From gmsh to dolfin without file generation
Hi all,
For my simulations (with fenics 2019.2.0), I’m currently using gmsh for the mesh generation, and then I use meshio for transforming the .msh file into .xdmf files, and finally I load these files as MeshFunction. A typical workflow is:
import sys
gmsh.initialize(sys.argv)
if MPI.comm_world.rank == 0:
    gmsh.model.add("geometry")
    gmsh.model.occ.addCircle(0, 0, 0, 1, angle1 = 0, angle2 = 2*pi, tag=1)
    gmsh.model.occ.addCircle(0, 0, 0, 2, angle1 = 0, angle2 = 2*pi, tag=2)
    gmsh.model.occ.addCurveLoop([1], tag=1)
    gmsh.model.occ.addPlaneSurface([1], tag=1)
    gmsh.model.occ.addCurveLoop([2], tag=2)
    gmsh.model.occ.addCurveLoop([1], tag=3)
    gmsh.model.occ.addPlaneSurface([2, 3], tag=2)
    gmsh.model.occ.synchronize()
    gmsh.model.addPhysicalGroup(2, [1], tag=1)
    gmsh.model.addPhysicalGroup(2, [2], tag=2)
    gmsh.model.addPhysicalGroup(1, [2], tag=3)
    gmsh.model.mesh.setSize([(0, 1)], size = 0.1)
    gmsh.model.mesh.setSize([(0, 2)], size = 0.1)
    gmsh.model.mesh.generate(2)
    gmsh.write("mesh.msh")
    gmsh.finalize()
    msh = meshio.read("mesh.msh")
    cells = np.vstack(np.array([cells.data for cells in msh.cells
                                if cells.type == "triangle"]))
    total_mesh = meshio.Mesh(points=msh.points,
                             cells=[("triangle", cells)])
    total_mesh.prune_z_0()
    cells_data = msh.cell_data_dict["gmsh:physical"]["triangle"]
    cells_mesh = meshio.Mesh(points=msh.points,
                                cells=[("triangle", cells)],
                                cell_data={"name_to_read": [cells_data]})
    cells_mesh.prune_z_0()
    facet_cells = np.vstack(np.array([cells.data for cells in msh.cells
                                      if cells.type == "line"]))
    facet_data = msh.cell_data_dict["gmsh:physical"]["line"]
    facet_mesh = meshio.Mesh(points=msh.points,
                             cells=[("line", facet_cells)],
                             cell_data={"name_to_read": [facet_data]})
    facet_mesh.prune_z_0()
    meshio.write("total.xdmf", total_mesh)
    meshio.write("facets.xdmf", facet_mesh)
    meshio.write("cells.xdmf", cells_mesh)
MPI.comm_world.barrier()
parameters["ghost_mode"] = "shared_vertex"
comm = MPI.comm_world
mesh = Mesh(MPI.comm_world)
with XDMFFile(MPI.comm_world, "cells.xdmf") as infile:
    infile.read(mesh)
mvc_facets = MeshValueCollection("size_t", mesh, 1)
with XDMFFile(MPI.comm_world, "facets.xdmf") as infile:
    infile.read(mvc_facets, "name_to_read")
mf_facets = cpp.mesh.MeshFunctionSizet(mesh, mvc_facets)
mvc_cells = MeshValueCollection("size_t", mesh, 2)
    infile.read(mvc_cells, "name_to_read")
mf_cells = cpp.mesh.MeshFunctionSizet(mesh, mvc_cells)
I’m wondering if someone has already worked out a way to shortcut the mesh loading into MeshFunction from gmsh without having to write .msh and .xdmf file. Maybe something can be done with MeshEditor, as suggested here, but I’m having troubles in understanding how I should translate this code into a gmsh compatible code.
You can extract the topology (cells) and geometry (points) of the gmsh object as done in:
Thank you very much for the suggestion.
