Giving every element a separate Youngs Modulus in linear elasticity problem
Hey there fellow friends,
i would like to make a little tool, so that i can calculate the displacements of nodes in a 2D truss system. It is working alright, but now i would like the elements of my system to have different Youngs Moduli. The mesh im using only has 6 elements so it’s not particularly complex. So far this is my code:
E = 1000
nu = 0.25                                       # Poisson's ratio
mu = E/(2*(1+nu))                               # 2. Lame's parameter
lmbda = Constant((E*nu)/((1+nu)*(1-2*nu)))      # 1. Lame's parameter
mesh = "files/mesh/truss.xml"
mesh = Mesh(mesh)
def cb1(x, on_boundary):
        return near(x[1], -2.0, 0.1)
bc1 = DirichletBC(V, Constant((0, 0)), cb1)
dx = Measure("dx")
def sigma(u, E):
        d = u.geometric_dimension()
        I = Identity(d)
        return lmbda * tr(epsilon(u)) * I + 2 * mu * epsilon(u)
def epsilon(z):
        return 0.5 * (nabla_grad(z) + nabla_grad(z).T)
du = TrialFunction(V)
U = Function(V)
u = U.vector()
d = U.geometric_dimension()
I = Identity(d)
E = 700
f = Constant((0, 0))
a = inner(sigma(du, E), epsilon(v)) * dx
L = inner(f, v) * dx
K, f_vec = assemble_system(a, L, bc1)
f_vec[4] = 400
f_vec[5] = -400
solve(K, u, f_vec)
u = np.array(u)
print(u)
I think i have to get some kind of loop going somewhere in:
but maybe some of you guys have some experience with this.
Thanks for the help and best regards!
Could you provide the mesh file or an image for me to test?
You can use a discontinuous Galerkin FunctionSpace of order 0 to model such things, i.e., you define
DG0 = FunctionSpace(mesh, 'DG', 0)
lmbda = Function(DG0)
and then you have to set the DoF’s of lambda, which correspond to the constant value on each triangle / tetrahedron, to the appropriate value. For this, you might want to take a look here: https://fenicsproject.org/qa/5476/accessing-the-cell-index-of-a-given-dof/
or the dofmap
DG0.dofmap()
