i want to apply a point boundary condition like the figure show. point load and point support. how to perform it in FEniCS?
Hello
Lets say you want to apply a point load equal to 100 N downward in Y direction at coordinate (5,5):
class Load(UserExpression):
def __init__(self, **kwargs):
super().__init__(degree=kwargs["degree"])
self.point = kwargs['point']
self.value = kwargs['value']
def eval(self, value, x):
if near(x[0], self.point[0]) and near(x[1], self.point[1]):
value[0] = self.value[0]
value[1] = self.value[1]
value[0] = 0
value[1] = 0
def value_shape(self):
return (2,)
You can call it by:
T = Load(point=(5, 5), value=(0, -100), degree=1)
Regarding applying boundary condition at a specific point:
Lest say you want to fix a point at coordinate (0,0). You can do as following:
def point(x, on_boundary):
tol = DOLFIN_EPS
return (abs(x[0] - 0) < tol) and (abs(x[1] -0) < tol)
BC_POINT = DirichletBC(V, Constant((0., 0.)), point,method="pointwise")
thanks leo, i can figure it out
I clumsily made a few changes to extend the ‘Load’ class to a 3d cantilever beam model, and it seemed to work. However, I need to go further and use this functionality to apply the load to multiple points, say, along a boundary, but I’m afraid I don’t know how the class produces the output it does. I’ll explain.
You can see how I modified the above code in the following example:
from ufl import nabla_div
#Updated class definition here
if near(x[0], self.point[0]) and near(x[1], self.point[1]) and near(x[2], self.point[2]):
value[2] = self.value[2]
value[0] = 0
value[1] = 0
value[2] = 0
return (3,)
# Scaled variables
l = 2; W = 0.2
mu = 1
rho = 1
delta = W/l
gamma = 0.4*delta**2
beta = 1.25
lambda_ = beta
g = gamma
mesh = BoxMesh(Point(0, 0, 0), Point(l, W, W), 10, 3, 3)
# Define boundary condition
tol = 1E-14
def clamped_boundary(x, on_boundary):
return on_boundary and x[0] < tol
bc = DirichletBC(V, Constant((0, 0, 0)), clamped_boundary)
# Define strain and stress
def sigma(u):
return lambda_*nabla_div(u)*Identity(d) + 2*mu*epsilon(u)
d = u.geometric_dimension() # space dimension
f = Constant((0, 0, 0))
T = Load(point=(2, 0, 0), value=(0, 0, -2), degree=2)
L = dot(f, v)*dx + dot(T, v)*ds
# Compute solution
solve(a == L, u, bc)
When I inspect the variable T, it says:
So, three questions:
- Where in the class definition or execution of “Load” is the node address accessed in order to create the variable?
- I assume that “degree” is the polynomial order of the element. What should inform this choice?
- And most importantly, how can I redefine the class to apply the load on multiple nodes on a boundary? In this case, it would be on all nodes along the boundary near x[0]=2 and x[2] = 0.2.
Thanks for your help!
Could someone tell me what is the meaning of degree=1 in Load(point=(5, 5), value=(0, -100), degree=1)?
Thank you.
