Hi everyone,
I’m new to FEniCSx, so I’m trying to reproduce some of the examples in the tutorial. I’m now with the membrane deflection case, but I’m not able to interpolate the ufl expression as I get the following error:
AttributeError Traceback (most recent call last)
Input In [7], in <cell line: 3>()
1 # we interpolate p into the function space for visualization
2 Q = fem.FunctionSpace(domain, ("CG", 5))
----> 3 expr = fem.Expression(p, Q.element.interpolation_points)
4 pressure = fem.Function(Q)
5 pressure.interpolate(expr)
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/function.py:98, in Expression.__init__(self, ufl_expression, X, form_compiler_params, jit_params, dtype)
68 def __init__(self, ufl_expression: ufl.core.expr.Expr, X: np.ndarray,
69 form_compiler_params: dict = {}, jit_params: dict = {},
70 dtype=PETSc.ScalarType):
71 """Create DOLFINx Expression.
72
73 Represents a mathematical expression evaluated at a pre-defined
95
96 """
---> 98 assert X.ndim < 3
99 num_points = X.shape[0] if X.ndim == 2 else 1
100 _X = np.reshape(X, (num_points, -1))
AttributeError: 'builtin_function_or_method' object has no attribute 'ndim'
The code I’m using is
membrane = gmsh.model.occ.addDisk(0, 0, 0, 1, 1)
gmsh.model.occ.synchronize()
gdim = 2
gmsh.model.addPhysicalGroup(gdim, [membrane], 1)
gmsh.option.setNumber("Mesh.CharacteristicLengthMin",0.05)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax",0.05)
from dolfinx.io import gmshio
gmsh_model_rank = 0
mesh_comm = MPI.COMM_WORLD
domain, cell_markers, facet_markers = gmshio.model_to_mesh(gmsh.model, mesh_comm, gmsh_model_rank, gdim=gdim)
from dolfinx import fem
# spatially varying load (previously f)
beta = fem.Constant(domain, ScalarType(12))
R0 = fem.Constant(domain, ScalarType(0.3))
p = 4 * ufl.exp(-beta**2 * (x[0]**2 + (x[1] - R0)**2))
def on_boundary(x):
return np.isclose(np.sqrt(x[0]**2 + x[1]**2), 1)
boundary_dofs = fem.locate_dofs_geometrical(V, on_boundary)
bc = fem.dirichletbc(ScalarType(0), boundary_dofs, V) # u=0 in the whole boundary
# like before, but with p instead of f
u = ufl.TrialFunction(V)
a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = p * v * ufl.dx
problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
I installed FEniCSx from Docker yesterday, so I guess I have the latest version. Is maybe the tutorial outdated? Thanks!
