How to apply a load on a single point or a node
I am using FEniCs to apply a load on particular point of a square mesh. When checking people has proposed to use Pointwise but it seems to be a method to fix a displacement, others has proposed to use PointSource but this also is used for one component of a vector or I don’t how to use it correctly.
Any help please.
Here is the code I am using:
from future import print_function
#!/usr/bin/env python3
-- coding: utf-8 --
Created on Thu Dec 24 18:36:09 2020
@author: pierre
Nx = 1
Ny = 1
L = 1Nx
H = 1
Ny
mesh = RectangleMesh(Point(0., 0.), Point(L, H), Nx, Ny)
E = Constant(1e9)
nu = Constant(0.3)
beta = E/(1-nu**2)
C = beta*as_matrix([[1, nu, 0],[nu, 1, 0],[0, 0, (1-nu)/2]])
def eps(v):
return sym(grad(v))
def strain2voigt(e):
“”“e is a 2nd-order tensor, returns its Voigt vectorial representation”""
return as_vector([e[0,0],e[1,1],2*e[0,1]])
def voigt2stress(s):
s is a stress-like vector (no 2 factor on last component)
returns its tensorial representation
return as_tensor([[s[0],s[2]],[s[2],s[1]]])
def sigma(v):
return voigt2stress(dot(C,strain2voigt(eps(v))))
class Top(SubDomain):
return near(x[1],L) and on_boundary
class Left(SubDomain):
return near(x[0],0) and on_boundary
class Bottom(SubDomain):
return near(x[1],0) and on_boundary
class point(SubDomain):
return near(x[0],Nx) and near(x[1],Ny)
exterior facets MeshFunction
facets = MeshFunction(“size_t”, mesh, 1)
facets.set_all(0)
Top().mark(facets, 1)
Left().mark(facets, 2)
Bottom().mark(facets, 3)
point().mark(facets,4)
ds = Measure(‘ds’)[facets]
Define function space
V = VectorFunctionSpace(mesh, ‘Lagrange’, 2)
Define variational problem
du = TrialFunction(V)
u_ = TestFunction(V)
u = Function(V, name=‘Displacement’)
a = inner(sigma(du), eps(u_))*dx
uniform traction on top boundary
T = Constant((10,10))
l = dot(T, u_)*ds(4)
symmetry boundary conditions
bc = [DirichletBC(V, Constant((0.,0.)), facets, 2),
DirichletBC(V, Constant((0.,0.)), facets, 3),
DirichletBC(V, T, point(), method=“pointwise”)]
solve(a == l, u, bc)
plt.figure(1)
plot(u, title = “u”)
Please format your code appropriately, using 3x` encapsulation.you should also consider the answers in: Implement point source in the variational formulation
Ok, Thank you I am going to consider your instructions.
Hi Dokken,
I considered the answers like you advise me. The fragment of code that I modified to use is the one below. I thought that X0 is the place where I can apply the load but it seems not to be so. Even if I change the values of X0, there is no effect on the point where I want to apply the load.
Help please
class Delta(UserExpression):
    def __init__(self, eps, x0, **kwargs):
        self.eps = eps
        self.x0 = x0
        UserExpression.__init__(self, **kwargs)
    def eval(self, values, x):
        eps = self.eps
        values[0] = 10    #eps/pi/(np.linalg.norm(x-self.x0)**2 + eps**2)
        values[1] = 10
        # values[2] = 0
    def value_shape(self): return (2, )
delta = Delta(eps=1E-4, x0=np.array([1, 1]), degree=5)
# l = inner(Constant(100)*delta, u_)*dx
# delta = Constant((10, 10))
l = inner(delta, u_)*dx
Just have a look at the plot of a source function, in for instance paraview:
mesh = UnitSquareMesh(20, 20)
V = VectorFunctionSpace(mesh, "CG", 1)
        self.eps = eps
        self.x0 = x0
        eps = self.eps
        values[0] = eps/pi/(np.linalg.norm(x-self.x0)**2 + eps**2)
        values[1] = 0
u = project(delta, V)
File("u.pvd") << u
As you are not specifying what is not working I can’t you help you more.
source
Thanks for your spontaneous answer. To be more clear, my idea is to apply a load in x and y direction at the point of coordinates (1, 1). So I have changed the lines below
values[1] = 0
into
values[1] = 10
but as the last two lines are independent of x0, I am not getting a satisfied result.
Or may be you can clearly explain me how the line below is working in the code
Hope that I have made sens to my question now.
Thanks
As you observe in the code I gave you, it gave you a point source in one direction.
