How to apply component wise dirichlet boundary condition on a point
Hello Everyone, I am solving a plane strain periodic boundary condition problem for linear elastic analysis. In order to constraint the geometry, I am thinking of applying dirichlet on a point on the model.
Here, I want to constraint the point in the present example such it is constrained in x-direction, however, it is free to displace in y-direction. Such that during any applied load in y-direction, it is free to displace in y-direction, however, since x-direction is constrained which is at the x=0.05, my model is constraint enough for solution to run.
My question is how do I apply dirichlet boundary condition on a point in just x-direction.
Here, is my MWE for the problem.
Here is my mesh
cl__1 = 0.001;
Point(1) = {0.01, 0.07000000000000001, 0, cl__1};
Point(2) = {0.03, 0.07000000000000001, 0, cl__1};
Point(3) = {0.03, 0.08, 0, cl__1};
Point(4) = {0.01, 0.08, 0, cl__1};
Point(5) = {0.04, 0.07000000000000001, 0, cl__1};
Point(6) = {0.06, 0.07000000000000001, 0, cl__1};
Point(7) = {0.06, 0.08, 0, cl__1};
Point(8) = {0.04, 0.08, 0, cl__1};
Point(9) = {0.07000000000000001, 0.07000000000000001, 0, cl__1};
Point(10) = {0.09, 0.07000000000000001, 0, cl__1};
Point(11) = {0.09, 0.08, 0, cl__1};
Point(12) = {0.07000000000000001, 0.08, 0, cl__1};
Point(13) = {0, 0.06, 0, cl__1};
Point(14) = {0.1, 0.06, 0, cl__1};
Point(15) = {0.1, 0.09, 0, cl__1};
Point(16) = {0, 0.09, 0, cl__1};
Point(17) = {0, 0, 0, cl__1};
Point(18) = {0.1, 0, 0, cl__1};
Point(19) = {0.15, 0.1, 0, cl__1};
Point(20) = {-0.05, 0.1, 0, cl__1};
Line(1) = {4, 1};
Line(2) = {1, 2};
Line(3) = {2, 3};
Line(4) = {3, 4};
Line(5) = {8, 5};
Line(6) = {5, 6};
Line(7) = {6, 7};
Line(8) = {7, 8};
Line(9) = {12, 9};
Line(10) = {9, 10};
Line(11) = {10, 11};
Line(12) = {11, 12};
Line(13) = {13, 14};
Line(14) = {14, 15};
Line(15) = {15, 16};
Line(16) = {16, 13};
Line(17) = {17, 18};
Line(18) = {18, 19};
Line(19) = {19, 20};
Line(20) = {20, 17};
Curve Loop(1) = {1, 2, 3, 4};
Plane Surface(1) = {1};
Curve Loop(2) = {5, 6, 7, 8};
Plane Surface(2) = {2};
Curve Loop(3) = {9, 10, 11, 12};
Plane Surface(3) = {3};
Curve Loop(4) = {1, 2, 3, 4, -8, -7, -6, -5, -12, -11, -10, -9, -15, -14, -13, -16};
Plane Surface(4) = {4};
Curve Loop(5) = {16, 13, 14, 15, -20, -19, -18, -17};
Plane Surface(5) = {5};
Physical Line("bottom") = {17};
Physical Line("right") = {18};
Physical Line("top") = {19};
Physical Line("left") = {20};
Physical Line("EF") = {13};
Physical Line("FG") = {14};
Physical Line("GH") = {15};
Physical Line("HE") = {16};
Physical Line("IJ") = {2};
Physical Line("JK") = {3};
Physical Line("KL") = {4};
Physical Line("LI") = {1};
Physical Line("MN") = {6};
Physical Line("NO") = {7};
Physical Line("OP") = {8};
Physical Line("PM") = {5};
Physical Line("QR") = {10};
Physical Line("RS") = {11};
Physical Line("ST") = {12};
Physical Line("TQ") = {9};
