Dear all,
I am trying to solve a stationary density u(\vec x) for a Fokker-Planck equation of the form
where \vec x is on the surface of the sphere. \vec a(\vec x)\in\mathbb{R}^3 and g(\vec x) is a
3\times 2 matrix which determines the diffusion matrix for the process as B=gg^T. Problem has Neumann boundary conditions.
Let \Omega be the surface of a unit sphere in \mathbb{R}^3.
I can state the problem in the variational form as
where b_i = a_i -\frac{1}{2}\sum_{j=1}^3\sum_{k=1}^2 g_{ik}(\partial_j g_{jk}).
My problem is that the implementation below returns the “trivial” solution u=C, where
C is some constant, which I can check not to be a stationary state for the original problem.
Below is a minimal working example
import mshr as mshr
if __name__ == "__main__":
#Create mesh and define function space
domain = mshr.Sphere(Point(0, 0,0), 1)
mesh = mshr.generate_mesh(domain, 20)
V = FunctionSpace(mesh, 'P', 2)
# Set model parameters
Omega = 2.0
#drift vector
drift_vector = Expression(('-6*x[0]*pow(x[2],2)','-6*x[1]*pow(x[2],2)-x[2]*O','6*x[2]-6*pow(x[2],3)+x[1]*O'), O=Omega,degree = 1)
#diffusion matrix
diffusion_matrix = Expression((('pow(x[1],2)+pow(x[0],2)*pow(x[2],2)','x[0]*x[1]*(pow(x[2],2)-1)','x[0]*x[2]*(pow(x[2],2)-1)'),
('x[0]*x[1]*(pow(x[2],2)-1)','pow(x[0],2)+pow(x[1],2)*pow(x[2],2)','x[1]*x[2]*(pow(x[2],2)-1)'),
('x[0]*x[2]*(pow(x[2],2)-1)','x[1]*x[2]*(pow(x[2],2)-1)','pow(pow(x[2],2)-1,2)')),degree=1)
#variational form
F = u*dot(drift_vector,grad(v))*dx +dot(grad(v),dot(diffusion_matrix,grad(u)))*dx
a, L = lhs(F), rhs(F)
#solution
solve(a==L, u)#J=J)
#plot the solution
plot(u)
Any hints and help would be greatly appreciated.
Best,
Kimmo
