I want to use a mesh created on GMSH (2d rectangle but separated into several rectangles containing a different number of meshes depending on x) in my topological toptimization via dolphin adjoint. However I encounter this error: ‘dolfin.cpp.mesh.mesh’ object has no attribute ‘_ad_will_add_as_dependency’ when I perform “vol_7 = assemble(Constant(1.0) * dx(7))”.
Here’s how I load the mesh:
mesh, boundaries_mf_imported, association_table = import_mesh(prefix=“Mesh/mesh”, dim=2),
which is a function from GitHub - floiseau/msh2xdmf: Converter from MSH mesh format to XDMF mesh format
My code works fine if I don’t import dolphin_adjoint, but I need it for optimization.
Thank you !!!
