Hi everyone! Dear community!
I am trying to learn the boundary condition processing of DG and curl elements.
Because I haven’t found it in any tutorials.Progress is very slow.
First I created a mesh and defined a mixed finite element space.
msh = create_unit_cube(MPI.COMM_WORLD,
1, 1, 1,
CellType.tetrahedron, ghost_mode=GhostMode.none)
u_element = ufl.VectorElement("DG", ufl.tetrahedron, 1)
A_element = ufl.FiniteElement("N1curl", ufl.tetrahedron, 1)
P_element = ufl.FiniteElement("DG", ufl.tetrahedron, 0)
TH = ufl.MixedElement([u_element, A_element, P_element])
W = fem.FunctionSpace(msh, TH)
W0, map0 = W.sub(0).collapse()
W1, map1 = W.sub(1).collapse()
W2, map2 = W.sub(2).collapse()
def u_D(x):
values = np.zeros_like(x, dtype=_PETSc.ScalarType)
values[0, :] = 1
values[1, :] = 2
values[2, :] = 3
return values
def A_D(x):
values[0, :] = 3
values[1, :] = 2
values[2, :] = 1
return values
u_D and A_D is Dirichlet boundary condition that I want.
Second I mark the boundary and assemble the boundary conditions
un_D=fem.Function(W0)
un_D.interpolate(u_D)
un=fem.Function(W0)
An_D=fem.Function(W1)
An_D.interpolate(A_D)
An=fem.Function(W1)
(unv,Anv,Pn)=ufl.TrialFunctions(W) #
(v,fai,q)=ufl.TestFunctions(W) #
def boundarymark(x):
return np.isclose(x[0],0)|np.isclose(x[0],1)|np.isclose(x[1],0)|np.isclose(x[1],1)|np.isclose(x[2],0)|np.isclose(x[2],1)
dofs0 = locate_dofs_geometrical((W0, W0), boundarymark)
bc0 = dirichletbc(un_D, dofs0, W0)
bcsu=[bc0]
dofs1 = locate_dofs_geometrical((W0, W0), boundarymark)
bc1 = dirichletbc(An_D, dofs1, W.sub(1))
bcsa=[bc1]
set_bc(un.vector,bcsu)
set_bc(An.vector,bcsa)
The output is :Un
An:
This code seems different from the Dolfinx tutorial.
Is this correct?
**The most important thing is that bcsa and bcsu the last thing I need to use when using Dirichlet boundary conditions?**i.e.
apply_lifting(b,[a],[bcs]) ?
