Geometric dimension error while compiling biharmonic pde
Hi all ,
I am working on biharmonic pde . I have neumann boundary condition . while compiling below code getting the error prescribed below
Cannot determine geometric dimension from expression.
  File "biharmonic3.py", line 87, in <module>
    + alpha/h_avg*inner(jump(z,n), jump(grad(v),n))*dS
  File "/usr/lib/python3/dist-packages/ufl/operators.py", line 381, in grad
    return Grad(f)
  File "/usr/lib/python3/dist-packages/ufl/differentiation.py", line 159, in __init__
    self._dim = find_geometric_dimension(f)
  File "/usr/lib/python3/dist-packages/ufl/domain.py", line 384, in find_geometric_dimension
    error("Cannot determine geometric dimension from expression.")
  File "/usr/lib/python3/dist-packages/ufl/log.py", line 172, in error
ufl.log.UFLException: Cannot determine geometric dimension from expression.
My code is given below:
# Next, some parameters for the form compiler are set::
# A mesh is created, and a quadratic finite element function space::
# Make mesh ghosted for evaluation of DG terms
parameters["ghost_mode"] = "shared_facet"
mesh = UnitSquareMesh(8,8)
V = FunctionSpace(mesh, "CG", 2)
class Source(UserExpression):
    def eval(self, values, x):
        values[0] = 112*pi**4*(sin(pi*x[0]))**4*(sin(pi*x[1]))**4 + 24*pi**4*(cos(pi*x[0]))**4*(sin(pi*x[1]))**4 + 24*pi**4*(cos(pi*x[1]))**4*(sin(pi*x[0]))**4 - 288*pi**4*(cos(pi*x[0]))**2*(sin(pi*x[0]))**2*(sin(pi*x[1]))**4 -288*pi**4*(cos(pi*x[1]))**2*(sin(pi*x[0]))**4*(sin(pi*x[1]))**2 + 288*pi**4*(cos(pi*x[0]))**2*(cos(pi*x[1]))**2*(sin(pi*x[0]))**2*(sin(pi*x[1]))**2
# On the finite element space ``V``, trial and test functions are
# created::
# Define normal component, mesh size and right-hand side
h = CellDiameter(mesh)
h_avg = (h('+') + h('-'))/2.0
g = Source(degree=2)
# Penalty parameter
alpha = Constant(6.0)
    def eval(self, value, x):
        value[0] = (sin(pi*x[0]))*(sin(pi*x[0]))*(sin(pi*x[0]))*(sin(pi*x[0]))*(sin(pi*x[1]))*(sin(pi*x[1]))*(sin(pi*x[1]))*(sin(pi*x[1]))
f = Source(degree=2)
        values[0] = 4*pi*cos(pi*x[0])*(sin(pi*x[0])**3)*(sin(pi*x[1])**4)
        values[1] = 4*pi*cos(pi*x[1])*(sin(pi*x[0])**4)*(sin(pi*x[1])**3)
    def value_shape(self):
         return (2,)
z = Source(degree=2)
b = inner(div(grad(f)), div(grad(v)))*dx \
  - inner(avg(div(grad(f))), jump(grad(v), n))*dS \
  - inner(jump(z, n), avg(div(grad(v))))*dS \
a = inner(div(grad(u)), div(grad(v)))*dx \
  - inner(avg(div(grad(u))), jump(grad(v), n))*dS \
  - inner(jump(grad(u), n), avg(div(grad(v))))*dS \
  + alpha/h_avg*dot(jump(grad(u),n), jump(grad(v),n))*dS
# Define linear form
L = b - g*v*dx
# A :py:class:`Function <dolfin.functions.function.Function>` is created
# to store the solution and the variational problem is solved::
# Solve variational problem
solve(a == L, u)
x = SpatialCoordinate(mesh)
u_ex = (cos(pi*x[0]))*(cos(pi*x[1]))
error_L2 = sqrt(assemble(((u-u_ex)**2)*dx))
print('error_L2  =', error_L2)
# The computed solution is written to a file in VTK format and plotted to
# the screen. ::
# Save solution to file
file = File("biharmonic.pvd")
file << u
# Plot solution
plot(u)
You should be able to solve this by adding the following class to your userexpression:
    return ()
Thanku for reply. Same error I am getting again. I want to know what is geometric dimension error?
Instead of using UserExpression, you can use ufl-expressions:
f =(sin(pi*x[0]))*(sin(pi*x[0]))*(sin(pi*x[0]))*(sin(pi*x[0]))*(sin(pi*x[1]))*(sin(pi*x[1]))*(sin(pi*x[1]))*(sin(pi*x[1]))
z = as_vector((4*pi*cos(pi*x[0])*(sin(pi*x[0])**3)*(sin(pi*x[1])**4)
               ,4*pi*cos(pi*x[1])*(sin(pi*x[0])**4)*(sin(pi*x[1])**3)))
It work but L2 error is too large while I am using h=1/128 , I am getting 0.5000000952… . Am I doing something wrong? Kindly help me.
That means that you haven’t provided the correct sources for the analytical solution. I suggest debugging this by visualizing the exact solution (project it to an appropriate function space) and the approximate solution in i.e. Paraview
You can also consider this question on the old forum:
https://fenicsproject.org/qa/11686/biharmonic-equation-with-dirichlet-and-neumann-bcs/
