Shear stress Calculation, converting a FEniCS code to FEniCSx
My intension is to calculate the shear stresses and normal stresses on a pipe under Poiseuille flow (Test problem 1: Channel flow )
I found a FEniCS code that have done the same thing, but now I’m having some trouble to convert it into the FEniCSx syntax.
The FEniCS code is as follows: (Source here)
And I was able to convert upto the following:
Required imports (including the items necessary for the test problem):
import pyvista
from dolfinx.fem import Constant,Function, FunctionSpace, assemble_scalar, dirichletbc, form, locate_dofs_geometrical
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc
from dolfinx.mesh import create_unit_square
from ufl import (FacetNormal,FacetArea,as_vector, FiniteElement, Identity,TestFunction, TrialFunction, VectorElement,
                 div, dot, ds, dx, inner, lhs, nabla_grad, rhs, sym,inner)
My attempt to convert the FEniCS code into the FEniCSx syntax:
    return sym(nabla_grad(u))
def sigma(u, p):
    return 2*mu*epsilon(u) - p*Identity(u.geometric_dimension())
#The above two values will anyway be calculated in the test problem.
T = -sigma(u, p)*n
Tn = inner(T, n) # Inner product: https://jorgensd.github.io/dolfinx-tutorial/chapter1/fundamentals_code.html?highlight=inner%20product#expressing-inner-products
Tt = T - Tn*n
#I'm changing the piecewise constant to, order 1 and order 2
p_cg1 = FiniteElement('CG', mesh.ufl_cell(), 1)
v_cg2 = VectorElement('CG', mesh.ufl_cell(), 2)
scalar = FunctionSpace(mesh, p_cg1)
vector = FunctionSpace(mesh, v_cg2)
v = TestFunction(scalar)
w = TestFunction(vector)
normal_stress = Function(scalar)
shear_stress = Function(vector)
Ln = (1/FacetArea(mesh))* v*Tn * ds
Lt = (1/FacetArea(mesh))* inner(w,Tt) * ds
But, then I’m confused on how to properly assemble it and obtain the shear stresses on the boundary (We have a unit square as the domain in the Test problem 1)
Can you please help me to proceed after this step.
Thank you in advance
A minimum reproducible example for the NS problem is:
(The exact code in the Test problem 1: Channel flow )
import pyvista
t = 0
T = 10
num_steps = 500
dt = T/num_steps
v_cg2 = VectorElement("CG", mesh.ufl_cell(), 2)
s_cg1 = FiniteElement("CG", mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, v_cg2)
Q = FunctionSpace(mesh, s_cg1)
p = TrialFunction(Q)
q = TestFunction(Q)
def walls(x):
    return np.logical_or(np.isclose(x[1],0), np.isclose(x[1],1))
wall_dofs = locate_dofs_geometrical(V, walls)
u_noslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
bc_noslip = dirichletbc(u_noslip, wall_dofs, V)
def inflow(x):
    return np.isclose(x[0], 0)
inflow_dofs = locate_dofs_geometrical(Q, inflow)
bc_inflow = dirichletbc(PETSc.ScalarType(8), inflow_dofs, Q)
def outflow(x):
    return np.isclose(x[0], 1)
outflow_dofs = locate_dofs_geometrical(Q, outflow)
bc_outflow = dirichletbc(PETSc.ScalarType(0), outflow_dofs, Q)
bcu = [bc_noslip]
bcp = [bc_inflow, bc_outflow]
u_n = Function(V)
u_n.name = "u_n"
U = 0.5 * (u_n + u)
f = Constant(mesh, PETSc.ScalarType((0,0)))
mu = Constant(mesh, PETSc.ScalarType(1))
rho = Constant(mesh, PETSc.ScalarType(1))
# Define strain-rate tensor
# Define stress tensor
def sigma(u, p):
# https://jorgensd.github.io/dolfinx-tutorial/chapter2/navierstokes.html
# Define the variational problem for the first step
p_n = Function(Q)
p_n.name = "p_n"
F1 = rho*dot((u - u_n) / k, v)*dx
F1 += rho*dot(dot(u_n, nabla_grad(u_n)), v)*dx
F1 += inner(sigma(U, p_n), epsilon(v))*dx
F1 += dot(p_n*n, v)*ds - dot(mu*nabla_grad(U)*n, v)*ds
F1 -= dot(f, v)*dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = assemble_matrix(a1, bcs=bcu)
A1.assemble()
b1 = create_vector(L1)
u_ = Function(V)
a2 = form(dot(nabla_grad(p), nabla_grad(q))*dx)
L2 = form(dot(nabla_grad(p_n), nabla_grad(q))*dx - (1/k)*div(u_)*q*dx)
A2.assemble()
b2 = create_vector(L2)
p_ = Function(Q)
a3 = form(dot(u, v)*dx)
L3 = form(dot(u_, v)*dx - k*dot(nabla_grad(p_ - p_n), v)*dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# Solver for step 1
