Fixing dofs normal to direction vector used in traction boundary condition for linear elasticity
I would like to partially fix the dofs where a traction force is applied on a circle on the surface of a body. Right now the way I am applying the traction is the following:
# Traction direction: push along +x (change sign if needed)
T = fem.Constant(domain, -p_traction * default_scalar_type((node_normal[0], node_normal[1], node_normal[2])))
a = ufl.inner(sigma(u, lambda_, mu), epsilon(v)) * ufl.dx
L = ufl.dot(f_vec, v) * ufl.dx + ufl.dot(T, v) * ds(2)
Is there a way of enforcing zero displacement normal to the node_normal vector for the nodes where the traction is applied?
Running code and a vtk mesh can be found in another post:
Thank you,
Alex
As you are using Lagrange elements, you can’t enforce this through a normal dirichlet condition if your normals do not align with the cartesian grid. You can however use DOLFINx MPC for it, as shown in: Stokes flow with slip conditions — DOLFINx-MPC: An extension to DOLFINx for multi point constraints in the setting of Stokes equation.
You could alternatively try to enforce it weakly with Nitsche’s method.
Thank you for the prompt reply. Could you give me an example of how to do it for a coordinate direction for the current code?
Do you have a post reference discussing how Nitsche’s method is applied to a similar problem in Fenicsx?
Thank you
Then you can take the DirichletBC in the appropriate sub space. For instance, if you want the component in the ith direction to be 0, you set a bc on V.sub(i).
In Mixed finite element problems — FEniCS Workshop there is a fairly comprehensive explaination.
Nitsche methods is for instance covered in: Weak imposition of Dirichlet conditions for the Poisson problem — FEniCSx tutorial
and asimov-contact/python/dolfinx_contact/one_sided/nitsche_ufl.py at main · Wells-Group/asimov-contact · GitHub goes through linear elasticity with nitsche/contact conditions, I.e. dot(u,n)-g=0
Thank you for the reply. I added this at the end of the build_primal_problem() function:
# Dirichlet BC to stop deflection normal to x (lock_num == 1) or y (lock_num == 2) axis
if lock_num == 1:
    right_facets = facet_tags.find(2)
    right_dofs   = fem.locate_dofs_topological(V, fdim, right_facets)
    bc_1 = fem.dirichletbc(0.0, right_dofs, V.sub(1))
    bc_2 = fem.dirichletbc(0.0, right_dofs, V.sub(2))
    return V, a, L, [bc_left, bc_1, bc_2]
if lock_num == 2:
    bc_1 = fem.dirichletbc(0.0, right_dofs, V.sub(0))
return V, a, L, [bc_left]
Is this correct? From the output displacements it seems to be working
No, to be completely safe here, you should use:
if lock_num == 1:
    right_dofs1   = fem.locate_dofs_topological(V.sub(1), fdim, right_facets)
    bc_1 = fem.dirichletbc(0.0, right_dofs1, V.sub(1))
    right_dofs2   = fem.locate_dofs_topological(V.sub(2), fdim, right_facets)
    bc_2 = fem.dirichletbc(0.0, right_dofs2, V.sub(2))
if lock_num == 2:
    right_dofs0   = fem.locate_dofs_topological(V.sub(0), fdim, right_facets)
    bc_1 = fem.dirichletbc(0.0, right_dofs0, V.sub(0))
That works thank you! The previous case was deflecting less but it was still moving upwards.
