How to compute the correct residual in parallel in DOLFINX?
Hi all, I am trying to compute the 2-norm of the residual when the code is running in parallel. The reason to do this is I would like to design the line search algorithm based on this residual.
Here is the MWE and the residual can be computed correctly when the code is running in serial.
from dolfinx.cpp.mesh import CellType
mesh = dolfinx.BoxMesh(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([1, 1, 1])], \
    [2, 2, 2], CellType.hexahedron)
V = dolfinx.VectorFunctionSpace(mesh, ("CG", 1))
E = 1e4 # elastic modulus
nu = 0.3 # Poisson's ratio
lambda_ = dolfinx.Constant(mesh, E*nu / (1+nu) / (1-2*nu))
mu = dolfinx.Constant(mesh, E / (2*(1+nu)))
def left(x):
    return np.isclose(x[0], 0)
def right(x):
    return np.isclose(x[0], 1)
left_facets = dolfinx.mesh.locate_entities_boundary(mesh, mesh.topology.dim - 1, left)
right_facets = dolfinx.mesh.locate_entities_boundary(mesh, mesh.topology.dim - 1, right)
marked_values = np.hstack([np.full(len(left_facets), 1, dtype=np.int32), np.full(len(right_facets), 2, dtype=np.int32)])
facet_tag = dolfinx.MeshTags(mesh, mesh.topology.dim-1, marked_facets[sorted_facets], marked_values[sorted_facets])
u_bc = dolfinx.Function(V)
with u_bc.vector.localForm() as loc:
    loc.set(0)
left_dofs = dolfinx.fem.locate_dofs_topological(V, facet_tag.dim, facet_tag.indices[facet_tag.values==1])
bcs = [dolfinx.DirichletBC(u_bc, left_dofs)]
B = dolfinx.Constant(mesh, (0, 0, 0)) # body force
T = dolfinx.Constant(mesh, (0, 0, 0)) # traction
u = dolfinx.Function(V) # test function
v = ufl.TestFunction(V) # trial function
d = len(u) # spatial dimension
I = ufl.variable(ufl.Identity(d)) # identity tensor
F = ufl.variable(I + ufl.grad(u)) # deformation gradient
C = ufl.variable(F.T * F) # right Cauchy-Green tensor
Ic = ufl.variable(ufl.tr(C)) # first invariant
J  = ufl.variable(ufl.det(F)) # third invariant
# strain energy density of compressible neo-Hookean model
psi = (mu / 2) * (Ic - 3) - mu * ufl.ln(J) + (lambda_ / 2) * (ufl.ln(J))**2
P = ufl.diff(psi, F) # first Piola-Kirchhoff stress
ds = ufl.Measure('ds', subdomain_data=facet_tag, metadata=metadata)
dx = ufl.Measure("dx", metadata=metadata)
R = ufl.inner(ufl.grad(v), P)*dx - ufl.inner(v, B)*dx - ufl.inner(v, T)*ds(2)
problem = dolfinx.fem.NonlinearProblem(R, u, bcs)
solver = dolfinx.NewtonSolver(MPI.COMM_WORLD, problem)
dolfinx.log.set_log_level(dolfinx.log.LogLevel.INFO)
T.value[2] = -5
num_its, converged = solver.solve(u)
u.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
rhs = dolfinx.fem.assemble_vector(R)
dolfinx.fem.set_bc(rhs, bcs)
rhs.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
print(rhs.norm())
The output indicates the computed residual 5.35121e-13 is the same as the one given by the backend.
2021-11-28 18:43:03.983 (   0.197s) [main            ]topologycomputation.cpp:628   INFO| Computing mesh entities of dimension 1
2021-11-28 18:43:03.983 (   0.197s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:43:03.983 (   0.197s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 0: r (abs) = 1.875 (tol = 1e-10) r (rel) = inf(tol = 1e-09)
2021-11-28 18:43:03.983 (   0.197s) [main            ]  PETScKrylovSolver.cpp:98    INFO| PETSc Krylov solver starting to solve system.
2021-11-28 18:43:03.985 (   0.199s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:43:03.985 (   0.199s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 1: r (abs) = 0.0438781 (tol = 1e-10) r (rel) = 4.53887(tol = 1e-09)
2021-11-28 18:43:03.986 (   0.200s) [main            ]  PETScKrylovSolver.cpp:98    INFO| PETSc Krylov solver starting to solve system.
2021-11-28 18:43:03.986 (   0.200s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:43:03.986 (   0.200s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 2: r (abs) = 1.55256e-07 (tol = 1e-10) r (rel) = 1.60601e-05(tol = 1e-09)
2021-11-28 18:43:03.987 (   0.201s) [main            ]  PETScKrylovSolver.cpp:98    INFO| PETSc Krylov solver starting to solve system.