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setHYPREType("boomeramg")
# Solver for step 2
solver2 = PETSc.KSP().create(mesh.comm)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.BCGS)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(mesh.comm)
solver3.setOperators(A3)
pc3 = solver3.getPC()
xdmf = XDMFFile(mesh.comm, "poiseuille.xdmf", "w")
xdmf.write_mesh(mesh)
xdmf.write_function(u_n, t)
xdmf.write_function(p_n, t)
def u_exact(x):
    values = np.zeros((2, x.shape[1]), dtype=PETSc.ScalarType)
    values[0] = 4*x[1]*(1.0 - x[1])
    return values
u_ex = Function(V)
u_ex.interpolate(u_exact)
L2_error = form(dot(u_ - u_ex, u_ - u_ex)*dx)
for i in range(num_steps):
    # Update current time step
    # Step 1: Tentative veolcity step
    with b1.localForm() as loc_1:
        loc_1.set(0)
    assemble_vector(b1, L1)
    set_bc(b1, bcu)
    solver1.solve(b1, u_.vector)
    u_.x.scatter_forward()
    # Step 2: Pressure corrrection step
    with b2.localForm() as loc_2:
        loc_2.set(0)
    assemble_vector(b2, L2)
    set_bc(b2, bcp)
    solver2.solve(b2, p_.vector)
    p_.x.scatter_forward()
    with b3.localForm() as loc_3:
        loc_3.set(0)
    assemble_vector(b3, L3)
    solver3.solve(b3, u_.vector)
    u_n.x.array[:] = u_.x.array[:]
    p_n.x.array[:] = p_.x.array[:]
    # Write solutions to file
    # Compute error at current time-step
    error_L2 = np.sqrt(mesh.comm.allreduce(assemble_scalar(L2_error), op=MPI.SUM))
    error_max = mesh.comm.allreduce(np.max(u_.vector.array - u_ex.vector.array), op=MPI.MAX)
    # Print error only every 20th step and at the last step
    # if (i % 20 == 0) or (i == num_steps - 1):
    #     print(f"Time {t:.2f}, L2-error {error_L2:.2e}, Max error {error_max:.2e}")
# Close xmdf file
xdmf.close()
To plot the velocity field and to make sure it works fine:
# pyvista.set_jupyter_backend("pythreejs")
# pyvista.set_jupyter_backend("ipygany")
pyvista.set_jupyter_backend("ipyvtklink")
pyvista.start_xvfb()
topology, cell_types, geometry = create_vtk_mesh(V)
values = np.zeros((geometry.shape[0], 3), dtype=np.float64)
values[:, :len(u_n)] = u_n.x.array.real.reshape((geometry.shape[0], len(u_n)))
# Create a point cloud of glyphs
function_grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
function_grid["u"] = values
glyphs = function_grid.glyph(orient="u", factor=0.2)
# Create a pyvista-grid for the mesh
grid = pyvista.UnstructuredGrid(*create_vtk_mesh(mesh, mesh.topology.dim))
# Create plotter
plotter = pyvista.Plotter()
# plotter.add_mesh(grid, style="wireframe", color="k")
plotter.add_mesh(glyphs)
plotter.view_xy()
if not pyvista.OFF_SCREEN:
    plotter.show()
    fig_as_array = plotter.screenshot("glyphs.png")
The code that I have so far, for the shear stress calculation:
T = -sigma(u, p)*n
Tt = T - Tn*n
assemble_vector(normal_stress.vector, form(Ln))
assemble_vector(normal_stress.vector, form(Lt))
why are you using dx and not ds as done in the old code? The assemble function should be replaced with dolfinx.fem.petsc.assemble_vector(normal_stresses.vector, Ln)
I’m sorry. That was a mistake from my side. I corrected it with ds (As we are using a surface integral)
Thank you for the instruction for the assembly. But when I used it, ( assemble_vector(normal_stress.vector, Ln)), I’m getting the following error:
TypeError                                 Traceback (most recent call last)
Input In [10], in <cell line: 26>()
     21 Ln = (1/FacetArea(mesh))* v*Tn * ds
     22 Ln = (1/FacetArea(mesh))* inner(w,Tt) * ds
---> 26 assemble_vector(normal_stress.vector, Ln)
File /usr/lib/python3.10/functools.py:889, in singledispatch.<locals>.wrapper(*args, **kw)
    885 if not args:
    886     raise TypeError(f'{funcname} requires at least '
    887                     '1 positional argument')
--> 889 return dispatch(args[0].__class__)(*args, **kw)
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/petsc.py:206, in _assemble_vector_vec(b, L, constants, coeffs)
    190 """Assemble linear form into an existing PETSc vector.
