Gather Function in parallel error
Hi everyone,
I’m trying to gather a function in parallel, but the vector doesn’t get updated. Any tips would be appreciated, here is a MWE:
mesh = UnitIntervalMesh(5)
V    = FunctionSpace(mesh, 'CG', 1)
v = Vector()
v.init(V.dim())
u.vector()[:] = 1
u.vector().gather(v)
print("Original vs copied: ", u.vector().get_local(), v.get_local())  # [1, 1], [0, 0, 0]
Hi, consider
u_vec = u.vector()
u_vec[:] = MPI.comm_world.rank + 1
v_vec = Vector(MPI.comm_self, u_vec.local_size())
u_vec.gather(v_vec, V.dofmap().dofs())
print("Original vs copied: ", u_vec.get_local(), v_vec.get_local())  # [1, 1], [0, 0, 0]
Thank you MiroK, this solves the question posed. If I may, I wanted this to work to share the entire function phi along my processors, i.e the 5 entries of the vector on each process. Is it possible to use gather for this? I have seen scripts but they are from the old forums and they don’t seem to work anymore.
Getting the coefficient vector of the function to all the CPUs is shown in the following
f = Expression('x[0]', degree=1)
u = interpolate(f, V)
u_vec = u.vector()
g_vec = Vector(MPI.comm_world, V.dim())
# Values from everywhere on 0
g_vec = u_vec.gather_on_zero()
# To everywhere from 0
mine = MPI.comm_world.bcast(g_vec)
# Reconstruct
if MPI.comm_world.rank == 0:
    my_g = g_vec
    my_g = Vector(MPI.comm_self, V.dim())
    my_g.set_local(mine)
I suppose you want next to rebuild from the coefficient vector the function locally on each CPU, so that something like this would return 0
mesh = UnitIntervalMesh(MPI.comm_self, 5)
fh = Function(V, my_g)
a = inner(f-fh, f-fh)*dx
print(assemble(a))
Is that the case? Perhaps post the link to the old forum.
Thank you very much MiroK, this is crystal clear and exactly what I needed.
