How to condition my modified 3D elasticity FEniCS code?
I am trying to solve a 3D elasticity problem with an additional field for eigenstrains. Geometry is hemisphere with tetrahedral meshing. I have checked the code for syntax: no errors, tuning/relaxing the tolerance parameters and also varied other solver parameters.
When I monitor convergence, the norm either does not decrease or in very rare cases decreases very very slowly. Although the weak form is mathematically correct, I believe there is some problem with the conditioning of stiffness (or global tangent) matrix of the mixed system. I am not sure how to approach this issue.
A MWE is given here: (most of the code is packed in functions)
from copy import deepcopy
from statistics import mode
from numpy import infty, iinfo, int32, argwhere, min, max
def sphere_geometry(db_mesh_folder, mesh_file):
    #R, mesh_size = geo_parameters
    mymesh = Mesh()
    #db_mesh_folder = "/Users/dhariwal/Library/CloudStorage/OneDrive-VirginiaTech/Zirconia/Particle_SIMULATION/Code/single_variant/meshes/"
    #mesh_file = "mesh3D_R_" + str(int(self.R)) + "_size_" + str(int(mesh_size)) + ".xdmf"
    with XDMFFile(db_mesh_folder + mesh_file) as infile:
        infile.read(mymesh)
    print("Domain created, meshing done")
    print("Radius = ", R)
    print("mesh_size = ", mesh_size)
    print("Number of cells = ", mymesh.num_cells())
    print("Number of vertices = ", mymesh.num_vertices())
    # Characteristic size of the elements of the mesh
    hMESH = CellDiameter(mymesh)
    meshSIZE = 0.5*(mymesh.hmax() + mymesh.hmin())
    print("meshSIZE = ", meshSIZE)
    return mymesh, hMESH, meshSIZE
    x1, y1, z1 = geo_parameters[0]
    nx, ny, nz = geo_parameters[1]
    corner1 = Point(0.0, 0.0, 0.0)
    corner2 = Point(x1, y1, z1)
    mymesh = BoxMesh(corner1, corner2, nx, ny, nz)
    return mymesh
def cuboid_geometry(geo_parameters):
def func_spaces(mesh, basis):
    if basis == 'linear':
        shape_func = 1
        shape_func = 2
    # basis for 'vector' displacement
    P1 = VectorElement("Lagrange", mesh.ufl_cell(), shape_func)
    # basis for 'scalar' monovariant phase field
    P2 = FiniteElement("Lagrange", mesh.ufl_cell(), shape_func)
    W1 = FunctionSpace(mesh, P1)
    W2 = FunctionSpace(mesh, P2)
    from db_variant import Variant
    shape_strains_list = Variant.CuAlNi()
    shape_strains_list = as_tensor(shape_strains_list[0])
    num_variants = 1
    # single variant
    element = MixedElement([P1, P2])
    # create the space of solutions over the domain
    W = FunctionSpace(mesh, element)
    # a generic function from W
    w  = Function(W)
    dw = TrialFunction(W)
    wx = TestFunction(W)
    print("Total D.O.F. = ", W.dim())
    return W, W1, W2, w, dw, wx, num_variants, shape_strains_list
        shape_func = 1
        shape_func = 2
    W = FunctionSpace(mesh, P1)
    w  = Function(W)               # a generic function from W
    v  = TestFunction(W)             # test function for variational problem
    num_variants = 0
    print("This is a pure elastic problem.\n No. of variants = ", num_variants)
    return W, w, dw, v, P1
    # Spatial coordinates of mesh
    x = SpatialCoordinate(mesh)
    # Definition of tolerance
    tol = DOLFIN_EPS # FEniCS tolerance - necessary for "boundary_markers" and the correct definition of the boundaries
    #class Bottom(SubDomain):
    #    def inside(self, x, on_boundary):
    #        return near(x[2], 0.0)
    #bottom = Bottom()
    bT = CompiledSubDomain('near(x[2], R, tol) && on_boundary', R = R, tol = tol)
    bP = CompiledSubDomain('sqrt(x[0]*x[0] + x[1]*x[1]) < meshSIZE \
                            && near(x[2], R, tol) \
                            && on_boundary', meshSIZE = meshSIZE, R=R, tol = tol)
    # Definition of contact zones