2021-11-28 18:43:03.987 (   0.201s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:43:03.988 (   0.201s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 3: r (abs) = 5.35121e-13 (tol = 1e-10) r (rel) = 5.53543e-11(tol = 1e-09)
2021-11-28 18:43:03.988 (   0.201s) [main            ]       NewtonSolver.cpp:252   INFO| Newton solver finished in 3 iterations and 3 linear solver iterations.
2021-11-28 18:43:03.990 (   0.204s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
5.351209992524201e-13
2021-11-28 18:43:04.023 (   0.237s) [main            ]             loguru.cpp:526   INFO| atexit
However, when running this code in parallel with mpirun -n 3 python3 ResidualTest.py, we can see the residuals are different:
2021-11-28 18:46:38.936 (   0.233s) [main            ]topologycomputation.cpp:628   INFO| Computing mesh entities of dimension 1
2021-11-28 18:46:38.936 (   0.238s) [main            ]topologycomputation.cpp:628   INFO| Computing mesh entities of dimension 1
2021-11-28 18:46:38.936 (   0.233s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:46:38.936 (   0.239s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:46:38.936 (   0.233s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 0: r (abs) = 1.875 (tol = 1e-10) r (rel) = inf(tol = 1e-09)
2021-11-28 18:46:38.937 (   0.234s) [main            ]  PETScKrylovSolver.cpp:98    INFO| PETSc Krylov solver starting to solve system.
2021-11-28 18:46:38.937 (   0.239s) [main            ]  PETScKrylovSolver.cpp:98    INFO| PETSc Krylov solver starting to solve system.
2021-11-28 18:46:38.939 (   0.236s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:46:38.939 (   0.242s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:46:38.939 (   0.237s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:46:38.940 (   0.236s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 1: r (abs) = 0.0438781 (tol = 1e-10) r (rel) = 4.53887(tol = 1e-09)
2021-11-28 18:46:38.940 (   0.237s) [main            ]  PETScKrylovSolver.cpp:98    INFO| PETSc Krylov solver starting to solve system.
2021-11-28 18:46:38.940 (   0.242s) [main            ]  PETScKrylovSolver.cpp:98    INFO| PETSc Krylov solver starting to solve system.
2021-11-28 18:46:38.941 (   0.238s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:46:38.941 (   0.243s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:46:38.941 (   0.238s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 2: r (abs) = 1.55256e-07 (tol = 1e-10) r (rel) = 1.60601e-05(tol = 1e-09)
2021-11-28 18:46:38.942 (   0.238s) [main            ]  PETScKrylovSolver.cpp:98    INFO| PETSc Krylov solver starting to solve system.
2021-11-28 18:46:38.942 (   0.244s) [main            ]  PETScKrylovSolver.cpp:98    INFO| PETSc Krylov solver starting to solve system.
2021-11-28 18:46:38.942 (   0.239s) [main            ]  PETScKrylovSolver.cpp:98    INFO| PETSc Krylov solver starting to solve system.
2021-11-28 18:46:38.942 (   0.239s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:46:38.942 (   0.245s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:46:38.942 (   0.240s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:46:38.943 (   0.240s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 3: r (abs) = 5.39295e-13 (tol = 1e-10) r (rel) = 5.57861e-11(tol = 1e-09)
2021-11-28 18:46:38.943 (   0.240s) [main            ]       NewtonSolver.cpp:252   INFO| Newton solver finished in 3 iterations and 3 linear solver iterations.
2021-11-28 18:46:38.945 (   0.242s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:46:38.947 (   0.244s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
2021-11-28 18:46:38.947 (   0.250s) [main            ]topologycomputation.cpp:669   INFO| Requesting connectivity 2 - 3
1.9425172391655907
1.9425172391655907
1.9425172391655907
2021-11-28 18:46:39.003 (   0.300s) [main            ]             loguru.cpp:526   INFO| atexit
2021-11-28 18:46:39.003 (   0.305s) [main            ]             loguru.cpp:526   INFO| atexit
After many tries, I still cannot solve this problem. So could anyone please help me with this problem?
Thanks in advance!
The following works as expected:
rhs.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
Thanks very much for your reply, @kamensky. This works well for the given MWE!
As a comment for future readers, if we also have non-zero Dirichlet boundary conditions like:
    loc.set(1.0)
We need to reset the boundary conditions as zeros like:
    loc.set(0.0)
before computing the residual.
The complete code snippet:
    loc.set(0.0)
