Function evaluation tutorial fails on mac m3, fenicsx 0.9
On mac M3 running fenicsx 0.9 conda environment, I get the following error on running the function evaluation tutorial. I downloaded it as a python file expressions.py.
(fenicsx-0.9) (Mac: learn) 1097. python expressions.py
  File "/Users/deboyce/Research/fenicsX/run/learn/expressions.py", line 128, in <module>
    print(f"{potential_colliding_cells._cpp_object=}")
AttributeError: 'dolfinx.cpp.graph.AdjacencyList_int32' object has no attribute '_cpp_object'
For some strange reason (probably limited amount of spare time), I never made a 0.9 release of the fenics-workshop notes.
There are a few minor things to change in that code to make it work on 0.9.
Change to the following:
print(f"{potential_colliding_cells=}")
print(f"{colliding_cells=}")
grad_expr = dolfinx.fem.Expression(grad_q, P.element.interpolation_points())
coordinates = facet_x.eval(mesh, cell_facet_pairs.flatten())
flux_values = heat_flux_expr.eval(mesh, cell_facet_pairs.flatten()
Thanks. That works now.
And for reference, I got what I needed. I was trying to compute integrals of the differences of two solutions on different meshes. It seems to be working now. It was straightforward enough: from a fenicsx function on one mesh, create a python function for interpolation, then use that on any other mesh.
You can also use interpolate_nonmatching;
https://docs.fenicsproject.org/dolfinx/v0.9.0/python/generated/dolfinx.fem.html#dolfinx.fem.Function.interpolate_nonmatching
which is quicker and works in parallel.
See for instance
and subsequent lines
Thanks a lot. That’s perfect.
