Elastodynamic problem
Hi, I’m trying to solve a simple elastodynamic problem with a 2d beam, that’s my code:
import fenics as fe
import time
# Functions and classes
def left(x, on_boundary):
    return (on_boundary and fe.near(x[0], 0.0))
# Strain function
    return 0.5*(fe.nabla_grad(u) + fe.nabla_grad(u).T)
# Stress function
def sigma(u):
    return lmbda*fe.div(u)*fe.Identity(2) + 2*mu*epsilon(u)
# Parameters
# Young's modulus and Poisson's ratio
E = 0.02e9
nu = 0.1
# Lame's constants
lmbda = E*nu/(1+nu)/(1-2*nu)
mu = E/2/(1+nu)
rho = 200.0
# Time-stepping
t_start = 0.0  # start time
t_end = 1.0e-1  # end time
t_steps = 100  # number of time steps
t, dt = np.linspace(t_start, t_end, t_steps, retstep=True)
dt = float(dt)
# Geometry
mesh = fe.RectangleMesh(fe.Point(0.,0.),fe.Point(5.,1.),100,10)
fe.plot(mesh)
# Function spaces
V = fe.VectorFunctionSpace(mesh, "CG", 1)
u_tr = fe.TrialFunction(V)
u_test = fe.TestFunction(V)
# Boundary conditions
bc1 = fe.DirichletBC(V, fe.Constant((0.0, 0.0)), left)
bc = [bc1]
# Initialization
u = fe.Function(V)
u_bar = fe.Function(V)
du = fe.Function(V)
ddu = fe.Function(V)
ddu_old = fe.Function(V)
file = fe.XDMFFile("FEniCS_explicit_output.xdmf")  # XDMF file
# Weak form
A_form = fe.inner(sigma(u_tr), epsilon(u_test))*fe.dx + 4*rho/(dt*dt)*fe.dot(u_tr - u_bar, u_test)*fe.dx
# Time loop
for ti in t:
    u_D.t = ti
    u_bar.assign(u + dt*du + 0.25*dt*dt*ddu)
    fe.solve(fe.lhs(A_form) == fe.rhs(A_form), u, bc)
    ddu_old.assign(ddu)
    ddu.assign(4/(dt*dt)*(u - u_bar))
    du.assign(du + 0.5*dt*(ddu + ddu_old))
    file.write(u, ti)
    #print(ti)
file.close()
The code works without errors, however when I plot the displacement I get a zero value. I have just write
fe.plot(u,mode='displacement')
I don’t understand if there is something wrong in the code or I have ton change the plot command.
Could you help me?
Thank you
Not sure if I am reading this right, but at the first time ti it seems to me that u_bar is assigned (a complicated expression which result is still) zero. In that case, accounting also for homogeneous Dirichlet BC, the system does not have any forcing, hence the solution u at the first time ti is still zero. Once the first u is zero, ddu and du will still be zero, and the next time steps will still have zero forcing term, hence zero solution.
Thank you very much. Initially indeed there was an imposed displacement that I have removed, I’ll try to fix it.
