Hi! I’m trying to solve the (Navier-)Stokes equations using Chorin’s method. Stokes already works just fine, but when I try to solve the nonlinear Navier-Stokes equation, I get an error message of the type
TypeError: ‘bool’ object is not iterable
I tried to cut out unnecessary code to make it more readable, but let me know if you need the rest!
from dolfin import * import mshr import sys import matplotlib.pyplot as plt
#Define function spaces V_el = VectorElement('P', triangle, 2) P_el = FiniteElement('P', triangle, 1) W = FunctionSpace(mesh, V_el * P_el) V = W.sub(0).collapse() Q = W.sub(1).collapse() #Inflow profile inflow_profile = ('1.0','0.0') #Boundary conditions bcu_inflow = DirichletBC(V, Expression(inflow_profile, degree=2), inflow) bcu_walls = DirichletBC(V, Constant((0, 0)), walls) bcu_cylinder = DirichletBC(V, Constant((0, 0)), cylinder) bcu = [bcu_inflow, bcu_walls, bcu_cylinder] #Viscosity nu = 0.1
#1: Stokes #2: Navier-Stokes equation_type = 2 pressure_eq = inner(grad(p),grad(q))*dx == -1/dt*div(u_tmp)*q*dx vel_update_eq = inner(u,v)*dx == inner(u_tmp,v)*dx - dt*dot(grad(p0),v)*dx timestep = 1 #Chorin iteration for timestep in range(1, num_timesteps+1): t = timestep * dt_val begin('Timestep {} / {} (t = {})'.format(timestep, num_timesteps, t)) if equation_type == 1: #Stokes **<- works fine** solve(inner(u,v)*dx + dt*inner(nu*grad(u),grad(v))*dx == inner(u0, v) * dx,u_tmp,bcu) else: #Navier-Stokes **<-throws error message** solve(inner(u,v)*dx + dt*inner(dot(u,nabla_grad(u)),v)*dx + dt*inner(nu*grad(u),grad(v))*dx - inner(u0, v) * dx == 0,u_tmp,bcu) solve(pressure_eq,p0,DirichletBC(Q, Constant(0), 'near(x[0],2.2)')) solve(vel_update_eq,u0) #pressure with mean 0 p0.vector()[:] = p0.vector() - assemble(p0*dx) end()
I’ve googled and tried several versions to write (u \cdot grad(u)) v, but everything so far has thrown error messages on dolfin 2019.1.0. What is the right way to do it?
Thank you!
