The problem in a simple example I made and how to 'project' the value assigned to 'FunctionSpace' into a numpy array in dolfinx environment?
hi :grinning:
Currently, I am using the dolfinx library.
I was studying the dolfinx library by myself, and many questions arose, so I wrote a post on the forum.
Condensing the questions into three,
1] Minor question?: The dolfinx library does not use docker, it is directly installed on ubuntu 22.04, and the version is assumed to be 0.4.1. Is there a separate way to check the dolfinx version?
2] To study the dolfinx library, I made an example of applying an external force to the simple 2D cantilever (spanning [0,L]\times[0,H]) as shown below.
Compared with the reliable results obtained from the dolfin library, there is a difference and I think that there is an error when grafting the given formula condition to the code.
화면 캡처 2022-08-30 140142
(Afterwards, in the example code, L(nelx) was applied as 2, and H(nely) was also applied as 2)
The formula can be rearranged as:
governing equation: -\nabla\cdot\sigma(\mathbf{u})=0
Dirichlet boundary condition(clamp): \mathbf{u}=0 at \partial\Omega_{D} (left of cantilever beam)
External load: \textbf{F}_{T}=-1 on \partial\Omega_{N}(for y-direction)
Then, using Cauchy stress tensor and strain energy equation such that
Cauchy stress tensor: \sigma(\mathbf{u})=\lambda\textrm{tr}(\epsilon(\mathbf{u}))\textit{I}\ +2\mu\epsilon(\mathbf{u})
Strain energy equation: \psi(\mathbf{u})=\frac{\lambda}{2}\{\textrm{tr}(\epsilon(\mathbf{u}))\}^{2}\ + \mu\textrm{tr}(\epsilon(\mathbf{u})^{2})
(\epsilon(\mathbf{u})=\frac{1}{2}(\nabla\mathbf{u}\ + (\nabla\mathbf{u})^{T})=sym(\nabla\mathbf{u}), \lambda=0.6, \mu=0.4)
The code using the dolfinx library is written as follows
from dolfinx import fem, mesh
Declare the input variables
nelx = 2
nely = 2
volfrac = 0.5
penal = 3
Setting preliminaries
sigma = lambda _u: 2.0 * mu * ufl.sym(ufl.grad(_u)) + lmd * ufl.tr(ufl.sym(ufl.grad(_u))) * ufl.Identity(len(_u))
psi = lambda _u: lmd / 2 * (ufl.tr(ufl.sym(ufl.grad(_u))) ** 2) + mu * ufl.tr(ufl.sym(ufl.grad(_u)) * ufl.sym(ufl.grad(_u)))
mu, lmd = PETSc.ScalarType(0.4), PETSc.ScalarType(0.6)
Prepare finite element analysis
msh = mesh.create_rectangle(MPI.COMM_WORLD, ((0.0, 0.0), (nelx, nely)), (nelx, nely), cell_type=mesh.CellType.triangle)
U = fem.VectorFunctionSpace(msh, ("CG", 1))
D = fem.FunctionSpace(msh, ("DG", 0))
u, v = ufl.TrialFunction(U), ufl.TestFunction(U)
u_sol, density = fem.Function(U), fem.Function(D)
density.x.array[:] = volfrac
Define support
def left_clamp(x):
    return np.isclose(x[0], 0.0)
f_dim = msh.topology.dim - 1
bc_facets = mesh.locate_entities_boundary(msh, f_dim, left_clamp)
u_zero = np.array([0.0, 0.0], dtype=PETSc.ScalarType)
bc_l = fem.dirichletbc(u_zero, fem.locate_dofs_topological(U, f_dim, bc_facets), U)
bcs = [bc_l]
Define external load
load_points = [(1, lambda x: np.logical_and(x[0]==nelx, x[1]<=2))]
for (marker, locator) in load_points:
    facets = mesh.locate_entities(msh, f_dim, locator)
    facet_indices.append(facets)
facet_indices = np.array(np.hstack(facet_indices), dtype=np.int32)
facet_markers = np.array(np.hstack(facet_markers), dtype=np.int32)
facet_tag = mesh.meshtags(msh, f_dim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = ufl.Measure("ds", domain=msh, subdomain_data=facet_tag)
f = ufl.dot(v, fem.Constant(msh, PETSc.ScalarType((0.0, -1.0)))) * ds(1)
