I am trying to set a mesh using gmsh, and I am struggling with the interface in dolfinx.io.gmshio. My code is the following :
from dolfinx.io.gmshio import model_to_mesh
mesh_comm = MPI.COMM_WORLD
gdim = 2
model_rank = 0
L = 5.0
H = 1.0
hmin = 0.1; # min element size
hmax = 0.01; # max element size
p0 = gmsh.model.occ.addPoint(0, 0, 0, hmin, 1)
p1 = gmsh.model.occ.addPoint(0, L, 0, hmin, 2)
p2 = gmsh.model.occ.addPoint(L, H, 0, hmax, 3)
p3 = gmsh.model.occ.addPoint(0, H, 0, hmax, 4)
lines = []
lines.append(gmsh.model.occ.addLine(1, 2, 1))
lines.append(gmsh.model.occ.addLine(2, 3, 2))
lines.append(gmsh.model.occ.addLine(3, 4, 3))
lines.append(gmsh.model.occ.addLine(4, 1, 4))
loop = gmsh.model.occ.addCurveLoop(lines ,5)
surface = gmsh.model.occ.addPlaneSurface([5],6)
gmsh.model.addPhysicalGroup(2, [surface], 1)
gmsh.model.setPhysicalName(2, 1, "surface")
gmsh.model.occ.synchronize()
domain, cell_tags, facet_tags = model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=gdim)
gmsh.finalize()
I get the following error:
File ~/anaconda3/envs/fenicsx-0.5.1/lib/python3.9/site-packages/dolfinx/io/gmshio.py:205, in model_to_mesh(model, comm, rank, gdim)
202 perm_sort = np.argsort(cell_dimensions)
204 # Broadcast cell type data and geometric dimension
--> 205 cell_id = cell_information[perm_sort[-1]]["id"]
206 tdim = cell_information[perm_sort[-1]]["dim"]
207 num_nodes = cell_information[perm_sort[-1]]["num_nodes"]
IndexError: index -1 is out of bounds for axis 0 with size 0
It seems, from a similar topic on this forum, that this has something to do with makers. But I am not sure how to solve this issue.
I used to export the gmsh files in msh format and to convert them into xml using meshconvert.convert2xml() from dolfin_utils.meshconvert, but I’m not sure a similar option exists in dolfinx, so I am stuck there…
Many thanks in advance for your help with this!
Claire