    bC = CompiledSubDomain('on_boundary && x[2] < compression + tol', R = R, tol=tol, compression = compression) # Contact search - contact part of the boundary
    boundaries = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
    boundaries.set_all(0)
    print("Markers for all boundary facets are set")
    bT.mark(boundaries, 2)      # bottom
    bP.mark(boundaries, 4)      # lateral_penalty
    bC.mark(boundaries, 6)      # contact_zone
    print(boundaries.array()[boundaries.array() > 0])
    cells = MeshFunction("size_t", mesh, mesh.topology().dim())
    cells.set_all(1)
    print("Marker for all internal cells is set to 1")
    bc1 = DirichletBC(W.sub(2), Constant((-compression)), boundaries, 2)
    bc2 = DirichletBC(W.sub(0), Constant((0)), boundaries, 4)
    bc3 = DirichletBC(W.sub(1), Constant((0)), boundaries, 4)
    bcs = [bc1,bc2,bc3]
    dx = Measure('dx', subdomain_data=cells)
    ds = Measure('ds', subdomain_data=boundaries)
    return dx, ds, boundaries, bcs
    lower_bound = Function(W)
    upper_bound = Function(W)
    #W00 = W.sub(0).collapse()
    #W11 = W.sub(1).collapse()
    #ninfty, pinfty = Function(W00), Function(W00)
    #_lower, c_upper = Function(W11), Function(W11)
    if u_min is None:
        lower_bound.sub(0).vector()[:] = - infty
        lower_bound.sub(1).vector()[:] = - infty
        lower_bound.sub(2).vector()[:] = - infty
        upper_bound.sub(0).vector()[:] = infty
        upper_bound.sub(1).vector()[:] = infty
        upper_bound.sub(2).vector()[:] = infty
        #lower_bound.vector()[:] = -infty
        #upper_bound.vector()[:] = infty
        lower_bound.vector()[:] = u_min
        upper_bound.vector()[:] = u_max
    #fa = FunctionAssigner(W, [W00, W11])
    #fa.assign(lower_bound, [ninfty, c_lower])
    #fa.assign(upper_bound, [pinfty, c_upper])
    return lower_bound, upper_bound
    # Form compiler options
    parameters["form_compiler"]["optimize"]     = True
    from db_compliance import Compliance
    compliance_phase1, compliance_phase2 = Compliance.CuAlNi()
    Compliance_tetragonal = as_tensor(compliance_phase1)
    #Compliance_monoclinic = as_tensor(compliance_phase2)
    # Definition of normal vectors to the elastic body and to the rigid half-space
    nRIGID = Constant((0.0, 0.0, 1.0))
    # matrix-to-vector transform
    def strain3voigt(e):
        return as_vector(
            [e[0, 0],
            e[1, 1],
            e[2, 2],
            e[1, 2] * 2,
            e[0, 2] * 2,
            e[0, 1] * 2]
    # vector-to-matrix transform
    def voigt3stress(s):
        return as_tensor(
            [[s[0], s[5], s[4]],
            [s[5], s[1], s[3]],
            [s[4], s[3], s[2]]]
    def epsilon(u, strain=None):
        if strain is None:
            e = 0.5 * (grad(u) + grad(u).T)
            return e
        elif strain=='lagrangian':
            I = Identity(3)
            Fgrad = I + grad(u)
            C = Fgrad.T * Fgrad
            E = 0.5*(C - I)
            return E
        elif strain=='hencky_order_22':
            I = Identity(3)
            Fgrad = I + grad(u)
            C = Fgrad.T * Fgrad
            a = C*C - I
            b = (C*C) + 4*C + I
            H = 1.5 * a * inv(b)
            return H
    def Vstrain(w):
        return strain3voigt(epsilon(w))
    def Vsigma(w):
        return dot(Compliance_tetragonal, Vstrain(w))
    def sigma(w):
        return voigt3stress(Vsigma(w))
    def gap(w): # Definition of gap function
        return x[2]+w[2]
    def maculay(x): # Definition of Maculay bracket
        return (x+abs(x))/2
    def pN(w):
        return dot(dot(nRIGID,sigma(w)),nRIGID)
    def convert_to_integer(a):
        "Convert to a 32-bit int. Raise exception if this will cause an overflow"
        if abs(a) <= iinfo(int32).max:
            return int32(a)
            raise OverflowError("Cannot safely convert to a 32-bit int.")