    191
    192 Note:
    203
    204 """
    205 with b.localForm() as b_local:
--> 206     assemble._assemble_vector_array(b_local.array_w, L, constants, coeffs)
    207 return b
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/assemble.py:198, in _assemble_vector_array(b, L, constants, coeffs)
    172 @assemble_vector.register(np.ndarray)
    173 def _assemble_vector_array(b: np.ndarray, L: FormMetaClass, constants=None, coeffs=None):
    174     """Assemble linear form into a new Vector.
    175
    176     Args:
    195
    196     """
--> 198     constants = _pack_constants(L) if constants is None else constants
    199     coeffs = _pack_coefficients(L) if coeffs is None else coeffs
    200     _cpp.fem.assemble_vector(b, L, constants, coeffs)
TypeError: pack_constants(): incompatible function arguments. The following argument types are supported:
    1. (form: dolfinx::fem::Form<double>) -> numpy.ndarray[numpy.float64]
    2. (e: dolfinx::fem::Expression<double>) -> numpy.ndarray[numpy.float64]
    3. (form: dolfinx::fem::Form<float>) -> numpy.ndarray[numpy.float32]
    4. (e: dolfinx::fem::Expression<float>) -> numpy.ndarray[numpy.float32]
    5. (form: dolfinx::fem::Form<std::complex<double> >) -> numpy.ndarray[numpy.complex128]
    6. (e: dolfinx::fem::Expression<std::complex<double> >) -> numpy.ndarray[numpy.complex128]
    7. (form: dolfinx::fem::Form<std::complex<float> >) -> numpy.ndarray[numpy.complex64]
    8. (e: dolfinx::fem::Expression<std::complex<float> >) -> numpy.ndarray[numpy.complex64]
Invoked with: Form([Integral(Product(Division(IntValue(1), FacetArea(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0))), Inner(Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), VectorElement(FiniteElement('Lagrange', triangle, 2), dim=2)), 0, None), Sum(ComponentTensor(Product(IntValue(-1), Indexed(ComponentTensor(Product(Indexed(FacetNormal(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0)), MultiIndex((Index(90),))), Conj(Inner(FacetNormal(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0)), ComponentTensor(IndexSum(Product(Indexed(FacetNormal(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0)), MultiIndex((Index(89),))), Indexed(ComponentTensor(Product(IntValue(-1), Indexed(Sum(ComponentTensor(Product(IntValue(-1), Indexed(ComponentTensor(Product(Indexed(Identity(2), MultiIndex((Index(82), Index(83)))), Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 1, None)), MultiIndex((Index(82), Index(83)))), MultiIndex((Index(84), Index(85))))), MultiIndex((Index(84), Index(85)))), ComponentTensor(Product(Indexed(Sym(NablaGrad(Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), VectorElement(FiniteElement('Lagrange', triangle, 2), dim=2)), 1, None))), MultiIndex((Index(80), Index(81)))), Product(IntValue(2), Constant(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), (), 2))), MultiIndex((Index(80), Index(81))))), MultiIndex((Index(86), Index(87))))), MultiIndex((Index(86), Index(87)))), MultiIndex((Index(88), Index(89))))), MultiIndex((Index(89),))), MultiIndex((Index(88),)))))), MultiIndex((Index(90),))), MultiIndex((Index(91),)))), MultiIndex((Index(91),))), ComponentTensor(IndexSum(Product(Indexed(FacetNormal(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0)), MultiIndex((Index(89),))), Indexed(ComponentTensor(Product(IntValue(-1), Indexed(Sum(ComponentTensor(Product(IntValue(-1), Indexed(ComponentTensor(Product(Indexed(Identity(2), MultiIndex((Index(82), Index(83)))), Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 1, None)), MultiIndex((Index(82), Index(83)))), MultiIndex((Index(84), Index(85))))), MultiIndex((Index(84), Index(85)))), ComponentTensor(Product(Indexed(Sym(NablaGrad(Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), VectorElement(FiniteElement('Lagrange', triangle, 2), dim=2)), 1, None))), MultiIndex((Index(80), Index(81)))), Product(IntValue(2), Constant(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), (), 2))), MultiIndex((Index(80), Index(81))))), MultiIndex((Index(86), Index(87))))), MultiIndex((Index(86), Index(87)))), MultiIndex((Index(88), Index(89))))), MultiIndex((Index(89),))), MultiIndex((Index(88),)))))), 'exterior_facet', Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), 'everywhere', {}, None)])
