How do i resolve this issue of MixedElement in google colab
Exception Traceback (most recent call last)
in <cell line: 8>()
62 P2 = dolfin.VectorElement(“CG”, mesh.ufl_cell(), 2)
63 TH = dolfin.MixedElement([P2, P1])
—> 64 W = dolfin.FunctionSpace(mesh, TH)
65
66 # define other spaces
7 frames
/usr/local/lib/python3.10/dist-packages/ufl/log.py in error(self, *message)
170 “Write error message and raise an exception.”
171 self._log.error(*message)
→ 172 raise self._exception_type(self._format_raw(*message))
173
174 def begin(self, *message):
Exception: Unknown ufl object type MixedElement
Note: I’m using FEniCS 2019.1.0.
Please clarify how you installed FEniCS on Colab.
If you used FEM on Colab, I purposely disabled ufl because of Announcement: ufl_legacy and legacy dolfin, so you must ufl_legacy instead of ufl.
i used the command:
!pip install fenics
Please use Packages — FEM on Colab instead
Thank you very much. The recommended approach of using the Packages — FEM on Colab worked.
