Gmshio.model_to_mesh 1D mesh error
i’ve encountered an error when tried to create 1d mesh with gmesh.occ and transform with gmshio.model_to_mesh. The problem is not preveilant when using gmesh.geo. Any suggestions why there is the difference between .occ and .geo result when using gmshio.model_to_mesh?
The error:
229 perm_sort = np.argsort(cell_dimensions)
    231 # Broadcast cell type data and geometric dimension
--> 232 cell_id = cell_information[perm_sort[-1]]["id"]
    233 tdim = cell_information[perm_sort[-1]]["dim"]
    234 num_nodes = cell_information[perm_sort[-1]]["num_nodes"]
IndexError: index -1 is out of bounds for axis 0 with size
gmesh code:
gmsh.model.add("1d")
p1 = gmsh.model.occ.addPoint(1, 1, 0)
p2 = gmsh.model.occ.addPoint(2, 1, 0)
l1 = gmsh.model.occ.addLine(p1, p2)
gmsh.model.addPhysicalGroup(1, [l1], 101)
gmsh.model.occ.synchronize()
gmsh.model.mesh.generate(1)
gdim = 2
gmsh_model_rank = 0
mesh_comm = MPI.COMM_WORLD
mesh1, cell_tags1, facet_tags1 = gmshio.model_to_mesh(gmsh.model, mesh_comm, gmsh_model_rank, gdim=gdim)
dolfinx → 0.7.1
You should never call
after adding physical groups, as it removes them. I.e. restructuring the code as
gdim = 2
gmsh_model_rank = 0
mesh1, cell_tags1, facet_tags1 = dolfinx.io.gmshio.model_to_mesh(
runs with no error
thanks for the answer. Now code works fine
