I am implementing biharmonic pde with neumann boundary condition . I am getting error 0.4961486 with mesh size 1/128 which is too high. I don,t understand where I am doing wrong . Kindly help me . Thank You.
Here is my code :
# Next, some parameters for the form compiler are set::
# A mesh is created, and a quadratic finite element function space::
# Make mesh ghosted for evaluation of DG terms
parameters["ghost_mode"] = "shared_facet"
mesh = UnitSquareMesh(8,8)
V = FunctionSpace(mesh, "CG", 2)
class Source(UserExpression):
def eval(self, values, x):
values[0] = 112*pi**4*(sin(pi*x[0]))**4*(sin(pi*x[1]))**4 + 24*pi**4*(cos(pi*x[0]))**4*(sin(pi*x[1]))**4 + 24*pi**4*(cos(pi*x[1]))**4*(sin(pi*x[0]))**4 - 288*pi**4*(cos(pi*x[0]))**2*(sin(pi*x[0]))**2*(sin(pi*x[1]))**4 -288*pi**4*(cos(pi*x[1]))**2*(sin(pi*x[0]))**4*(sin(pi*x[1]))**2 + 288*pi**4*(cos(pi*x[0]))**2*(cos(pi*x[1]))**2*(sin(pi*x[0]))**2*(sin(pi*x[1]))**2
# On the finite element space ``V``, trial and test functions are
# created::
# Define normal component, mesh size and right-hand side
h = CellDiameter(mesh)
h_avg = (h('+') + h('-'))/2.0
f = Source(degree=2)
# Penalty parameter
alpha = Constant(6.0)
x = SpatialCoordinate(mesh)
g =(sin(pi*x[0]))*(sin(pi*x[0]))*(sin(pi*x[0]))*(sin(pi*x[0]))*(sin(pi*x[1]))*(sin(pi*x[1]))*(sin(pi*x[1]))*(sin(pi*x[1]))
z = as_vector((4*pi*cos(pi*x[0])*(sin(pi*x[0])**3)*(sin(pi*x[1])**4),4*pi*cos(pi*x[1])*(sin(pi*x[0])**4)*(sin(pi*x[1])**3)))
b = inner(div(z), div(grad(v)))*dx \
- inner(avg(div(z)), jump(grad(v), n))*dS \
- inner(jump(z, n), avg(div(grad(v))))*dS \
+ alpha/h_avg*inner(jump(z,n), jump(grad(v),n))*dS
l = (cos(pi*x[0]))*(cos(pi*x[1]))
p = as_vector((((-1)*pi*(cos(pi*x[1]))*(sin(pi*x[0]))),((-1)*pi*(cos(pi*x[0]))*(sin(pi*x[1])))))
c = inner(div(grad(l)), div(grad(v)))*dx \
- inner(avg(div(grad(l))), jump(grad(v), n))*dS \
- inner(jump(grad(l), n), avg(div(grad(v))))*dS \
+ alpha/h_avg*inner(jump(grad(l),n), jump(grad(v),n))*dS
a = inner(div(grad(u)), div(grad(v)))*dx \
- inner(avg(div(grad(u))), jump(grad(v), n))*dS \
- inner(jump(grad(u), n), avg(div(grad(v))))*dS \
+ alpha/h_avg*dot(jump(grad(u),n), jump(grad(v),n))*dS
# Define linear form
L = b - f*v*dx + c
# A :py:class:`Function <dolfin.functions.function.Function>` is created
# to store the solution and the variational problem is solved::
# Solve variational problem
solve(a == L, u)
u_ex = (cos(pi*x[0]))*(cos(pi*x[1]))
error_L2 = sqrt(assemble(((u-u_ex)**2)*dx))
print('error_L2 =', error_L2)
# The computed solution is written to a file in VTK format and plotted to
# the screen. ::
# Save solution to file
file = File("biharmonic3.pvd")
file << u
# Plot solution
plot(u)
