I am new to Fenics. I am trying to implement a simple crystal plasticity model, where I need to calculate the resolved shear stress on each slip system as
tau(i)= 1/ J * m(i) . S * n(i)
where J = det(F_e), m(i) and n(i) are slip direction and slip plane normal of slip system i and S is second Piola Kirchoff stress. Here is a minimal working example.
from ufl import *
# constants
size = 1.0;
mu = 41.0
lamb = 87.2
nSlip = 12
mesh = BoxMesh(Point(0, 0, 0), Point(size, size, size), 10,10,10) # refinement, refinement, refinement)
# function spaces
deg_u = 1
deg_stress = 1
We = VectorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, dim=9, quad_scheme='default')
W = FunctionSpace(mesh, We)
Ze = VectorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, dim=nSlip, quad_scheme='default')
Z = FunctionSpace(mesh, Ze)
Z0e = VectorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default')
Z0 = FunctionSpace(mesh, Z0e)
v = TrialFunction(V)
F_p=Function(W) # plastic deformation
tau = Function(Z) # resolved shear stress on the slip systems
d = u.geometric_dimension() # space dimension
I=Identity(d)
# slip directions
sno_ = as_tensor(Constant( ((1, 1, 1), \
(1, 1, 1), \
(1, 1, 1), \
(-1, -1, 1), \
(-1, -1, 1), \
(-1, -1, 1), \
(-1, 1, 1), \
(-1, 1, 1), \
(-1, 1, 1), \
(1, -1, 1), \
(1,-1, 1), \
(1, -1, 1))) )
sno = sno_ * 1.0/np.sqrt(3.0)
# slip plane normals
sdo_ = as_tensor(Constant ( ((0, 1, -1), \
(-1, 0, 1), \
(1, -1, 0), \
(0, -1, -1), \
(1, 0, 1), \
(-1, 1, 0), \
(0, 1, -1), \
(1, 0, 1), \
(-1, -1, 0), \
(0, -1, -1), \
(-1, 0, 1), \
(1, 1, 0)) ) )
sdo= sdo_ * 1.0/np.sqrt(2.0)
# stiffness tensor
def C_int(d): # C_intermediate
tmp = np.zeros((d,d,d,d))
for i in range(0,d):
for j in range(0,d):
for k in range(0,d):
for l in range(0,d):
if ((i==k) and (j==l)):
tmp[i][j][k][l] = tmp[i][j][k][l] + mu
if ((i==l) and (j==k)):
if ((i==j) and (k==l)):
tmp[i][j][k][l] = tmp[i][j][k][l] + lamb
return as_tensor(tmp)
# get elastic deformation
def get_Fe(u,F_p):
F= I + grad(u)
G_p = inv(as_3D_tensor(F_p))
F_e = F*G_p
return F_e
# get Second Piola Kirchoff stress
def get_Sint(F_e):
E_e = 0.5*(F_e.T*F_e - I) # Right Cauchy-Green tensor
i,j,k,l = indices(4)
S_int= as_tensor(C_int(d)[i,j,k,l]*E_e[k,l],(i,j))
return S_int
# get Resolved shear stress on all Slip systems
def get_tau(J,S):
for i in range(0,nSlip):
tau.sub(i).assign( project(1/J * dot(sdo[0,:], S*sno[0,:]),Z0 ) )
return tau
def as_3D_tensor(X):
return as_tensor([[X[0], X[1], X[2]],
[X[3], X[4], X[5]],
[X[6], X[7], X[8]]])
# initialize F_p
F_p.interpolate(Constant((1,0,0,0,1,0,0,0,1)))
F_e=get_Fe(u,F_p)
S= get_Sint(F_e)
tau=get_tau(det(F_e),S)
So I am unable to populate the function tau (Resolved shear stress) which is a QuadratureElement function of dimension 12 (number of slip systems). I want to populate it in a loop for all the slip systems. So I try to assign the i-th component using sub function and try to project the scalar value inside into the scalar QuadratureElement function space Z0. I am receiving this error
Shapes do not match: <Argument id=139866885635192> and <Product id=139866885324232>.
File "crystalPlasticity_min.py", line 132, in <module>
File "crystalPlasticity_min.py", line 116, in get_tau
File "/usr/lib/python3/dist-packages/dolfin/fem/projection.py", line 129, in project
L = ufl.inner(w, v) * dx
File "/usr/lib/python3/dist-packages/ufl/operators.py", line 169, in inner
return Inner(a, b)
File "/usr/lib/python3/dist-packages/ufl/tensoralgebra.py", line 161, in _new_
error("Shapes do not match: %s and %s." % (ufl_err_str(a), ufl_err_str(b)))
File "/usr/lib/python3/dist-packages/ufl/log.py", line 172, in error
ufl.log.UFLException: Shapes do not match: <Argument id=139866885635192> and <Product id=139866885324232>.
Could you please let me know what I am doing wrong here. Thanks.
