb_small, big_process)
    outgoing_edges = set()
    num_outgoing_cells = np.zeros(mesh_big.comm.size, dtype=np.int32)
    cell_indices = []
    for cell_idx, process_idx in process_collisions:
        num_outgoing_cells[process_idx] += 1
        outgoing_edges = set.union(outgoing_edges, (process_idx,))
    outgoing_edges = np.asarray(np.unique(list(outgoing_edges)), dtype=np.int32)
    small_to_big_comm = mesh_small.comm.Create_dist_graph(
        list([mesh_small.comm.rank]), [len(np.unique(outgoing_edges))], outgoing_edges, reorder=False)
    num_cells = num_small_cells
    source, dest, _ = small_to_big_comm.Get_dist_neighbors()
    num_vertices_per_cell_small = cpp.mesh.cell_num_vertices(
        mesh_small.topology.cell_type)
    # Extract all mesh nodes per process
    process_offsets = np.zeros(len(dest)+1, dtype=np.int32)
    np.cumsum(num_outgoing_cells[dest], out=process_offsets[1:])
    sending_cells = np.full(process_offsets[-1], 10, dtype=np.int32)
    insert_counter = np.zeros_like(dest, dtype=np.int32)
        local_idx = np.flatnonzero(dest == process_idx)
        assert len(local_idx) == 1
        idx = local_idx[0]
        sending_cells[process_offsets[idx]+insert_counter[idx]] = cell_idx
        insert_counter[idx] += 1
    node_counter = np.zeros(mesh_small.geometry.index_map().size_local +
                            mesh_small.geometry.index_map().num_ghosts+1, dtype=np.int32)
    local_pos = np.zeros_like(node_counter, dtype=np.int32)
    send_geom = []
    send_top = []
    send_top_size = np.zeros_like(dest, dtype=np.int32)
    send_geom_size = np.zeros_like(dest, dtype=np.int32)
    for i in range(len(dest)):
        # Get nodes of all cells sent to a given process
        org_nodes = cpp.mesh.entities_to_geometry(
            mesh_small._cpp_object, mesh_small.topology.dim, sending_cells[process_offsets[i]:process_offsets[i+1]], False).reshape(-1)
        # Get the unique set of nodes sent to this process
        unique_nodes = np.unique(org_nodes)
        # Compute remapping of nodes
        node_counter[:] = 0
        node_counter[unique_nodes] = 1
        np.cumsum(node_counter, out=local_pos)
        local_pos -= 1  # Map to 0 index system
        send_geom.append(
            mesh_small.geometry.x[unique_nodes][:, :mesh_small.geometry.dim])
        send_geom_size[i] = np.size(send_geom[-1])
        send_top.append(local_pos[org_nodes])
        send_top_size[i] = np.size(send_top[-1])
    # Compute send and receive offsets for geometry and topology
    geom_offset = np.zeros(len(dest)+1, dtype=np.int32)
    top_offset = np.zeros(len(dest)+1, dtype=np.int32)
    np.cumsum(send_geom_size, out=geom_offset[1:])
    np.cumsum(send_top_size, out=top_offset[1:])
    if len(send_geom) == 0:
        send_geom = np.array([], dtype=mesh_small.geometry.x.dtype)
        send_geom = np.vstack(send_geom).reshape(-1)
    if len(send_top) == 0:
        send_top = np.array([], dtype=np.int32)
        send_top = np.hstack(send_top)
    if len(send_geom_size) == 0:
        send_geom_size = np.zeros(1, dtype=np.int32)
    if len(send_top_size) == 0:
        send_top_size = np.zeros(1, dtype=np.int32)
    recv_geom_size = np.zeros(max(len(source), 1), dtype=np.int32)
    recv_geom_size = recv_geom_size[:len(source)]
    send_geom_size = send_geom_size[:len(dest)]
    recv_geom_offsets = np.zeros(len(recv_geom_size)+1, dtype=np.int32)
    np.cumsum(recv_geom_size, out=recv_geom_offsets[1:])
    recv_top_size = np.zeros(max(len(source), 1), dtype=np.int32)
    small_to_big_comm.Neighbor_alltoall(send_top_size, recv_top_size)
    recv_top_size = recv_top_size[:len(source)]
    send_top_size = send_top_size[:len(dest)]
    recv_top_offsets = np.zeros(len(recv_top_size)+1, dtype=np.int32)
    np.cumsum(recv_top_size, out=recv_top_offsets[1:])
    numpy_to_mpi = {np.float64: MPI.DOUBLE,
