AttributeError: module 'dolfinx' has no attribute 'IntervalMesh'
Hi all!
I’m trying to run the following script but I get this error:
File /home/miniconda3/envs/fenicsx-env/lib/python3.11/site-packages/spyder_kernels/py3compat.py:356 in compat_exec
exec(code, globals, locals)
File /home/fenicsx/wiremodel/tests/wmB_v1.py:223
mesh, V, order = create_mesh()
File /home/fenicsx/wiremodel/tests/wmB_v1.py:39 in create_mesh
mesh = dolfinx.IntervalMesh(MPI.COMM_WORLD, n_ele, [start_x, end_x])
AttributeError: module ‘dolfinx’ has no attribute ‘IntervalMesh’
I’m new to fenicsx and dolfinx, and I’m having a lot of trouble getting started on this. Any help would be nice, thanks!
My python script:
import os.path
import sys
import dolfinx.fem.petsc
# FENICS/DOLFIN validation of free-free beam vibration
#from dolfinx.io import XDMFFile
import scipy.sparse
import scipy.linalg
from slepc4py import SLEPc
from celluloid import Camera
# beam properties
n_ele = 50
start_x = 0.0
end_x = 1.0
E = 1e6
nu = 0.3
G = E / (2*(1 + nu))
I = 2e-9
kappa = 1
A = 0.0002
rho = 1.0
# 1D mesh and its function space
def create_mesh():
    P2 = ufl.FiniteElement("CG", "interval", 2)
    P1 = ufl.FiniteElement("CG", "interval", 1)
    ME = ufl.MixedElement([P2, P1])
    V = dolfinx.FunctionSpace(mesh, ME)
    nodes = mesh.geometry.x[:, 0]
    order = np.argsort(nodes)
    return mesh, V, order
def create_matrices(V, lumped = False):
    def chi(Phi):
        return Phi.dx(0)
    def gamma(w, Phi):
        return (w.dx(0) - Phi)
    def M(Phi):
        return E * I * chi(Phi)
    def Q(w, Phi):
        return kappa * G * A * gamma(w,Phi)
    u = ufl.TrialFunction(V)
    (w, phi) = ufl.split(u)
    (w_ , phi_) = ufl.split(v)
    # Timoshenko stiffness
    stiffness_form = (ufl.inner(M(phi), chi(phi_)) + ufl.inner(Q(w, phi), gamma(w_, phi_))) * ufl.dx
    KM = dolfinx.fem.assemble_matrix(stiffness_form)
    KM.assemble()
    # consistent mass matrix
    mass_form = rho * (A * ufl.dot(w, w_) + I * ufl.dot(phi, phi_)) * ufl.dx
    MM = dolfinx.fem.assemble_matrix(mass_form)
    MM.assemble()
    # make lumped mass matrix
    if lumped:
        UU = dolfinx.Function(V)
        unity = UU.vector.copy()
        unity.set(1.0)
        lm = MM*unity
        MM.zeroEntries()
        MM.setDiagonal(lm)
    return KM, MM
def solve_eigenmodes(KM, MM, dims = 5, target_freq = 0.0, print_status = True):
    pc = PETSc.PC().create(MPI.COMM_WORLD)
    pc.setType(pc.Type.CHOLESKY)
    ksp = PETSc.KSP().create(MPI.COMM_WORLD)
    ksp.setType(ksp.Type.PREONLY)
    ksp.setPC(pc)
    #ksp.setTolerances(rtol=1E-9)
    st = SLEPc.ST().create(MPI.COMM_WORLD)
    st.setType(st.Type.SINVERT)
    st.setKSP(ksp)
    solver = SLEPc.EPS().create(MPI.COMM_WORLD)
    solver.setST(st)
    solver.setOperators(KM, MM)
    solver.setType(solver.Type.KRYLOVSCHUR)
    solver.setDimensions(dims)
    solver.setTolerances(1e-5, 1000)
    solver.setWhichEigenpairs(solver.Which.TARGET_REAL)
    solver.setTarget(target_freq)
    solver.setProblemType(SLEPc.EPS.ProblemType.GHEP)
    solver.setFromOptions()
    solver.solve()
    if print_status:
        its = solver.getIterationNumber()
        sol_type = solver.getType()
        nev, ncv, mpd = solver.getDimensions()