Set up the variational problem and solver (using SIMP)
k = ufl.inner(density ** penal * sigma(u), ufl.grad(v)) * ufl.dx
problem = fem.petsc.LinearProblem(k, f, bcs)
u_sol = problem.solve()
Then, the result for u_sol array is
array([-17.05014904, -31.16299225, -23.40409419, -70.10238634,
        -1.23442586, -66.45633149,   0.17561615, -26.80259435,
         0.        ,   0.        ,  20.43334505, -65.04736033,
         0.        ,   0.        ,  15.06233617, -27.34430426,
         0.        ,   0.        ])
the result I want to get (reliable results from code written with the dolfin library)
array([ 2.19098143e+01, -6.77188329e+01,  4.26325641e-15, -6.44827586e+01,
        1.51458886e+01, -2.69893899e+01, -1.51458886e+01, -2.69893899e+01,
        0.00000000e+00,  0.00000000e+00,  1.08212540e-15, -2.81564987e+01,
       -2.19098143e+01, -6.77188329e+01,  0.00000000e+00,  0.00000000e+00,
        0.00000000e+00,  0.00000000e+00])
I think that different results were obtained because of wrong coding when applying boundary condition or external load. Which part of the code could be considered bad?
3] Declare ‘FunctionSpace’ in the dolfinx environment, and arosed question how to convert the calculated value stored in the ‘FunctionSpace’ location to a numpy array.
Extending the above code example,
Assuming that the u_sol value is well obtained, how to map this value to a numpy array?
(In the dolfin library, mapping was done as ‘project’)
project(psi(u_sol), D0).vector()[:]
(but I do not know how to do it in the dolfinx library.)
  1. Run the command
    python3 -c "import dolfinx as dfx;print(dfx.__version__);print(dfx.git_commit_hash)"
    which produces on my machine:
    0.5.0
    2aaf3b20dbaedcbd3925a9640c3859deec563e02
  2. I obtain identical results with the code you provided and a code that I developed in old FEniCS (old FEniCS on the left, DOLFINx on the right):
    Keep in mind that the dof ordering in old FEniCS and DOLFINx may be different. Also, in your DOLFINx code you apply a traction to the entire right boundary (load_points = [(1, lambda x: np.logical_and(x[0]==nelx, x[1]<=2))]), while your schematic appears to show a point load on the bottom-right corner. Is your code correctly implementing the intended boundary condition?
  3. I assume that you are asking how to project the strain energy density into a DG-0 function. To do that, you can set up and solve the linear variational problem that represents a projection, i.e.:
    \int_\Omega {\psi \phi \, \mathrm{d}x} = \int_\Omega {\psi(u_h) \phi \, \mathrm{d}x}
    where \psi is the quantity you want to solve for, i.e. the DG-0 projection of the strain energy density, \phi is a test function, and \psi(u_h) is the strain energy density calculated from the (known) discrete solution u_h. This can be implemented as:
    psi_trial = ufl.TrialFunction(D)
    psi_test = ufl.TestFunction(D)
    a = psi_trial * psi_test * ufl.dx
    L = psi(u_sol) * psi_test * ufl.dx
    projection_problem = fem.petsc.LinearProblem(a, L, [])
    psi_sol = projection_problem.solve()
    print(psi_sol.x.array)
    producing
    [ 79.91107539 111.61468049 211.04645563  66.28836385 143.69740152
     122.77015115  28.56753585 308.35397476]
Hi, @conpierce8
Thank you very much for the detailed reply. :slight_smile:
1] I checked the version with the command you gave me!
