I am trying to obtain the external forces force vector and stiffness matrix of this code. The stiffness matrix works but for obtaining the external forces vector I get stuck in saving the vector and how to load it afterward.
import math
import scipy.sparse as sp_sparse
mesh =UnitCubeMesh(4, 4, 4)
# Defining the function spaces
V_c = FunctionSpace(mesh, 'P', 1)
#STABILIZATION CROSSWIND TERMS
alpha= Constant(0.6)
I= Identity(mesh.geometry().dim())
def q(c):
return (sqrt(dot(dot(u,grad(c)),dot(u,grad(c))))/sqrt(dot(grad(c),grad(c))))
# Define variational problem for Picard iteration
c = TrialFunction(V_c)
# Galerkin variational problem
F=(diff*dot(grad(c),grad(v))+dot(u,grad(c))*v)*dx-f*v*dx
# Add SUPG stabilization terms
F += dot(u,grad(v))*tau_supg*dot(u,grad(c))*dx
# Add crosswind stabilization terms
CWD=(I-(outer(u,u)/sqrt(dot(dot(u,u),dot(u,u)))))
F += dot(dot(0.5*alpha*h*q(c_k)*grad(c),CWD),grad(v))*dx
# Create bilinear and linear forms
a = lhs(F)
L = rhs(F)
# Get the stifness matrix and the force vector
A=assemble(a)
y=assemble(L)
A_mat = as_backend_type(A).mat()
y_array= as_backend_type(y).vec()
from scipy.sparse import csr_matrix
A_sparray = csr_matrix(A_mat.getValuesCSR()[::-1], shape = A_mat.size)
from scipy import sparse
sparse.save_npz("K_sparray.npz", A_sparray)
y.vector().get_local()
I don’t know how to transform the dolfin vector to numpy or neither from petcs to numpy .