Physical Surface("my_surface") = {5};
Physical Surface("EFGH") = {4};
Physical Surface("IJKL") = {1};
Physical Surface("MNOP") = {2};
Physical Surface("QRST") = {3};
Field[1] = Box;
Field[1].Thickness = 0;
Field[1].VIn = 0;
Field[1].VOut = 0;
Field[1].XMax = 0;
Field[1].XMin = 0;
Field[1].YMax = 0;
Here is my code
import os
import sys
from dolfinx.cpp.mesh import to_type, cell_entity_type
from dolfinx import mesh, fem, io, common, default_scalar_type
import dolfinx.fem.petsc
from dolfinx.io import VTXWriter, distribute_entity_data, gmshio
from dolfinx.mesh import create_mesh, meshtags_from_entities
from ufl import (FacetNormal, FiniteElement, as_matrix, Identity, Measure, TestFunction, TrialFunction, VectorElement, as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym)
import dolfinx_mpc.utils
from dolfinx_mpc import LinearProblem, MultiPointConstraint
# Mesh
mesh_path = "WPright-medium.msh"
domain, cell_markers, facet_markers = gmshio.read_from_msh(mesh_path, MPI.COMM_WORLD, gdim=2)
gdim = 2
def strain(u, repr ="vectorial"):
    eps_t = sym(grad(u))
    if repr =="vectorial":
        return as_vector([eps_t[0,0], eps_t[1,1], 2*eps_t[0,1]])
    elif repr =="tensorial":
        return eps_t
E = fem.Constant(domain, 200000000000.0)
nu = fem.Constant(domain,0.3)
lmbda = E*nu/(1+nu)/(1-2*nu)
mu = E/2/(1+nu)
C = as_matrix([[lmbda+2*mu, lmbda, 0.0],[lmbda, lmbda+2*mu,  0.0],[0.0, 0.0, mu]])
def stress(u, repr ="vectorial"):
    sigv = dot(C, strain(u))
        return sigv
        return as_matrix([[sigv[0], sigv[2]], [sigv[2], sigv[1]]])
# Define Function Space
degree = 2
V = fem.functionspace(domain, ("P",degree, (gdim,)))
#Cyclic Symmetry Condition
def periodic_relation(x):
    out_x = np.zeros(x.shape)
    out_x[0] = x[1]*(-0.05/0.1)
    out_x[1] = x[1]
    return out_x
#Define Variational Problem
du = TrialFunction(V)
u_ = TestFunction(V)
u = fem.Function(V, name = "Displacement")
a_form = inner(stress(du),strain(u_))*dx
T = fem.Constant(domain, 1000000.0)
n = FacetNormal(domain)
ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_markers)
L_form = dot(T*n,u_) * ds(3)
V_ux, _ = V.sub(0).collapse()
V_uy, _ = V.sub(1).collapse()
ux0 = fem.Function(V_ux)
uy0 = fem.Function(V_uy)
# bc at point
def pointt(x):
    return np.logical_and(np.isclose(x[0], 0.05), np.isclose(x[1], 0))
middof = fem.locate_dofs_geometrical(V, pointt)
u_center = fem.Function(V)
u_center.x.array[:] = 0
bc_center = fem.dirichletbc(u_center, middof)
bcs = [bc_center]
with common.Timer("~~Periodic: Compute mpc condition"):
    mpc = MultiPointConstraint(V)
    mpc.create_periodic_constraint_topological(V.sub(0), facet_markers, 2, periodic_relation, bcs, default_scalar_type(1))
    mpc.finalize()
WPsolve = LinearProblem(a_form, L_form, mpc, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = WPsolve.solve()
uh.name = "u"
I will illustrate this on a unit square (with a non-zero condition to show that it is applied).
