Hi all, I am using dolfin/C++.
What I have: a set of 2D images (pgm format), each with the same resolution, deriving from CT DICOM;
What I want to do: create a scalar 3D P1 function which allocates the stack of 2D images (a so-called 3D-image).
What I did:
std::shared_ptr<dolfin::Function> setupDICOM::amReadDicoms(std::string name, int n1, int n2, double dx, double dy, double dz)
int imageWidth, imageHeight;
std::ifstream infile(name+"/slice"+std::to_string(n1)+".pgm");
std::stringstream ss;
std::string inputLine = "";
getline(infile,inputLine);
std::string spool = "";
spool += inputLine[0]; spool += inputLine[1]; spool += inputLine[2];
std::istringstream iss1(spool);
iss1 >> imageWidth;
spool = "";
spool += inputLine[4]; spool += inputLine[5]; spool += inputLine[6];
std::istringstream iss2(spool);
iss2 >> imageHeight;
ss << infile.rdbuf();
auto p1 = std::make_shared<dolfin::Point>(0.0,0.0,0.0);
auto p2 = std::make_shared<dolfin::Point>(dx*imageWidth,dy*imageHeight,dz*(n2-n1));
auto Th = std::make_shared<dolfin::BoxMesh>(*p1,*p2,imageWidth-1,imageHeight-1,n2-n1-1);
auto Vh = std::make_shared<varfs::CoefficientSpace_mu>(Th);
auto image = std::make_shared<dolfin::Function>(Vh);
std::vector<double> unrolledImge;
for(int kkl=0; kkl<n2-n1; kkl++)
int index = n1+kkl;
std::string str = name+"slice";
str+=std::to_string(index);
str+=".pgm";
std::ifstream infileInner(str);
if(infileInner.fail())
return nullptr;
std::stringstream ssInner;
std::string inputLineInner = "";
getline(infileInner,inputLineInner);
ssInner << infileInner.rdbuf();
int spool2;
ssInner >> spool2;
for(int ik=0; ik<imageHeight; ik++)
for(int jk=0; jk<imageWidth; jk++)
unsigned char px;
ssInner >> px;
unrolledImge.push_back(px);
std::vector<std::size_t> dof2vert = dof_to_vertex_map(*Vh);
int nnn = unrolledImge.size();
for(int k=0; k<unrolledImge.size(); k++)
image->vector()->setitem(dolfin::la_index(k),unrolledImge[dof2vert[k]]);
return image;
What it produces: something, but the degrees of freedom are totally mixed up, showing all possible kind of patterns. I know how to do this with only one image (https://fenicsproject.org/qa/9339/fenics-image-processing-because-matrix-expression-poisson/), but even after 100 index permutations I can’t understand how how these degrees of freedom are ordered. Any suggestion?
