For the \phi_i's, the basis functions obtained by the approximation of a P1 (linear) finite element space related to the discretization of a cylinder \Omega,
The setup is as follows:
r=15
large=70
begin=[-15, 0, 0]
ending=[45, 0, 0]
cylinder=Cylinder(Point(begin),Point(ending), r ,r)
mesh_cilinder = generate_mesh(cylinder, 10)
Space = FunctionSpace(mesh_cilinder,'P', 1)
basis_function=TrialFunction(Space)
I am trying to compute the gradients of the basis functions evaluated at each vertex of the mesh. Specifically, I want to compute the following matrices: \big[\nabla_x \phi_i(x_j)\big]_{i,j}, \big[\nabla_y \phi_i(x_j)\big]_{i,j}, \big[\nabla_z \phi_i(x_j)\big]_{i,j}, where x_j are the coordinates of the mesh vertices.
My approach was to create an expression for each basis function and then interpolate it over the entire function space:
coordinates_nodes=mesh_cilinder.coordinates()
cells_nodes=mesh_cilinder.cells()
basis_function_list=[ ]
integral_basis=[ ]
n=Space.dim()
for i in range(n):
# Create a function that represents the i-th basis function
x0=coordinates_nodes[i][0]
x1=coordinates_nodes[i][1]
x2=coordinates_nodes[i][2]
phi_node = interpolate(Expression('(x[0] == x0 && x[1] == x1 && x[2] == x2) ? 1 : 0', degree=3, x0=x0,x1=x1,x2=x2),Space)
basis_function_list.append(phi_node)
and after that compute the gradient and evaluate in the vertex of the mesh, for example for phi_0
u0=interpolate(basis_function_list[0],Space)
gradf = grad(u0)
u,v,w = gradf
project(u).vector().get_local()
project(v).vector().get_local()
project(w).vector().get_local()
However, the values I obtained for the gradients are not what I expected, since they are not constant, however the derivatives of the basis functions should be piecewise constant since I am using P1.
Could you please help me understand the correct way to compute the gradients of the basis functions and evaluate them at the mesh vertices for computing the matrices?