The x dependence above is what creates the point source as you divide epsilon by the distance from x0. If you apply values[0]=10, values[1]=10, you set a constant source all over the domain
Hi dokken,
Excuse me for I come back to the same question. I want to control the value of the values[0], so I print it in order to control the value I will obtain but I obtained too many values.
 print(values[0])
See the result I obtain
3.183098830006919e-05
3183.0988618379065
4.9735918939093545e-05
8.841941037273602e-05
0.00019894366643089014
0.000795774516515848
2.4867959663827704e-05
4.420970580039168e-05
9.947183632393973e-05
0.000397887307993825
1.940913928310224e-05
2.340513851788801e-05
2.7440507193081033e-05
3.060671953106911e-05
3.9788735275614644e-05
4.681027669158277e-05
6.121343847354747e-05
7.957746955651093e-05
0.00015915493513414867
1.591549422961206e-05
3183.0988618379065
3183.0988618379065
3183.0988618379065
I want to know exactly the value I am giving to values[0]. Is it possible ?
That is I want it to take only one value the I can change as I wish.
Thanks.
values[0] is of the dimension of a scalar function space (print x to see this). This means that you are evaluating your function at a set of coordinates at once. This, if you want to control a specific value in this array, you need to identify which entry you would like to change (by inspecting x).
Hope you are ok.
I am trying to solve a 3D (Orthotropic) linear elasticity in FEniCs but still getting an error message that I am not understanding very well.
Code
from ufl import *
N = 2
mesh = UnitCubeMesh(N, N, N)
# plt.figure(1)
# plot(mesh)
# plt.show()
Ex, Ey, Ez, nuxy,nuxz,nuyz, Gxy, Gxz, Gyz = 100., 10.,1., 0.3, 0.2, 0.1, 5., 4., 3.
S = as_matrix([[1./Ex,-nuxy/Ex,-nuxz/Ex,0.,0.,0.],[-nuxy/Ex,1./Ey,-nuyz/Ey,0.,0.,0.],[-nuxz/Ex,-nuyz/Ey,1/Ez,0.,0.,0.],[0.,0.,0.,1/Gxy,0.,0.],[0.,0.,0.,0.,1/Gxz,0.],[0.,0.,0.,0.,0.,1/Gyz]])
C = inv(S)
print('S',S)
print('C',C)
def eps(v):
    return sym(grad(v))
def strain3voigt(e):
    """e is a 2nd-order tensor, returns its Voigt vectorial representation"""
    return as_vector([e[0,0],e[1,1],e[2,2],2*e[0,1],2*e[0,2],2*e[1,2]])
def voigt3stress(s):
    return as_tensor([[s[0],s[3],0.],[s[3],s[1],0.],[0.,0.,s[2]]])
def sigma(v):
    return voigt3stress(dot(C,strain3voigt(eps(v))))
        return near(x[2],1) and on_boundary
        return near(x[2],0) and on_boundary
class Right(SubDomain):
        return near(x[1],1) and on_boundary
class Direct(SubDomain):
# exterior facets MeshFunction
facets = MeshFunction("size_t", mesh, 2)
facets.set_all(0)
Right().mark(facets,4)
Direct().mark(facets,5)
ds = Measure('ds', subdomain_data=facets)
# Define function space
V = VectorFunctionSpace(mesh, 'CG', 2)
u = Function(V, name='Displacement')
# uniform traction on top boundary
T = Constant((0.,0.,1e-3))
l = dot(T, u_)*ds(1)
# symmetry boundary conditions
bcs = [DirichletBC(V.sub(0), Constant(0.), facets, 2),
      DirichletBC(V.sub(1), Constant(0.), facets, 3),
      DirichletBC(V.sub(2), Constant(0.), facets, 5)]
problem = LinearVariationalProblem(a, l, u, bcs)
solver = LinearVariationalSolver(problem)
solver.solve()
solver.parameters['linear_solver'] = 'cg'
solver.parameters['preconditioner'] = 'ilu'
cg_prm = solver.parameters['krylov_solver']
cg_prm['absolute_tolerance'] = 1E-7
cg_prm['relative_tolerance'] = 1E-4
cg_prm['maximum_iterations'] = 1000
Error message
UFLException: adj_expr not implemented for dimension 6.
Is it my Voigt notation that is not correct ?
How to correct my program to solve a 3D orthotropic linear elasticity in FEniCs?
please help me
Hi, you cannot use the UFL inv operator to invert the 6x6 compliance matrix. As said in the corresponding doc, inv is implemented only for 2x2 or 3x3 since it uses a symbolic formula for the inversion. You must therefore either implement yourself the expression of C or go through numpy for instance to invert S as a numpy array first.
Hi Bleyerj, Thank you
I hope you are ok,
I am trying to solve a linear elasticity problem.
Figure 2021-06-02 162139
But my objective is to assign different Young modulus to the different parts of the mesh above. For instance I want to assign E1 to the yellow part, E2 to the green part…
Please can you show me the way to do so?
I am reading documents but still not understanding very well.
