Hi guys,
I know this is a basic question but can anyone tell me what is the function/code snippet to compute the nodal (displacement) and element (strain, stress) property at an arbitrary location (which may not be a mesh node) on the structure?
Hi guys,
If you project the stress/strain into a suitable function space, you can use the point evaluation method part of Function to evaluate at any point.
See for instance: Bitbucket
Thanks for the reply. I use that. I also found this code
strain_gauges = [
Point(0.03, 0.03),
Point(0.12, 0.12)
strain = 0.5 * (grad(u) + grad(u).T)
[s00,s01,s10,s11] = strain.split(True)
print(s00(strain_gauges[0]))
Does this also work?
Where did you find this code?
If you simply try to run it:
mesh = UnitSquareMesh(10, 10)
V = VectorFunctionSpace(mesh, "CG", 1)
train_gauges = [
Point(0.03, 0.03),
Point(0.12, 0.12)
you obtain the following error message:
File "split_ufl.py", line 14, in <module>
AttributeError: 'ComponentTensor' object has no attribute 'split'
as you need to project the ufl expression into a suitable function space.