                    np.float32: MPI.FLOAT, np.int8: MPI.INT8_T, np.int32: MPI.INT32_T}
    # Communicate data
    recv_geom = np.zeros(recv_geom_offsets[-1], dtype=mesh_small.geometry.x.dtype)
    s_geom_msg = [send_geom, send_geom_size, numpy_to_mpi[send_geom.dtype.type]]
    r_geom_msg = [recv_geom, recv_geom_size, numpy_to_mpi[recv_geom.dtype.type]]
    small_to_big_comm.Neighbor_alltoallv(s_geom_msg, r_geom_msg)
    recv_top = np.zeros(recv_top_offsets[-1], dtype=np.int32)
    s_top_msg = [send_top, send_top_size, numpy_to_mpi[send_top.dtype.type]]
    r_top_msg = [recv_top, recv_top_size, numpy_to_mpi[recv_top.dtype.type]]
    small_to_big_comm.Neighbor_alltoallv(s_top_msg, r_top_msg)
    # For each received geometry, create a mesh
    local_meshes = []
    for i in range(len(source)):
        local_meshes.append(mesh.create_mesh(
            MPI.COMM_SELF,
            cells=recv_top[recv_top_offsets[i]:recv_top_offsets[i+1]].reshape(-1, num_vertices_per_cell_small),
            x=recv_geom[recv_geom_offsets[i]:recv_geom_offsets[i+1]].reshape(-1, mesh_small.geometry.dim),
            e=ufl.Mesh(mesh_small.ufl_domain().ufl_coordinate_element())))
    # For each local mesh, compute the bounding box, compute colliding cells
    tol = 1e-13
    big_cells = []
    local_cells = []
    num_local_cells = np.zeros(max(len(source), 1), dtype=np.int32)
        local_cells_i = set()
        o_cell_idx = local_meshes[i].topology.original_cell_index
        local_tree = geometry.bb_tree(
            local_meshes[i], local_meshes[i].topology.dim)
        cell_cell_collisions = geometry.compute_collisions_trees(
            local_tree, bb_tree)
        for local_cell, big_cell in cell_cell_collisions:
            geom_small = extract_cell_geometry(local_meshes[i], local_cell)
                local_cells_i = local_cells_i.union([o_cell_idx[local_cell]])
        num_local_cells[i] = len(local_cells_i)
        local_cells.append(np.asarray(list(local_cells_i), dtype=np.int32))
    # Create reverse communicator
    big_to_small_comm = mesh_small.comm.Create_dist_graph_adjacent(
        dest, source, reorder=False
    # Send incoming cell sizes
    recv_cell_sizes = np.zeros(max(len(dest), 1), dtype=np.int32)
    big_to_small_comm.Neighbor_alltoall(num_local_cells, recv_cell_sizes)
    recv_cell_sizes = recv_cell_sizes[:len(dest)]
    num_local_cells = num_local_cells[:len(source)]
    recv_cell_offsets = np.zeros(len(recv_cell_sizes)+1, dtype=np.int32)
    np.cumsum(recv_cell_sizes, out=recv_cell_offsets[1:])
    recv_cells = np.zeros(recv_cell_offsets[-1], np.int32)
    if len(source) == 0:
        send_cells = np.array([], dtype=np.int32)
        send_cells = np.hstack(local_cells).astype(np.int32).reshape(-1)
    s_cell_msg = [send_cells, num_local_cells, numpy_to_mpi[send_cells.dtype.type]]
    r_cell_msg = [recv_cells, recv_cell_sizes, numpy_to_mpi[recv_cells.dtype.type]]
    big_to_small_comm.Neighbor_alltoallv(s_cell_msg, r_cell_msg)
    small_mesh_colliding_cells = []
        local_cells = sending_cells[process_offsets[i]:process_offsets[i+1]]
        recv_data = recv_cells[recv_cell_offsets[i]:recv_cell_offsets[i+1]]
        small_mesh_colliding_cells.append(local_cells[recv_data])
    if len(small_mesh_colliding_cells) == 0:
        small_mesh_colliding_cells = np.array([], dtype=np.int32)
        small_mesh_colliding_cells = np.hstack(small_mesh_colliding_cells)
    sorted_unique_small_cells = np.unique(
        small_mesh_colliding_cells).astype(dtype=np.int32)
    colliding_small_marker = mark_cells(mesh_small, sorted_unique_small_cells)
    colliding_small_marker.name = "colliding cells small"
    sorted_unique_big_cells = np.unique(big_cells).astype(dtype=np.int32)
    colliding_big_marker = mark_cells(mesh_big, sorted_unique_big_cells)
    colliding_big_marker.name = "colliding cells"
    return colliding_big_marker, colliding_small_marker