Using command produces on my PC:
0.4.1
unknown
→ As an additional question, my PC is using version 0.4.1, how do I update the version(ex. update to 0.5.0)?
2] The reason why I wrote the ‘Define external load’ part in the dolfinx code I wrote like the code above
load_marker = MeshFunction("size_t", msh, msh.topology().dim() - 1)
CompiledSubDomain("x[0]==l && x[1]<=2", l=nelx).mark(load_marker, 1)
ds = Measure("ds")(subdomain_data=load_marker)
the code that in the dolfin library as follows to apply the load to the bottom-right corner point. Knowing that the dolfinx library should be applied similarly, I wrote it by quoting the above code using ‘mark’. However, I didn’t know that the code applied loads to the entire right side boundary.
Then, how should I write the code to load the bottom-right corner point in dolfinx?
In my opinion, the difference in u_sol value between the dolfin library code and the code made with dolfinx library is the dolfin library additionally allocates a very small subdomain when the load is applied to the bottom-right corner.
I think this part needs to be corrected in dolfinx code, is it not a big deal?
Note that a more scalable approach is to use interpolation, as explained in Implementation — FEniCSx tutorial
I guess you used apt-get to install DOLFINx, and then you would have to use apt-get update and apt-get upgrade to get the latest release
I’m not quite sure what is the status of releases to apt, @dparsons can probably give a concrete answer to this.
Debian has had some problems with the pmix (MPI) package. That’s now resolved so dolfinx 0.5 packages will be built soon.
1] The answer to the question is now complete. Thank you! :smile:
Looking forward to the next update! Thank you! :slightly_smiling_face:
I would not expect this behavior when using a built-in mesh. Can you share your DOLFIN code?
I used a simple rectangular mesh in dolfin. Here’s the code:
mesh = RectangleMesh(Point(0, 0), Point(nelx, nely), nelx, nely, "right/left")
The constraint was applied only to the left part of the domain as follows
bc = CompiledSubDomain("near(x[0], 0.0, tol) && on_boundary", tol=1e-14)
bcs = [DirichletBC(U, Constant((0.0, 0.0)), bc)]
And as in the above reply, load condition was given,
load_marker = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
f = dot(v, Constant((0.0, -1.0))) * ds(1)
and u_sol was obtained with
k = inner(density**penal*sigma(u), grad(v)) * dx
problem = LinearVariationalProblem(k, f, u_sol, bcs=bcs)
solver = LinearVariationalSolver(problem)
solver.solve()
I composed the dolfin code like this, and I thought that the same value (even if the dof indexing is different) should appear in the dolfinx code, but it did not come out.
I don’t know why the values are different. :disappointed_relieved:
You are getting different results because your old DOLFIN code and DOLFINx code are using different meshes ("right/left" for old DOLFIN and dolfinx.mesh.DiagonalType.right for DOLFINx). See screenshot below
If you change your DOLFINx mesh generation code to the following, you should see that the solutions are identical
    MPI.COMM_WORLD,
    (nelx, nely),
    cell_type=mesh.CellType.triangle,
    diagonal=mesh.DiagonalType.right_left,
As a final note, your code in old DOLFIN is also applying the traction to the entire right boundary, not a point load at the bottom right corner. The following statement marks all facets on the right boundary because x[1]<=2 is true for all points on the right boundary.
If you want to apply a point load at the bottom right corner, you should use PointSource in old DOLFIN (see here and here). Unfortunately, the reimplementation in DOLFINx is not complete yet; see PointSource in dolfinx.
The problem seems to have been resolved! I learned a lot about dolfin and dolfinx thanks to @conpierce8.
Thank you so much!! :smile: :laughing:
It was confirmed that almost same value was derived when the mesh was given in dolfinx. Awesome!
I thought that dolfin was also giving an external load to the Point, but I found out that it wasn’t. (Sorry for the confusion.)
