Modeling heterogeneous material expansion with mixed elements
I’m trying to model the heterogeneous dilation of a 3D solid, composed of a two-phase material that has different properties. For that, I’m creating mixed elements P and Q with different mechanical properties and expansion coefficients.
I have several questions.
1- I’m not sure I have formulated correctly the variatonal formulation. As I understand it (or need it), each P element should share the nodes with its Q counterpart.
2- I don’t know how to stablish the dirichlet boundary conditions as I’m struggling with the nomenclature. I understand that I need to define u_D as a 2x3 vector of zeros, but I’m not able to do so.
This is the code I have so far:
from dolfinx import fem, io, mesh
from ufl import Measure, SpatialCoordinate, TestFunctions, TrialFunctions, div, exp, inner, sym, nabla_div, Identity, grad
Lx, Ly, Lz = 1.0, 1.0, 1.0  # Length in x, y, z directions
nx, ny, nz = 10, 10, 10  # Number of elements in x, y, z directions
# Create the box mesh
domain = mesh.create_box(MPI.COMM_WORLD,
                                 [np.array([0.0, 0.0, 0.0]), np.array([Lx, Ly, Lz])],
                                 [nx, ny, nz],
                                 mesh.CellType.tetrahedron)
# Define the function space
P_el = element("Lagrange", domain.basix_cell(), 1, shape=(3,))
Q_el = element("Lagrange", domain.basix_cell(), 1, shape=(3,))
V_el = mixed_element([Q_el, P_el])
V = fem.functionspace(domain, V_el)
# Define material properties for P elements
E_p = 10.0  # Young's modulus
nu_p = 0.3  # Poisson's ratio
alpha_p = 1e-5  # Coefficient of thermal expansion
delta_T_p = -100  # Temperature change
lambda_p = (E_p * nu_p / ((1 + nu_p) * (1 - 2 * nu_p)))
mu_p = (E_p / (2 * (1 + nu_p)))
kappa_p = delta_T_p * (alpha_p * (2 * mu_p + 3 * lambda_p))
E_q = 20.0  # Young's modulus
nu_q = 0.4  # Poisson's ratio
alpha_q = 2e-5  # Coefficient of thermal expansion
delta_T_q = -100  # Temperature change
lambda_q = (E_q * nu_q / ((1 + nu_q) * (1 - 2 * nu_q)))
mu_q = (E_q / (2 * (1 + nu_q)))
kappa_q = delta_T_q * (alpha_q * (2 * mu_q + 3 * lambda_q))
(u_p, u_q) = TrialFunctions(V)
(v_p, v_q) = TestFunctions(V)
x = SpatialCoordinate(domain)
# f_p = ? # list of individual kappa values for P elements
# f_q = ? # list of individual kappa values for Q elements
f_p = fem.Constant(domain, default_scalar_type((kappa_p, kappa_p, kappa_p)))
f_q = fem.Constant(domain, default_scalar_type((kappa_q, kappa_q, kappa_q)))
dx = Measure("dx", domain)
    return sym(grad(u))
def sigma(u):
    return lambda_p * nabla_div(u) * Identity(len(u)) + 2 * mu_p * epsilon(u) + lambda_q * nabla_div(u) * Identity(len(u)) + 2 * mu_q * epsilon(u)
a = inner(sigma(u_p), epsilon(v_p)) * dx
L = inner(f_p, v_p) * dx  + inner(f_q, v_q) * dx
# Get subspace of V
V0 = V.sub(0)
facets_x0 = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[0], 0.0))
Q, _ = V0.collapse()
dofs_x0 = fem.locate_dofs_topological((V0, Q), fdim, facets_x0)
u_D = np.array([0, 0, 0], dtype=default_scalar_type) # THIS IS WRONG
bc = fem.dirichletbc(u_D, dofs_x0, V0)
If ran like that, it throws this error:
Exception has occurred: TypeError
__init__(): incompatible function arguments. The following argument types are supported:
    1. __init__(self, g: ndarray[dtype=float64, writable=False, order='C'], dofs: ndarray[dtype=int32, writable=False, shape=(*), order='C'], V: dolfinx.cpp.fem.FunctionSpace_float64) -> None
    2. __init__(self, g: dolfinx.cpp.fem.Constant_float64, dofs: ndarray[dtype=int32, writable=False, shape=(*), order='C'], V: dolfinx.cpp.fem.FunctionSpace_float64) -> None
    3. __init__(self, g: dolfinx.cpp.fem.Function_float64, dofs: ndarray[dtype=int32, writable=False, shape=(*), order='C']) -> None
    4. __init__(self, g: dolfinx.cpp.fem.Function_float64, dofs: list[ndarray[dtype=int32, writable=False, shape=(*), order='C']], V: dolfinx.cpp.fem.FunctionSpace_float64) -> None
Invoked with types: dolfinx.cpp.fem.DirichletBC_float64, ndarray, list, dolfinx.cpp.fem.FunctionSpace_float64
TypeError: __init__(): incompatible function arguments. The following argument types are supported:
Invoked with types: dolfinx.cpp.fem.DirichletBC_float64, ndarray, list, dolfinx.fem.function.FunctionSpace
  File "/home/cborau/fenicsx_projects/test13.py", line 79, in <module>
Thanks in advance
For the boundar conditions, please consider
and/or
as well as
https://jsdokken.com/dolfinx-tutorial/chapter3/component_bc.html
and
https://docs.fenicsproject.org/dolfinx/v0.8.0/python/demos/demo_stokes.html#non-blocked-direct-solver
