Thank you for watching. This is the program used to simulate the cavity flow, but it still makes mistakes after a long time of modification. Please publish it again. I hope you can find the mistakes or make comments.
import sympy as sym
from sympy import cos, sin
import math
import time
def boundary(x):
tol = 1E-12
return abs(x[0]) < tol or abs(x[1]) < tol or abs(x[0] - 1) < tol or abs(x[1] - 1) < tol
# Define two-dimensional versions of cross and curl operators
def scross(x, y):
return x[0] * y[1] - x[1] * y[0] # 向量叉乘
def vcross(x, y):
return as_vector([x[1] * y, -x[0] * y])
def scurl(x):
return x[1].dx(0) - x[0].dx(1)
def vcurl(x):
return as_vector([x.dx(1), -x.dx(0)])
def acurl(x):
return as_vector([x[2].dx(1),-x[2].dx(0),x[1].dx(0) - x[0].dx(1)])
def E_L2_H1(n):
channel = Rectangle(Point(0, 0), Point(1.0, 1.0))
mesh = generate_mesh(channel, n)
B = FiniteElement("Bubble", mesh.ufl_cell(), 3)
V = VectorElement(P1 + B) # velocity field space
# V = VectorElement("P", mesh.ufl_cell(), 2)
Q = FiniteElement("P", mesh.ufl_cell(), 1) # pressure field space
M = FiniteElement("N1curl", mesh.ufl_cell(), 1) # magnetic filed space
G = FiniteElement("P", mesh.ufl_cell(), 1)
H = FiniteElement("P", mesh.ufl_cell(), 1) # temperture
We = MixedElement([V, Q, M, G, H]) # u p B r T
W = FunctionSpace(mesh, We)
T = 11 # final time
Re = 1000
Sc = 1
Rm = 1
dt = 1 / 100
t = dt
f = Constant((0.0, 0.0))
g = Constant((0.0, 0.0))
beta = Constant((1.0, 0.0))
k = Constant(1.0)
ps=Constant((0.0, 0.0))
u1_d1 = '''0'''
u2_d1 = '''0'''
B_d1 = '''0'''
B_d2 = '''0'''
p_d1 = '''0'''
r_x = '''0'''
T_D = '''0'''
W_ex = Expression((u1_d1, u2_d1, B_d1, B_d2, p_d1, r_x, T_D), degree=4)
U = interpolate(W_ex, W)
Uk = Function(W) # 储存上一步值的函数空间 定义
start = time.time()
while t <= T:
inflow = 'near(x[0],0)'
outflow = 'near(x[0],1)'
walls = 'near(x[1],0) || near (x[1],1)'
inflow_profile = ('6.0', '0')
bcu_inflow = DirichletBC(W.sub(0), Expression(inflow_profile, degree=2), inflow)
bcu_outflow = DirichletBC(W.sub(0), Expression(inflow_profile, degree=2), outflow)
bcu_walls = DirichletBC(W.sub(0), Constant((0.0, 0.0)), walls)
bcB_inflow = DirichletBC(W.sub(2), Constant((0.0, 0.0)), inflow)
bcB_walls = DirichletBC(W.sub(2), Constant((1.0, 0.0)), walls)
bcB_outflow = DirichletBC(W.sub(2), Constant((0.0, 0.0)), outflow)
bcr = DirichletBC(W.sub(3), Constant(0.0), boundary)
bcT_inflow = DirichletBC(W.sub(4), Constant(1.0), inflow)
#bcp_outflow = DirichletBC(W.sub(1), Constant(0.0), outflow)
bcs = [bcu_inflow, bcu_outflow, bcu_walls, bcB_inflow, bcB_walls, bcB_outflow, bcr , bcT_inflow]
u, p, B, r, TTT = TrialFunctions(W)
v, q, s, w, ttt = TestFunctions(W)
(uk, pk, Bk, rk, TTTk) = Uk.split(deepcopy=True)
# temperture-inner(beta*TTT,v)
F = (dot((u - uk) / dt, v) + inner(grad(u), grad(v)) * pow(Re, -1) + 0.5 * inner(dot(grad(u), uk),v)- 0.5 * inner(dot(grad(v), uk), u) - p * div(v) - dot(scurl(B), scross(Bk, v)) * Sc + div(u) * q + 1.E-10 * inner(p, q)- inner(beta * TTT, v)) * dx \
+ (dot((B - Bk) / dt, s) + dot(scurl(B), scurl(s)) * Sc * pow(Rm, -1) - dot(scross(u, Bk),scurl(s)) * Sc - inner(grad(r),s)+ inner(grad(w), B)) * dx \
+ (dot((TTT - TTTk) / dt, ttt) + inner(grad(TTT), grad(ttt)) * k + 0.5 * inner(dot(grad(TTT), uk),ttt) - 0.5 * inner(dot(grad(ttt), uk), TTT)) * dx - (inner(f, v) + inner(g, s) + inner(ps, ttt)) * dx
A0 = lhs(F)
L0 = rhs(F)
U = Function(W)
solve(A0 == L0, U, bcs)
(u, p, B, r, TTT) = U.split(deepcopy=True)
plot(u, title='t=%.d Velocity' % t)
end = time.time()
print("time:%。2f秒" % (end - start))
n = 16
E_L2_H1(n)
The error
Shapes do not match: <Coefficient id=139856827226432> and <Indexed id=139856696760336>.
File "/mnt/c/Users/ALSACE/PycharmProjects/pythonProject3/main.py", line 118, in <module>
E_L2_H1(n)
File "/mnt/c/Users/ALSACE/PycharmProjects/pythonProject3/main.py", line 104, in E_L2_H1
File "/usr/lib/python3/dist-packages/ufl/operators.py", line 158, in inner
return Inner(a, b)
File "/usr/lib/python3/dist-packages/ufl/tensoralgebra.py", line 147, in __new__
error("Shapes do not match: %s and %s." % (ufl_err_str(a), ufl_err_str(b)))
File "/usr/lib/python3/dist-packages/ufl/log.py", line 158, in error
ufl.log.UFLException: Shapes do not match: <Coefficient id=139856827226432> and <Indexed id=139856696760336>.
Thanks again!
