Hi all, I am trying to solve the following problem
\nabla^2 u + (\alpha - \beta dot(u,u)) u = 0
where u is a 2d vector in 2d space and alpha and beta are two real constants. Following examples I tried the following as LHS
(inner(grad(u), grad(v)) + (alpha-beta*inner(u,u))*inner(u,v))*dx
but I get an error 'bool' object is not iterable
which goes away when I remove the \beta
term. Can anyone point out what’s wrong here?
MiroK
2
Hi, please share the minimal code that reproduces the error.
Here it is.
plt.rcParams.update({'figure.dpi':256})
mesh = UnitSquareMesh(32, 32)
uD = Expression(('-sin(atan2(x[1]-y0,x[0]-x0))','cos(atan2(x[1]-y0,x[0]-x0))'), degree=2, x0=0.5,y0=0.5)
def boundary(x, on_boundary):
return on_boundary
bc = DirichletBC(V, uD, boundary)
alpha = Constant(1.0)
beta = Constant(1.0)
LHS = (inner(grad(u), grad(v)) + (alpha-beta*dot(u,u))*inner(u,v))*dx
#LHS = inner(grad(u), grad(v))*dx
f = Constant((0,0))
RHS = dot(f,v)*dx
# Compute solution
solve(LHS == RHS, u, bc)
plot(u)
nate
4
Your underlying equations are nonlinear, you need to solve a nonlinear finite element problem. Cf. here.
return on_boundary
f = Constant((0,0))
RHS = dot(f,v)*dx
# Compute solution
F = LHS - RHS
solve(F == 0, u, bc)
plot(u)