Thanks
See for instance:
Or
https://fenicsproject.org/olddocs/dolfin/latest/python/demos/subdomains-poisson/documentation.html?highlight=subdomain
Hi Dokken,
Based on your advice to see the link below:
I have developed the code below:
# -*- coding: utf-8 -*-
Created on Thu Jun  3 08:36:47 2021
@author: pierre
# Create the mesh
Nx, Ny = 1 , 1
L, H = 1, 1
mesh = RectangleMesh(Point(0., 0.), Point(L, H), Nx, Ny, 'left')
E0 = Constant(2.1e11)
nu0 = Constant(0.3)
beta0 = E0/(1-(nu0*nu0))
C0 = as_matrix([[beta0, beta0*nu0, 0],[beta0*nu0, beta0, 0],[0, 0, beta0*(1-nu0)/2]])
E1 = Constant(70e9)
nu1 = Constant(0.3)
beta1 = E1/(1-(nu1*nu1))
C1 = as_matrix([[beta1, beta1*nu1, 0],[beta1*nu1, beta1, 0],[0, 0, beta1*(1-nu1)/2]])
def eps(v):
    return sym(grad(v))
def sigma0(v):
    return voigt2stress(dot(C0,strain2voigt(eps(v))))
def sigma1(v):
    return voigt2stress(dot(C1,strain2voigt(eps(v))))
# Create classes for defining parts of the boundaries
        return near(x[0], 0.0)
        return near(x[0], 1.0)
        return near(x[1], 0.0)
        return near(x[1], 1.0)
# Create classes for defining parts of the interior of the domain
tol = 1E-14
class Omega_0(SubDomain):
          return x[1] <= 0.5 + tol
class Omega_1(SubDomain):
          return x[1] >= 0.5 - tol
# Initialize sub-domain instances
left = Left()
top = Top()
right = Right()
bottom = Bottom()
Omega_0 = Omega_0()
Omega_1 = Omega_1()
# Initialize mesh function for interior domains
domains = MeshFunction("size_t", mesh, mesh.topology().dim())
domains.set_all(0)
Omega_0.mark(domains, 1)
Omega_0.mark(domains, 2)
boundaries = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
boundaries.set_all(0)
left.mark(boundaries, 1)
top.mark(boundaries, 2)
right.mark(boundaries, 3)
bottom.mark(boundaries, 4)
V = VectorFunctionSpace(mesh, 'CG', 1)
u = Function(V, name = 'Displacement')
# Define new measures associated with the interior domains and
# exterior boundaries
dx = Measure('dx', domain=mesh, subdomain_data=domains)
# Define Dirichlet boundary conditions at bottom boundary
bcs = DirichletBC(V, Constant((0., 0.)), boundaries, 4)
a = inner(sigma0(du), eps(u_))*dx(1) + inner(sigma1(du), eps(u_))*dx(2)
T = Constant((0, 1e7))
l = dot(T, u_)*ds(2)
solve(a == l, u, bcs)
But I have the following error message:
*** Error:   Unable to set given (local) rows to identity matrix.
*** Reason:  some diagonal elements not preallocated (try assembler option keep_diagonal).
*** Where:   This error was encountered inside PETScMatrix.cpp.
*** Process: 0
I tried to solve the problem but unsuccessfully.
Please I need your help
Sorry Dokken,
I see my error
Thanks
Thank you again for the help,
I have now solved the problem of defining subdomains with different Young modulus.
Now suppose I have a domain meshed with 3 node triangles like the figure below:
Figure 2021-06-03 114705
And I want to give two different Young modulus to triangles among the triangles in the domain. How can I do that?
I have tried with what is done in the link below:
https://fenicsproject.discourse.group/t/how-to-assign-different-material-properties-to-elements-linear-elasticity/3742
But I was not able to solve my problem.
Hope I make sens.
You need to make a minimal example, as I have already linked you to how to make a discontinuous dolfin function that can store different material properties on each cell. Please follow the structure of the posts highlighted in Read before posting: How do I get my question answered? - #4 by nate
Sorry Dokken,
As you have linked me to how to overcome my problem, I have developed the code below
# Create the mesh
Nx, Ny = 4 , 4
L, H = 1, 1
nu0 = Constant(0.3)
E1 = Constant(2.1e9)
nu1 = Constant(0.3)
def eps(v):
    return sym(grad(v))
def sigma0(v):
def sigma1(v):
tol = 1E-14
left = Left()
top = Top()
right = Right()
bottom = Bottom()
Omega_0 = Omega_0()
Omega_1 = Omega_1()
domains.set_all(0)
Omega_1.mark(domains, 1)
a = inner(sigma0(du), eps(u_))*dx(0) + inner(sigma1(du), eps(u_))*dx(1)
T = Constant((0, -1e7))
and it is working successfully based on what I have seen here:
But my problem now is to assign a different Young modulus to a 3 node triangular element as it is done in the following code:
E_VALUES = [7.5E6, 12E6, 83E6, 42E6,33E6,98E6]
mesh = BoxMesh(Point(0, 0, 0), Point(1, 1, 1), 1, 1, 1)
DG = FunctionSpace(mesh, "DG", 0)
E = Function(DG)
E.vector()[:] = E_VALUES
The code above is assigning different young modulus to all the elements in the mesh.
Now suppose I have 1000 elements and I want to assign different Young modulus to one of them (E1 to one of them and E2 to the 999 other elements); How can I modify the code above to solve my problem?
Thanks again
