Generate UnitIntervalMesh dolfin-legacy
I am not able to generate interval mesh in dolfin-legacy. However, I found this command was working previously and can be seen in previous posts. The dolfin-version is: 2019.2.0.dev0 (obtained from terminal).
mesh = UnitIntervalMesh(4)
mesh
The error is
File ~/.local/lib/python3.10/site-packages/IPython/core/formatters.py:344, in BaseFormatter.__call__(self, obj)
    342     method = get_real_method(obj, self.print_method)
    343     if method is not None:
--> 344         return method()
    345     return None
    346 else:
File /usr/lib/petsc/lib/python3/dist-packages/dolfin/mesh/__init__.py:40, in _repr_html_(self)
     39 def _repr_html_(self):
---> 40     return cpp.io.X3DOM.html(self)
RuntimeError:
That’s a new one, I think we have never seen this error before in this forum.
Close your notebook, try using the system wide ipython installation, i.e. do a mv ~/.local/lib/python3.10 ~/.local/lib/python3.10.bak, and start the notebook again.
The full error message contains useful info
***     https://fenicsproject.discourse.group/
*** Error:   Unable to get X3DOM string representation of a mesh.
*** Reason:  X3D works only for 2D and 3D meshes.
*** Where:   This error was encountered inside X3DOM.cpp.
*** Process: 0
*** Git changeset:  982f37614ec24299add4e09024d7d5f985474a91
Note that the error only happens when you end the cell with the word mesh, i.e. you try to represent it in the notebook. Mesh generation itself works. If you really want to represent the mesh, you can use repr(mesh), but I can’t see why the info you get from there would be relevant.
Thanks @francesco-ballarin. repr(mesh)/ plot(mesh) is showing the 1D mesh.
Noted point: the mesh was generated previously, but, with typing only mesh to work was my error.