Did you forget to `#include <pybind11/stl.h>`? Or <pybind11/complex.h>,
<pybind11/functional.h>, <pybind11/chrono.h>, etc. Some automatic
conversions are optional and require extra headers to be included
when compiling your pybind11 module.
I typed this on my phone, and hence missed that you need to wrap Ln
should be
dolfinx.fem.petsc.assemble_vector(normal_stresses.vector, dolfinx.fem.form(Ln))
mh… Sorry for the trouble but now I’m getting the following:
UFLException                              Traceback (most recent call last)
Input In [17], in <cell line: 1>()
----> 1 assemble_vector(normal_stress.vector, form(Ln))
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/forms.py:166, in form(form, dtype, form_compiler_params, jit_params)
    163         return list(map(lambda sub_form: _create_form(sub_form), form))
    164     return form
--> 166 return _create_form(form)
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/forms.py:161, in form.<locals>._create_form(form)
    158 """Recursively convert ufl.Forms to dolfinx.fem.Form, otherwise
    159 return form argument"""
    160 if isinstance(form, ufl.Form):
--> 161     return _form(form)
    162 elif isinstance(form, collections.abc.Iterable):
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/forms.py:135, in form.<locals>._form(form)
    132 if mesh is None:
    133     raise RuntimeError("Expecting to find a Mesh in the form.")
--> 135 ufcx_form, module, code = jit.ffcx_jit(mesh.comm, form,
    136                                        form_compiler_params=form_compiler_params,
    137                                        jit_params=jit_params)
    139 # For each argument in form extract its function space
    140 V = [arg.ufl_function_space()._cpp_object for arg in form.arguments()]
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/jit.py:56, in mpi_jit_decorator.<locals>.mpi_jit(comm, *args, **kwargs)
     51 @functools.wraps(local_jit)
     52 def mpi_jit(comm, *args, **kwargs):
     53
     54     # Just call JIT compiler when running in serial
     55     if comm.size == 1:
---> 56         return local_jit(*args, **kwargs)
     58     # Default status (0 == ok, 1 == fail)
     59     status = 0
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/jit.py:204, in ffcx_jit(ufl_object, form_compiler_params, jit_params)
    202 # Switch on type and compile, returning cffi object
    203 if isinstance(ufl_object, ufl.Form):
--> 204     r = ffcx.codegeneration.jit.compile_forms([ufl_object], parameters=p_ffcx, **p_jit)
    205 elif isinstance(ufl_object, ufl.FiniteElementBase):
    206     r = ffcx.codegeneration.jit.compile_elements([ufl_object], parameters=p_ffcx, **p_jit)
File /usr/local/lib/python3.10/dist-packages/ffcx/codegeneration/jit.py:147, in compile_forms(forms, parameters, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries)
    143 p = ffcx.parameters.get_parameters(parameters)
    145 # Get a signature for these forms
    146 module_name = 'libffcx_forms_' + \
--> 147     ffcx.naming.compute_signature(forms, _compute_parameter_signature(p)
    148                                   + str(cffi_extra_compile_args) + str(cffi_debug))
    150 form_names = [ffcx.naming.form_name(form, i, module_name) for i, form in enumerate(forms)]
    152 if cache_dir is not None:
File /usr/local/lib/python3.10/dist-packages/ffcx/naming.py:32, in compute_signature(ufl_objects, tag)
     30 if isinstance(ufl_object, ufl.Form):
     31     kind = "form"
---> 32     object_signature += ufl_object.signature()
     33 elif isinstance(ufl_object, ufl.FiniteElementBase):
     34     object_signature += repr(convert_element(ufl_object))
File /usr/local/lib/python3.10/dist-packages/ufl/form.py:252, in Form.signature(self)
    250 "Signature for use with jit cache (independent of incidental numbering of indices etc.)"
