Thanks for your reply. Here is the full code attached.
from dolfinx import fem, mesh, plot,io
from dolfinx.fem import dirichletbc, Function, locate_dofs_topological
from dolfinx.io import (VTXWriter, distribute_entity_data, gmshio,XDMFFile)
from dolfinx.mesh import create_unit_square, locate_entities_boundary
create_vector, create_matrix, set_bc,LinearProblem)
from ufl import (Circumradius, FacetNormal, SpatialCoordinate,FacetNormal, Identity, Measure, TestFunction, TrialFunction,
as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym, system)
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
import scipy.special as sp
import pyvista as pv
import csv
from pathlib import Path
import tqdm.autonotebook
import matplotlib as mpl
# Time-stepping parameters
t = 0
T = 2.0 # final time
dt = 0.001 # time step
num_steps = int(T / dt)
folder = Path("results_new_fen")
folder.mkdir(exist_ok=True, parents=True)
D_c = np.array([[0.57, 6, 0.1410* 0.57], [-0.012, 1.6, 1.8], [-0.0006, -0.08, 0.56]])
d11, d12, d13 = D_c[0, :]/D_c[0, 0]
d21, d22, d23 = D_c[1, :]/D_c[0, 0]
d31, d32, d33 = D_c[2, :]/D_c[0, 0]
a, b, c = 0.266, 0.366, 0.141
gamma = 160
mesh = mesh.create_unit_square(MPI.COMM_WORLD, nx=10, ny=10)
V = fem.functionspace(mesh, ("Lagrange", 1))
dx = ufl.Measure("dx", domain=mesh)
ds = ufl.Measure("ds", domain=mesh)
cells, types, x = plot.vtk_mesh(V)
grid = pv.UnstructuredGrid(cells, types, x)
plotter = pv.Plotter(off_screen=True)
plotter.view_xy() # assigns plotting view
mesh_path = folder / "mesh_plot.jpg"
plotter.screenshot(filename=str(mesh_path),window_size=(1024, 768), transparent_background=False)
u, v, w = ufl.TrialFunction(V), ufl.TrialFunction(V), ufl.TrialFunction(V)
phi_1, phi_2, phi_3 = TestFunction(V), TestFunction(V), TestFunction(V)
u_ ,v_ , w_ = Function(V), Function(V), Function(V)
u_.name = "u_"
v_.name = "v_"
w_.name = "w_"
u_n, v_n, w_n = fem.Function(V), fem.Function(V), fem.Function(V)
u_n.name = "u_n"
v_n.name="w_n"
v_n.name="w_n"
u_star = a + b + c
v_star = b / (u_star**2)
w_star = c / (u_star**2)
def cosine_linear_combination(x, orders, scaling_factor=0.0001):
result = 0
result = np.zeros(x.shape[1])
for n, m in orders:
result += (
scaling_factor
* np.cos(n * np.pi * x[0, :])
* np.cos(m * np.pi * x[1, :])
return result
# Define the orders for the cosine terms
orders = [(1, 2), (2, 3), (1, 3)]
# Assign initial conditions
u_n.interpolate(lambda x: u_star + cosine_linear_combination(x, orders))
v_n.interpolate(lambda x: v_star + cosine_linear_combination(x, orders))
w_n.interpolate(lambda x: w_star + cosine_linear_combination(x, orders))
grid_u = pv.UnstructuredGrid(cells, types, x)
grid_v = pv.UnstructuredGrid(cells, types, x)
grid_w = pv.UnstructuredGrid(cells, types, x)
grid_u.point_data["u"] = u_n.x.array.real
grid_v.point_data["v"] = v_n.x.array.real
grid_w.point_data["w"] = w_n.x.array.real
ini_path = folder / "AAA_initial_u_v_w.jpg"
plotter = pv.Plotter(shape=(1, 3), off_screen=True)
# First subplot: u_n
plotter.subplot(0, 0)
plotter.add_mesh(grid_u, show_edges=False, scalars="u", cmap="viridis")
plotter.add_axes()
plotter.view_xy()
plotter.add_title("u_n")
# Second subplot: v_n
plotter.subplot(0, 1)
plotter.add_mesh(grid_v, show_edges=False, scalars="v", cmap="viridis")
plotter.add_axes()
plotter.view_xy()
plotter.add_title("v_n")
# Third subplot: w_n
plotter.subplot(0, 2)
plotter.add_mesh(grid_w, show_edges=False, scalars="w", cmap="viridis")
plotter.add_axes()
plotter.view_xy()
plotter.add_title("w_n")
plotter.screenshot(str(ini_path), window_size=(1024, 768), transparent_background=False)
plotter.close()
sol_u = folder / "U_solution.xdmf"
sol_v = folder / "v_solution.xdmf"
sol_w = folder / "w_solution.xdmf"
# Write mesh and solution to the XDMF file
with io.XDMFFile(MPI.COMM_WORLD, str(sol_u), "w") as xdmf_u:
xdmf_u.write_mesh(mesh)
u_.interpolate(lambda x: u_star + cosine_linear_combination(x, orders))
xdmf_u.write_function(u_, t)
with io.XDMFFile(MPI.COMM_WORLD, str(sol_v), "w") as xdmf_v:
xdmf_v.write_mesh(mesh)
v_.interpolate(lambda x: v_star + cosine_linear_combination(x, orders))
