Hello everyone, i need help with an error i encountered in a project where I am applying finite element method and topology optimization. Firstly, I exported a file in STEP format to MSH format using the GMSH application. Then, I converted this file to XDMF format. I apply the finite element method to the model first, followed by topology optimization. However, I am encountering an error. I am sharing my code and the error message with you, and I would appreciate any help you can provide.
Here my .msh file GitHub - ctaskum/-ekiller
msh = meshio.read(filename="/home/zeynep/FEM/square2.msh")
for cell in msh.cells:
if cell.type == "triangle":
triangle_cells = cell.data
for key in msh.cell_data_dict["gmsh:geometrical"].keys():
if key == "triangle":
triangle_data = msh.cell_data_dict["gmsh:geometrical"][key]
triangle_mesh = meshio.Mesh(points=msh.points,
cell_data={"name_to_read": [triangle_data]})
# XDMF
mesh = Mesh()
xdmf_file = XDMFFile("mf.xdmf")
xdmf_file.read(mesh)
plot(mesh)
# Algorithmic parameters
niternp = 20
niter = 80
pmax = 4
exponent_update_frequency = 4
tol_mass = 1e-4
thetamin = 0.001
# Problem parameters
thetamoy = 0.4
E = Constant(1)
nu = Constant(0.3)
lamda = E*nu/(1+nu)/(1-2*nu)
mu = E/(2*(1+nu))
f = Constant((0, -1, 0))
def left(x, on_boundary):
return near(x[0], -400) and on_boundary
def load(x, on_boundary):
return near(x[0], 650) and near(x[1], 150, 50)
# Facets
facets = MeshFunction("size_t", mesh, 1)
AutoSubDomain(load).mark(facets, 1)
ds = Measure("ds", subdomain_data=facets)
# Function space for density field
V0 = FunctionSpace(mesh, "DG", 0)
# Function space for displacement
V2 = VectorFunctionSpace(mesh, "CG", 3)
# Fixed boundary condtions
bc = DirichletBC(V2, Constant((0, 0, 0)), left)
p = Constant(1) # SIMP penalty exponent
exponent_counter = 0 # exponent update counter
lagrange = Constant(1) # Lagrange multiplier for volume constraint
thetaold = Function(V0, name="Density")
thetaold.interpolate(Constant(thetamoy))
coeff = thetaold**p
theta = Function(V0)
volume = assemble(Constant(1.)*dx(domain=mesh))
avg_density_0 = assemble(thetaold*dx)/volume # initial average density
avg_density = 0.
def eps(v):
return sym(grad(v))
def sigma(v):
return coeff*(lamda*div(v)*Identity(3)+2*mu*eps(v))
def energy_density(u, v):
return inner(sigma(u), eps(v))
# Inhomogeneous elastic variational problem
u_ = TestFunction(V2)
du = TrialFunction(V2)
a = inner(sigma(u_), eps(du))*dx
L = dot(f, u_)*ds(1)
def local_project(v, V):
dv = TrialFunction(V)
v_ = TestFunction(V)
a_proj = inner(dv, v_)*dx
b_proj = inner(v, v_)*dx
solver.factorize()
solver.solve_local_rhs(u)
return u
def update_theta():
theta.assign(local_project((p*coeff*energy_density(u, u)/lagrange)**(1/(p+1)), V0))
thetav = theta.vector().get_local()
theta.vector().set_local(np.maximum(np.minimum(1, thetav), thetamin))
theta.vector().apply("insert")
avg_density = assemble(theta*dx)/volume
return avg_density
def update_lagrange_multiplier(avg_density):
avg_density1 = avg_density
# Initial bracketing of Lagrange multiplier
if (avg_density1 < avg_density_0):
lagmin = float(lagrange)
while (avg_density < avg_density_0):
lagrange.assign(Constant(lagrange/2))
avg_density = update_theta()
lagmax = float(lagrange)
elif (avg_density1 > avg_density_0):
while (avg_density > avg_density_0):
lagrange.assign(Constant(lagrange*2))
# Dichotomy on Lagrange multiplier
inddico=0
while ((abs(1.-avg_density/avg_density_0)) > tol_mass):
lagrange.assign(Constant((lagmax+lagmin)/2))
inddico += 1;
if (avg_density < avg_density_0):
print(" Dichotomy iterations:", inddico)
def update_exponent(exponent_counter):
exponent_counter += 1
if (i < niternp):
p.assign(Constant(1))
elif (i >= niternp):
if i == niternp:
print("\n Starting penalized iterations\n")
if ((abs(compliance-old_compliance) < 0.01*compliance_history[0]) and
(exponent_counter > exponent_update_frequency) ):
# average gray level
gray_level = assemble((theta-thetamin)*(1.-theta)*dx)*4/volume
p.assign(Constant(min(float(p)*(1+0.3**(1.+gray_level/2)), pmax)))
print(" Updated SIMP exponent p = ", float(p))
return exponent_counter
u = Function(V2, name="Displacement")
old_compliance = 1e30
ffile = XDMFFile("topology_optimization.xdmf")
ffile.parameters["flush_output"]=True
ffile.parameters["functions_share_mesh"]=True
compliance_history = []
for i in range(niter):
solve(a == L, u, bc, solver_parameters={"linear_solver": "cg", "preconditioner": "hypre_amg"})
ffile.write(thetaold, i)
ffile.write(u, i)
compliance = assemble(action(L, u))
compliance_history.append(compliance)
print("Iteration {}: compliance =".format(i), compliance)
exponent_counter = update_exponent(exponent_counter)
# Update theta field and compliance
thetaold.assign(theta)
old_compliance = compliance
plot(theta, cmap="bone_r")
plt.title("Final density")
plt.show();
plt.figure()
plt.plot(np.arange(1, niter+1), compliance_history)
ax = plt.gca()
ymax = ax.get_ylim()[1]
plt.plot([niternp, niternp], [0, ymax], "--k")
plt.annotate(r"$\leftarrow$ Penalized iterations $\rightarrow$", xy=[niternp+1, ymax*0.02], fontsize=14)
plt.xlabel("Number of iterations")
plt.ylabel("Compliance")
plt.title("Convergence history", fontsize=16)
plt.show();
zeynep@LAPTOP-3KN21JEE:~$ /usr/bin/env /bin/python3 /home/zeynep/.vscode-server/extensions/ms-python.debugpy-2024.14.0-linux-x64/bundled/libs/debugpy/adapter/../../debugpy/launcher 45387 -- /home/zeynep/FEM/fem1.py
Solving linear variational problem.
free(): invalid next size (normal)
[LAPTOP-3KN21JEE:37362] *** Process received signal ***
[LAPTOP-3KN21JEE:37362] Signal: Aborted (6)
[LAPTOP-3KN21JEE:37362] Signal code: (-6)