I think I’ve almost done it, but I’m having hard times in understanding how to correctly write the MeshValueCollection without the use of .xdmf file (Eventually, I’d like to have MeshFunction variables to use as subdomain_data for my Measure). My code is the following one at the moment:
import sys
import dolfin as df
from ufl import vertex
def extract_gmsh_topology_and_markers(gmsh_model, model_name=None):
    if model_name is not None:
        gmsh_model.setCurrent(model_name)
    phys_grps = gmsh_model.getPhysicalGroups()
    topologies = {}
    for dim, tag in phys_grps:
        entities = gmsh_model.getEntitiesForPhysicalGroup(dim, tag)
        for entity in entities:
            element_data = gmsh_model.mesh.getElements(dim, tag=entity)
            element_types, element_tags, node_tags = element_data
            assert len(element_types) == 1
            element_type = element_types[0]
            num_el = len(element_tags[0])
            properties = gmsh_model.mesh.getElementProperties(element_type)
            name, dim, order, num_nodes, local_coords, _ = properties
            element_topology = node_tags[0].reshape(-1, num_nodes) - 1
            if element_type in topologies.keys():
                topologies[element_type]["topology"] = np.concatenate(
                    (topologies[element_type]["topology"], element_topology), axis=0)
                topologies[element_type]["cell_data"] = np.concatenate(
                    (topologies[element_type]["cell_data"], np.full(num_el, tag)), axis=0)
                topologies[element_type] = {"topology": element_topology, "cell_data": np.full(num_el, tag)}
    return topologies
def extract_gmsh_geometry(gmsh_model, model_name=None):
    indices, points, _ = gmsh_model.mesh.getNodes()
    points = points.reshape(-1, 3)
    indices -= 1
    perm_sort = np.argsort(indices)
    assert np.all(indices[perm_sort] == np.arange(len(indices)))
    return points[perm_sort]
if comm.rank == 0:
    topologies = extract_gmsh_topology_and_markers(gmsh.model)
    cells = topologies[2]["topology"]
    points = extract_gmsh_geometry(gmsh.model)
    points = points[:, 0:2]
    points = cells = None
comm.barrier()
points = comm.bcast(points, root=0)
cells  = comm.bcast(cells, root=0)
editor = MeshEditor()
mesh = Mesh(comm)
editor.open(mesh, "triangle", 2, 2)
if comm.rank == 0:
    editor.init_vertices(points.shape[0])
    editor.init_cells(cells.shape[0])
    for k, point in enumerate(points):
        editor.add_vertex(k, point)
    for k, cell in enumerate(cells):
        editor.add_cell(k, cell)
    editor.close()
comm.barrier()
print(assemble(Constant(1)*dx(domain=mesh)))
#with XDMFFile(comm, "cells.xdmf") as infile:
#    infile.read(mesh)
#mvc_facets = MeshValueCollection("size_t", mesh, 1)
#with XDMFFile(comm, "facets.xdmf") as infile:
#    infile.read(mvc_facets, "name_to_read")
#mf_facets = cpp.mesh.MeshFunctionSizet(mesh, mvc_facets)
#mvc_cells = MeshValueCollection("size_t", mesh, 2)
#    infile.read(mvc_cells, "name_to_read")
#mf_cells = cpp.mesh.MeshFunctionSizet(mesh, mvc_cells)
The commented part is the one I wish to translate into an “xdmf-free” code, but, as I said, I was not able to find a way to define my MeshValueCollection w/o .xdmf files.
Hello everyone,
I’m still struggling finding a way to express MeshFunction without passing through .xdmf files.
Could anyone give me some hints on that? Which dolfin functions shoud I look at?
As far as I am aware, you need: Bitbucket
which is similar to dolfinx/xdmf_utils.h at fe741ee468b43bd4645202201aa983726eed59ab · FEniCS/dolfinx · GitHub in DOLFINx, which is used to map the gmsh entities to the correct local entity: dolfinx/demo_gmsh.py at 3a113a8854b14649a70127cae6455f2588e8be31 · FEniCS/dolfinx · GitHub
In dolfin, this function is called when reading in XDMFFiles:Bitbucket
Thanks so much, I’ll have a look at it!