In the following example I have constrained the x component at (0.5,0.5) to be 0.3:
V = dolfinx.fem.functionspace(mesh, ("Lagrange", 1, (2,)))
def single_dof(x):
    return np.isclose(x[0], 0.5) & np.isclose(x[1], 0.5)
constrained_vertex = dolfinx.mesh.locate_entities(mesh, 0, single_dof)
constrained_dof = dolfinx.fem.locate_dofs_topological(V.sub(0), 0, constrained_vertex)
u_bc = dolfinx.fem.Constant(mesh, 0.3)
bc_x = dolfinx.fem.dirichletbc(u_bc, constrained_dof, V.sub(0))
uh = dolfinx.fem.Function(V)
uh.x.array[:] = 0.0
dolfinx.fem.set_bc(uh.x.array, [bc_x])
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "output.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
    xdmf.write_function(uh)
Thanks Jorgen for your response. Then, how do I call the bcs for my solving of the problem with mpc as shown in here
The whole point is that bc_x is a standard DirichletBC object, that you can send in to the linear problem as any other bc, simply define bcs=[bc_x] before creating WPsolve.
Thank you Jorgen for your prompt response. I was able to implement your suggestion, however, I am not able to constraint the model as I earlier thought for my analysis. As you know that I am solving a plane strain linear elastic problem with Periodic Boundary Condition and as per your suggestion, I could constraint the vertex in x-direction and in y-direction (together or separately). However, my results show large deflections when I constaint the vertex only in the x-direction.
I tried the same with COMSOL and it was successfull in constraining the model.
I show some images for problem definition and results from COMSOL and FENICSX.
I am attaching here some images to explain you my problem
By constraining only in “x” direction- your model can move arbitrarily in the y-direction, which I guess is what you are seeing (inspect the x and y components of u in Paraview rather than just looking at the magnitudes).
Hi Jorgen, I just plotted the displacement magnitudes for comparison. I have seen contour plots of u in x and y direction and for the 3rd case where only x is constrained for the vertex, the u displacements are 1e7 order of magnitude as if its free. However, if we see the results from COMSOL, the displacements are within of the O(1e-7). What other option I can try here? Any suggestions…
Could you report how these figures above look like if you only consider the x-component and then only the y-component separately in the post-processing?
As I have already stated, if you only constrain in x-direction, you can translate in y direction without violating the PDE.
Dear Jorgen, please find attached results for x and y translation invidually for only x and y constrains respectively.
As you can clearly see by these pictures, it is not sufficient to only constrain one of the directions.
But then, how do you suggest I constrain the system without impacting the solution. As here, if I constraint the top and bottom boundary, it affects the solution. Also, as presented earlier, the results from COMSOL showed that even if with x-directional constraint, the system did not result in large displacements.
You can add nullspace handling to the solver, along the lines of:
Saying that COMSOL gave you a finite solution doesn’t really help much, as COMSOL is a commercial package, which most people:
  1. Doesn’t have access to (as it is quite expensive)
  2. You haven’t described how this is implemented in COMSOL, or justified why the solution should be allowed to slide arbitrarily in the y-direction. What should the expected movement of the whole bottom surface be in y-direction?
So, if you assume this trapezoid as a sector of a long vessel or a tank, then assume it as a plane strain condition and along its left and right edges, I give periodicity. Y-direction here can be assumed radial direction and x- direction can be assumed trigonometric function of circumferential direction.
For any radial loads-here along y-axis (for example: Pressure in internal or external boundary of the tank implies bottom and top surfaces here), the vessel expands radially with periodicity in circumferencial direction.
So in such case, when there is radial loading (along Y), bottom and top boundaries should displace radially (along Y direction). Thus, I dont want to put any constraint on top and bottom edges.
Hi Jorgen, this null space constraint is not able to check the free large displacements that is occurring in the Y-axis when only x is constrained. Any more ideas which could be implemented.
As I have already stated, you could remove all null-spaces from the problem, and follow instructions from: KSP: Linear System Solvers — PETSc 3.21.4 documentation.
You could also normalize the y-displacement post solve, i.e. subtract the displacement at the lower boundary from all nodes, to get the relative displacement as if it was fixed.