    251 if self._signature is None:
--> 252     self._compute_signature()
    253 return self._signature
File /usr/local/lib/python3.10/dist-packages/ufl/form.py:506, in Form._compute_signature(self)
    503 def _compute_signature(self):
    504     from ufl.algorithms.signature import compute_form_signature
    505     self._signature = compute_form_signature(self,
--> 506                                              self._compute_renumbering())
File /usr/local/lib/python3.10/dist-packages/ufl/form.py:469, in Form._compute_renumbering(self)
    466 def _compute_renumbering(self):
    467     # Include integration domains and coefficients in renumbering
    468     dn = self.domain_numbering()
--> 469     cn = self.coefficient_numbering()
    470     cnstn = self.constant_numbering()
    471     renumbering = {}
File /usr/local/lib/python3.10/dist-packages/ufl/form.py:238, in Form.coefficient_numbering(self)
    235 """Return a contiguous numbering of coefficients in a mapping
    236 ``{coefficient:number}``."""
    237 if self._coefficient_numbering is None:
--> 238     self._analyze_form_arguments()
    239 return self._coefficient_numbering
File /usr/local/lib/python3.10/dist-packages/ufl/form.py:456, in Form._analyze_form_arguments(self)
    454 "Analyze which Argument and Coefficient objects can be found in the form."
    455 from ufl.algorithms.analysis import extract_arguments_and_coefficients
--> 456 arguments, coefficients = extract_arguments_and_coefficients(self)
    458 # Define canonical numbering of arguments and coefficients
    459 self._arguments = tuple(
    460     sorted(set(arguments), key=lambda x: x.number()))
File /usr/local/lib/python3.10/dist-packages/ufl/algorithms/analysis.py:127, in extract_arguments_and_coefficients(a)
    122     if len(bfnp) != len(set(bfnp.values())):
    123         msg = """\
    124 Found different Arguments with same number and part.
    125 Did you combine test or trial functions from different spaces?
    126 The Arguments found are:\n%s""" % "\n".join("  %s" % f for f in arguments)
--> 127         error(msg)
    129     # Build count: instance mappings, should be one to one
    130     fcounts = dict((f, f.count()) for f in coefficients)
File /usr/local/lib/python3.10/dist-packages/ufl/log.py:158, in Logger.error(self, *message)
    156 "Write error message and raise an exception."
    157 self._log.error(*message)
--> 158 raise self._exception_type(self._format_raw(*message))
UFLException: Found different Arguments with same number and part.
  v_0
  v_1
  v_1
Please note that I used:
instead of the zero order that was in the FEniCS code.
Please make a minimal reproducible code. I cannot spend time copy-pasting snippets of code from your previous posts guessing how you have added the changes. Please use a built-in mesh and make sure that one can run the code with DOLFINx by simply copy pasting it.
Sure. I edited my post with an executable example for the Navier Stokes problem.
And I was trying to calculate the shear stresses for that vector field
v is part of the scalar space, while w is part of the vector function space.
Are you sure that you want to call
There is also so much code here (You need to remove parts that are not needed to reproduce the error), it is really hard to see whats going on, your code
This shouldnt be u and p, but u_ and p_ as far as I can tell.
@dokken Thank You!
yes it shouldn’t be u and p.
It should be u_n and p_n.