        tol, maxit = solver.getTolerances()
        nconv = solver.getConverged()
        print("")
        print("Number of iterations of the method: %i" % its)
        print("Solution method: %s" % sol_type)
        print("Number of requested eigenvalues: %i" % nev)
        print("Stopping condition: tol=%.4g, maxit=%d" % (tol, maxit))
        print("Number of converged eigenpairs: %d" % nconv)
    return solver
def extract_modes(results, V, N = 3, min_freq = 0.01, max_error = 1e-4):
    vr, vi = KM.getVecs()
    freqs = []
    modes = []
    for i in range(results.getConverged()):
        k = results.getEigenpair(i, vr, vi)
        error = results.computeError(i)
        if len(freqs) < N and not np.isnan(k.real) and k.real > min_freq and error < max_error:
            m = dolfinx.Function(V)
            m.vector.array[:] = PETSc.Vec.getArray(vr)
            modes.append(m)
            freqs.append(np.sqrt(k.real))
    return freqs, modes
def invert_stiffness(K):
    ai, aj, av = K.getValuesCSR()
    K_np = scipy.sparse.csr_matrix((av, aj, ai)).todense()
    return scipy.linalg.inv(K_np, overwrite_a=False, check_finite=True)
def calc_modal_thing(modes, what, V):
    out = []
    tmp = dolfinx.Function(V)
    for m in modes:
        what.mult(m.vector, tmp.vector)
        #result = np.dot(m.sub(0).vector.array[order], )
        out.append(m.vector.dot(tmp.vector))
    return out
def postprocess(mesh, V, order, KM, results, min_freq = 0.01, max_error = 1e-4):
    eigenmode = dolfinx.Function(V)
    n_okay = 0
    print("")
    print("        k          ||Ax-kx||/||kx|| ")
    print("----------------- ------------------")
        if not np.isnan(k.real) and k.real > min_freq and error < max_error:
            n_okay += 1
            print(" %12f       %12g" % (np.sqrt(k.real) / (2*np.pi), error)) # rad/s to Hz
            if n_okay <= 4:
                eigenmode.vector.array[:] = PETSc.Vec.getArray(vr)
                eigenmode.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
                result = eigenmode.sub(0).compute_point_values()
                plt.plot(mesh.geometry.x[order, 0], result[order] / np.max(np.abs(result[order])))
    print("")
    plt.legend(["2-node", "3-node", "4-node", "5-node"])
# Newmark-Beta integrator (gamma = 0.5, beta = 1/6 are coefs for linear acceleration)
def update_eta_newmark(dt, dis, vel, acc, wn, zeta, F, Fprev, gamma = 0.5, beta = 1.0/6.0):
    a1 = 1 / (beta * np.power(dt, 2)) + (gamma * 2 * zeta * wn) / (beta * dt)
    a2 = 1 / (beta * dt) + (gamma / beta - 1) * (2 * zeta * wn)
    a3 = (1 / (2 * beta) - 1) + dt * 2 * zeta * wn * (gamma / (2 * beta) - 1)
    new_disp = (F + a1 * dis + a2 * vel + a3 * acc) / (np.power(wn, 2) + a1)
    new_veloc = (gamma / (beta * dt)) * (new_disp - dis) + (1 - gamma / beta) * vel + dt * (1 - gamma / (2 * beta)) * acc
    new_accel = 1 / (beta * np.power(dt, 2)) * (new_disp - dis) - (1 / (beta * dt)) * vel - (1 / (2 * beta) - 1) * acc
    return new_disp, new_veloc, new_accel
# Complementary Function and Particular Integral (CF&PI) method
# "Fluid–Structure Interaction Using a Modal Approach", doi:10.1115/1.4004859
def update_eta_cfpi(dt, dis, vel, acc, wn, zeta, F, Fprev):
    #Fprev = F
