I am using FenicsX vs 0.7.3 to solve a simple non-linear PDE consistenting of two distinct fields on the same domain in 1D.
In serial (i.e. mpirun -n 1) everything works fine. However, when I attempt to run it in parallel I am having issues gathering all the data on one process in order to write it to a file etc.
Where msh=create_interval(...) and u=Function(V), and V=functionspace(...) (see below for minimal example), the issues are:
I know how to get the number of dofs in
uusingnum_dofs_local = V.dofmap.index_map.size_local * V.dofmap.index_map_bs. But when collecting the data I want to know how many points are on the mesh (should be the same for each field). Currently I am usingnum_points_local = int(np.ceil(num_dofs_local/2)). Is there a better way? -
gathering the two fields independently using
msh.comm.gather(u.sub(0).x.array[:num_points_local])returns incorrect data - that is it returns a mix of data points from bothu.sub(0)andu.sub(1). This is illustrated in first set of output below where it should have sequential positive numbers foru.sub(0)and sequential negative numbers foru.sub(1). I know this lacks thecollapse()call (see point 3), but this does run in mpirun with n > 1, so I use it as a reference. -
If I instead use (what I believe to be the correct form)
msh.comm.gather(u.sub(0).collapse().x.array[:num_points_local])then I get the expected result formpirun -n 1only. If rI run more than one process then the code hangs at this line.
What am I doing wrong?
The minimal code to create my issue is below:
from dolfinx.fem import Function, functionspace
from dolfinx.mesh import create_interval
from basix.ufl import (element, mixed_element)
import sys
comm = MPI.COMM_WORLD
def printf(s):
print(f"Rank {comm.rank}: {s}")
sys.stdout.flush()
###### FUNCTION SPACE ######
L = 10
mesh_size = 10
x_left = 0.0
x_right = L
msh = create_interval(comm, points=(x_left, x_right), nx=mesh_size, ghost_mode=dolfinx.cpp.mesh.GhostMode.shared_facet)
P1 = element("Lagrange", msh.basix_cell(),1)
V = functionspace(msh, mixed_element([P1, P1]))
u = Function(V) # current solution
u_prev = Function(V)
###### INITIAL CONDITIONS ######
# designed to be increasing positive values for u.sub(0) and decreasing negative values for u.sub(1)
class InitialTestState():
def __init__(self):
return
def f0(self,x):
values = np.zeros((1, x.shape[1]))
for i,v in enumerate(x[0]):
values[0][i] = v
return values
def f1(self,x):
values[0][i] = -v
return values
initial_condition = InitialTestState()
u.sub(0).interpolate(initial_condition.f0)
u.sub(1).interpolate(initial_condition.f1)
u.x.scatter_forward()
###### GATHER DATA ##########
num_points_local = int(np.ceil(num_dofs_local/2)) ## <----- better way?
global_vals0 = msh.comm.gather(u.sub(0).collapse().x.array[:num_points_local])
global_vals1 = msh.comm.gather(u.sub(1).collapse().x.array[:num_points_local])
global_x = msh.comm.gather(msh.geometry.x[:num_points_local,0])
if comm.rank == 0:
print("\nUnexpected result, but runs for all n \n\n")
# gives wrong data: should be 0,1,2,3, and 0,-1,-2,-3,-4 or similar
print("Local values:")
printf(u.sub(0).x.array[:num_points_local])
printf(u.sub(1).x.array[:num_points_local])
print("Collected values:")
root_vals0 = np.concatenate(global_vals0)
printf(root_vals0)
root_vals1 = np.concatenate(global_vals1)
printf(root_vals1)
print("\n\nExpected result: only works for n=1 \n\n")
# gives correct data but hangs for n> 1 in mpirun -n $n minimal_example.py
printf(u.sub(0).collapse().x.array[:num_points_local])
printf(u.sub(1).collapse().x.array[:num_points_local])
printf(root_vals0)
printf(root_vals1)
Thanks,
R.
