f = \frac{K_1}{2}[\frac{\partial\phi}{\partial x}]^2 + \frac{K_2}{2}[\frac{\partial\phi}{\partial z}+q_0]^2
Now I have a functional which is the total energy given by:
F = \displaystyle \int_{0 }^{L} \int_{0 }^{\Lambda}f dx dz
Now I want to find the stationary point
\delta F = 0
The boundary conditions are given as
\phi(x,0) = \frac{\pi x}{\Lambda}
\phi(x,L) = \frac{(2u+1)\pi}{2}
given that u is an integer.
q_0 and L and \Lambda are constants.
I am using finite element analysis to solve for \phi computationally
from mpl_toolkits.mplot3d import Axes3D
pi =3.141
Step 1: Define the Problem (Geometry and Material Parameters)
L_k = 14e-6 # Length of the domain in the y direction
d = 14e-6 # Length of the domain in the x direction
lam = 60e-6
K1 = Constant(7.49e-12) # Splay elastic constant
K2 = Constant(3.81e-12) # Twist elastic constant
q0 = Constant(0)
dim_x = 64
dim_y = 64
# Step 2: Define Function Space
mesh = RectangleMesh(Point(0, 0), Point(d, L_k),dim_x-1,dim_y-1) # Define the rectangular mesh
V = FunctionSpace(mesh, "CG", 1) # Vector function space for the director field
# Define the trial and test functions
phi = TrialFunction(V)
# Boundary condition at y=0 (linear with respect to x)
bx0 = Expression("pi*x[0]/lam", degree=1,lam=lam,pi=pi)
bc_0 = DirichletBC(V, bx0, "near(x[1], 0)")
#Step 7 : Apply Boundary Conditions
# Boundary condition at y=L (takes only odd multiples of pi/2)
u_k = Constant(0)
theta_L = Expression("pi/2*(2*u_k+1)", pi=pi,u_k=u_k, degree=1)
bc_L = DirichletBC(V, theta_L, "near(x[1], 14e-6)")
bcs= [bc_0,bc_L]
L = (K1 / 2) * (grad(phi)[0] ** 2) + (K2 / 2) * (grad(phi)[1] + q0) ** 2
F = L * dx
F_var = derivative(F, phi,v)
problem = NonLinearVariationalProblem(F_var, phi, bcs)
solver = NonLinearVariationalSolver(problem)
solver.solve()
But unfortunately I get an error message like this
Invalid coefficient type for
File ~/opt/anaconda3/envs/fenicsproject/lib/python3.11/site-packages/spyder_kernels/py3compat.py:356 in compat_exec
exec(code, globals, locals)
File ~/Desktop/LIQUID CRYSTALS/codebase/weak_euler_lagrangian.py:54
File ~/opt/anaconda3/envs/fenicsproject/lib/python3.11/site-packages/dolfin/fem/formmanipulations.py:82 in derivative
return ufl.derivative(form, u, du, coefficient_derivatives)
File ~/opt/anaconda3/envs/fenicsproject/lib/python3.11/site-packages/ufl/formoperators.py:280 in derivative
coefficients, arguments = _handle_derivative_arguments(form, coefficient,
File ~/opt/anaconda3/envs/fenicsproject/lib/python3.11/site-packages/ufl/formoperators.py:230 in _handle_derivative_arguments
error("Invalid coefficient type for %s" % ufl_err_str(c))
File ~/opt/anaconda3/envs/fenicsproject/lib/python3.11/site-packages/ufl/log.py:172 in error
UFLException: Invalid coefficient type for
Please can someone help understand the issue with the code?
Thank you and if there is something wrong with the mathematics please correct me on that aspect as well.