    s = np.sqrt(1 - zeta**2)
    wts = wn * dt * s
    e = np.exp(-zeta * wn * dt)
    S, C = np.sin(wts), np.cos(wts)
    # complementary solution
    new_dis = dis * e * (C + zeta/s*S) + vel * e * 1/(wn*s)*S
    new_vel = vel * e * (C - zeta/s*S) - dis * e * wn/s*S
    # particular solution
    new_dis += \
        -e * Fprev * ((zeta*wn*dt + 2*zeta**2 - 1)/(wn**2*wts) * S + (wn*dt+2*zeta)/(wn**3*dt)*C) \
        + Fprev * 2*zeta/(wn**3 * dt) \
        + e * F * ((2*zeta**2 - 1)/(wn**2*wts) * S + (2*zeta)/(wn**3*dt)*C) \
        + F * (wn*dt - 2*zeta)/(wn**3*dt)
    new_vel += \
          e * Fprev * ((zeta + wn*dt)/(wn*wts) * S + 1/(wn**2*dt)*C) \
        - Fprev * 1/(wn**2 * dt) \
        - e * F * (zeta/(wn*wts) * S + 1/(wn**2*dt)*C) \
        + F * 1/(wn**2*dt)
    return new_dis, new_vel, acc
KM, MM = create_matrices(V)
results = solve_eigenmodes(KM, MM)
freqs, modes = extract_modes(results, V)
n_modes = len(freqs)
K_inv = invert_stiffness(KM)
modal_masses = calc_modal_thing(modes, MM, V)
modal_stiffness = calc_modal_thing(modes, KM, V)
# TODO allow damping as CM = a*MM + b*KM
#postprocess(mesh, V, order, KM, results)
def calc_force(t, mesh, order):
    F = dolfinx.Function(V)
    u,v = F.split()
    if t < 0.03:
        u.interpolate(lambda x: ((x[0] > 0.5) * (1 - (4*(x[0] - 0.8))**2)) * t/0.03 * 5e-2)
    return F
dt, t, i = 1e-2, 0.0, 0
dis, vel, acc, Fmodal = np.zeros(n_modes), np.zeros(n_modes), np.zeros(n_modes), np.zeros(n_modes)
ds, ts = [[] for i in range(n_modes)], []
fig = plt.figure()
camera = Camera(fig)
while t < 0.2:
    F = calc_force(t, mesh, order)
    yeah = dolfinx.Function(V)
    yeah.vector.array[:] = np.dot(K_inv, F.vector.array)
    for j in range(n_modes):
        wn = freqs[j]
        mode = modes[j]
        Fprev = Fmodal[j]
        Fmodal[j] = mode.vector.dot(F.vector)
        dis[j], vel[j], acc[j] = update_eta_cfpi(dt, dis[j], vel[j], acc[j], wn, 0.05, Fmodal[j], Fprev)
        ds[j].append(dis[j])
    if i % 20:
        result = np.zeros_like(F.sub(0).compute_point_values())
            result += modes[j].sub(0).compute_point_values() * dis[j]
        #plt.clf()
        #plt.ylim([-2, 2])
        #plt.plot(mesh.geometry.x[order, 0], result[order], c='black', lw=4)
        #plt.scatter(mesh.geometry.x[order, 0], result[order], s=1e4*np.absolute(F.sub(0).compute_point_values()[order]), color='red')
        #plt.draw()
        #plt.pause(0.001)
        #camera.snap()
    ts.append(t)
    i += 1
#plt.show()
#animation = camera.animate(interval = 30)
#animation.save('/home/josip/Temp/beam_01.mp4')
    plt.plot(ts, ds[j])
plt.xlim([0, 0.2])
plt.ylim([-0.004, 0.004])
plt.legend(["1", "2", "3"])
Use the demos as a guide
https://docs.fenicsproject.org/dolfinx/v0.7.3/python/demos.html
https://jsdokken.com/dolfinx-tutorial/
There is also API documentation at API reference — DOLFINx 0.7.3 documentation
The problem is exactly what you reported. module ‘dolfinx’ has no attribute ‘IntervalMesh’. You need to use the path (i.e. submodule) that provides IntervalMesh, or the equivalent function that creates a 1D mesh.
It looks like you might be working from an example in legacy dolfin. Can you see from the demos (or API docs) how a mesh can be created in dolfinx?