xdmf_v.write_function(v_, t)
with io.XDMFFile(MPI.COMM_WORLD, str(sol_w), "w") as xdmf_w:
xdmf_w.write_mesh(mesh)
w_.interpolate(lambda x: w_star + cosine_linear_combination(x, orders))
xdmf_w.write_function(w_, t)
def gg(u_n):
return u_n*u_n
lhs_um = u * phi_1 * ufl.dx + dt * (d11 * ufl.inner(ufl.grad(u), ufl.grad(phi_1)) * ufl.dx)\
+ dt * gamma * u *phi_1 * ufl.dx
lhs_vm = v * phi_2 * ufl.dx + dt * (d22 * ufl.inner(ufl.grad(v), ufl.grad(phi_2))* ufl.dx)\
+ dt * gamma * gg(u_n) * v * phi_2 * ufl.dx
lhs_wm = w * phi_3 * ufl.dx + dt *( d33 * ufl.inner(ufl.grad(w), ufl.grad(phi_3)) * ufl.dx)\
+ dt * gamma * gg(u_n)* w *phi_3 * ufl.dx
lhs_u, lhs_v, lhs_w = fem.form(lhs_um), fem.form(lhs_vm), fem.form(lhs_wm)
Au, Av, Aw = assemble_matrix(lhs_u), create_matrix(lhs_v), create_matrix(lhs_w)
Au.assemble()
rhs_um = u_n * phi_1 * dx + dt * gamma * a * phi_1 * ufl.dx\
+ dt * gamma * gg(u_n) * v_n * phi_1 * ufl.dx \
+ dt * gamma * gg(u_n)* w_n * phi_1 * ufl.dx\
- dt * (d12* dot(grad(v_n),grad(phi_1)) * ufl.dx) \
- dt * (d13* dot(grad(w_n),grad(phi_1)) * ufl.dx)
rhs_vm = v_n * phi_2 * dx + dt * gamma * b * phi_2 * ufl.dx\
- dt * (d21* dot(grad(u_n),grad(phi_2)) * ufl.dx)\
- dt * (d23* dot(grad(w_n),grad(phi_2)) * ufl.dx)
rhs_wm = w_n * phi_3 * dx + dt * gamma * c * phi_3 * ufl.dx\
- dt * (d31* dot(grad(u_n),grad(phi_3)) * ufl.dx)\
- dt * (d32* dot(grad(v_n),grad(phi_3)) * ufl.dx)
rhs_u, rhs_v, rhs_w = fem.form(rhs_um), fem.form(rhs_vm), fem.form(rhs_vm)
bu, bv, bw = create_vector(rhs_u), create_vector(rhs_v), create_vector(rhs_w)
bcs_u =[]
# Solver for u
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(Au)
#solver1.setType(PETSc.KSP.Type.GMRES)
#setType(PETSc.KSP.Type.GMRES)
pc1 = solver1.getPC()
pc1.setType(PETSc.PC.Type.JACOBI)
#pc1.setType(PETSc.PC.Type.ILU)
solver1.setTolerances(rtol=1e-10, atol=1e-10, max_it=2000)
# Solver v
solver2 = PETSc.KSP().create(mesh.comm)
solver2.setOperators(Av)
solver2.setType(PETSc.KSP.Type.BCGS)
pc2 = solver2.getPC()
pc2.setType(PETSc.PC.Type.JACOBI)
#pc2.setHYPREType("boomeramg")
# Solver for w
solver3 = PETSc.KSP().create(mesh.comm)
solver3.setOperators(Aw)
solver3.setType(PETSc.KSP.Type.BCGS)
pc3 = solver3.getPC()
pc3.setType(PETSc.PC.Type.JACOBI)
pv.start_xvfb()
grid_1 = pv.UnstructuredGrid(*plot.vtk_mesh(V))
plotter1 = pv.Plotter()
plotter1.open_gif("u_time.gif", fps=20)
grid_1.point_data["u_"] = u_.x.array
warped = grid_1.warp_by_scalar("u_", factor=1)
viridis = mpl.colormaps.get_cmap("viridis").resampled(25)
sargs = dict(title_font_size=25, label_font_size=20, fmt="%.2e", color="black",
position_x=0.1, position_y=0.8, width=0.8, height=0.1)
renderer = plotter1.add_mesh(warped, show_edges=True, lighting=False,
cmap=viridis, scalar_bar_args=sargs,
clim=[0, max(u_.x.array)])
progress = tqdm.autonotebook.tqdm(desc="Solving RDE", total=num_steps)
for i in range(num_steps):
progress.update(1)
# Update current time step
with bu.localForm() as loc:
loc.set(0)
assemble_vector(bu, rhs_u)
apply_lifting(bu, [lhs_u], bcs=[bcs_u])
bv.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
set_bc(bu, bcs_u)
solver1.solve(bu, u_.x.petsc_vec)
u_.x.scatter_forward()
# Solver 2
Av.zeroEntries()
assemble_matrix(Av, lhs_v)
Av.assemble()
with bv.localForm() as loc:
loc.set(0)
assemble_vector(bv, rhs_v)
apply_lifting(bv, [lhs_v], bcs=[bcs_u])
#apply_lifting(b2, [a2], [bcp])
set_bc(bv, bcs_u)
solver2.solve(bv, v_.x.petsc_vec)
v_.x.scatter_forward()
# Solver 3
Aw.zeroEntries()
assemble_matrix(Aw, lhs_w)
Aw.assemble()
with bw.localForm() as loc:
loc.set(0)
assemble_vector(bw, rhs_w)
apply_lifting(bv, [lhs_w], bcs=[bcs_u])
bw.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
set_bc(bw, bcs_u)
solver3.solve(bw, w_.x.petsc_vec)
w_.x.scatter_forward()
u_n.x.array[:] = u_.x.array
v_n.x.array[:] = v_.x.array
w_n.x.array[:] = w_.x.array
# Write solution to file
# Update plot
new_warped = grid_1.warp_by_scalar("u_", factor=1)
warped.points[:, :] = new_warped.points
warped.point_data["u_"][:] = u_.x.array
plotter1.write_frame()
plotter1.close()
xdmf_u.close()