    def elastic(w):
        elastic_energy = 0.5 * inner(sigma(w), epsilon(w))
        return elastic_energy
    # The displacement u must be such that the current configuration x+u
    # remains in the box [xmin = -inf,xmax = inf] x [ymin = 0,ymax = inf]
    # constraint_u = Expression(("xmax - x[0]","ymax - x[1]","zmax - x[2]"),
    #                         xmax=infty,  ymax=infty, zmax=infty, degree=1)
    # constraint_l = Expression(("xmin - x[0]","ymin - x[1]","zmin - x[2]"),
    #                         xmin=-infty, ymin=-infty, zmin=0.0, degree=1)
    # umin = interpolate(constraint_l, W)
    # umax = interpolate(constraint_u, W)
    #w_converged = Function(W)
    time_end = 1.0
    t_curr = 0.0
    t_curr = t_curr + time_step
    d_step = compression * t_curr
    # Define the solver parameters
    while t_curr <= time_end:
        dx, ds, boundaries, bcs = pureElastic_sphere_boundaries(mesh, meshSIZE, R, d_step, W)
        print("Current displacement at boundary = ", d_step, " nm")#, " and i_count = ", i_count)
        #w = w_converged
        # Stored strain energy density (linear elasticity model)
        psi = elastic(w)
        # Total potential energy
        Pi = psi*dx +  (0.5 * penalty * (E/hMESH) * inner(maculay(-gap(w)), maculay(-gap(w)))) * ds(6)
        # Compute first variation of Pi (directional derivative about u in the direction of v)
        F = derivative(Pi, w, v)
        # Compute Jacobian of F for iterative "newton_solver"
        J = derivative(F, w, dw)
        problem = NonlinearVariationalProblem(F, w, bcs, J=J)
        umin, umax = PureElastic_func_space_bounds(W)
        problem.set_bounds(umin, umax)
        solver  = NonlinearVariationalSolver(problem)
        snes_solver_parameters = {"nonlinear_solver": "snes",
                            "snes_solver": {"linear_solver": "lu",# "preconditioner": "ilu",
                                            "maximum_iterations": 100,
                                            "absolute_tolerance": 1E-9,
                                            "relative_tolerance": 1E-9,
                                            "report": False,
                                            "method":'vinewtonrsls',
                                            "error_on_nonconvergence": True}}
                                            # ,"krylov_solver": {"divergence_limit": 1e10}
        solver.parameters.update(snes_solver_parameters)
        # Solve the nonlinear problem
        (iter, converged) = solver.solve()
        if not converged:
            t_curr = t_curr - time_step
            time_step = time_step/2.0
            continue
    # WT = TensorFunctionSpace(mesh, "Lagrange", degree=0)
    # # strain field
    # EPS = Function(WT, name="Strain")
    # EPS.assign(project(epsilon(w), WT))
    # # stress field
    # SIGMA = Function(WT, name="Strain")
    # SIGMA.assign(project(sigma(w), WT))
    return w, boundaries
def func_space_bounds(W, u_min=None, u_max=None, c_min=None, c_max=None):
    S = [W.sub(i).collapse() for i in range(num_variants + 1)]
    ninfty, pinfty = Function(S[0]), Function(S[0])
    c_lower = [Function(S[i+1]) for i in range(num_variants)]
    c_upper = [Function(S[i+1]) for i in range(num_variants)]
    if u_min is None:
        ninfty.vector()[:] = - 50
        pinfty.vector()[:] = 50
        if c_min is None:
            for i in range(num_variants):
                c_lower[i].vector()[:] = - 0.1
                c_upper[i].vector()[:] = 1
        ninfty.vector()[:] = u_min
        pinfty.vector()[:] = u_max
                c_lower[i].vector()[:] = c_min
                c_upper[i].vector()[:] = c_max
    fa = FunctionAssigner(W, S)
    lb = [ninfty]
    ub = [pinfty]
    for i in c_lower: lb.append(i)
    for i in c_upper: ub.append(i)
    fa.assign(lower_bound, lb)
    fa.assign(upper_bound, ub)
    print(lower_bound.vector()[:], upper_bound.vector()[:])
def sphere_boundaries(mesh, meshSIZE, R, compression, W):
    #print(boundaries.array()[boundaries.array() == 2])
    print(boundaries.array()[boundaries.array() == 4])
    print(boundaries.array()[boundaries.array() == 6])
    cells.set_all(1)
    bc1 = DirichletBC(W.sub(0).sub(2), Constant((-compression)), boundaries, 2)
    bc2 = DirichletBC(W.sub(0).sub(0), Constant((0)), boundaries, 4)
    bc3 = DirichletBC(W.sub(0).sub(1), Constant((0)), boundaries, 4)
    bc4 = DirichletBC(W.sub(1), Constant((0)), boundaries, 4)
    # for more than one variants
    #bc5 = DirichletBC(W.sub(2), Constant((0)), boundaries, 4)
    #bc6 = DirichletBC(W.sub(3), Constant((0)), boundaries, 4)
    #bc7 = DirichletBC(W.sub(4), Constant((0)), boundaries, 4)
    #bc8 = DirichletBC(W.sub(5), Constant((0)), boundaries, 4)
    #bc9 = DirichletBC(W.sub(6), Constant((0)), boundaries, 4)
    # bcs = [bc1,bc2,bc3]
    # bcs = [bc1,bc2,bc3, bc4, bc5, bc6, bc7, bc8, bc9]
    bcs = [bc1,bc2,bc3, bc4] #, bc5, bc6, bc7, bc8, bc9]
def cuboid_boundaries(mesh, compression, W):
    tol = DOLFIN_EPS
    bLEFT = CompiledSubDomain("near(x[0], 0.0, tol) && on_boundary", tol = tol)
    bRIGHT = CompiledSubDomain("near(x[0], 200.0, tol) && on_boundary", tol = tol)
    bLEFT.mark(boundaries, 2)       # left
    bRIGHT.mark(boundaries, 4)      # right
    cells.set_all(1)
    bc1 = DirichletBC(W.sub(0).sub(0), Constant((compression)), boundaries, 4)
    bc2 = DirichletBC(W.sub(0).sub(1), Constant((0)), boundaries, 4)
    bc3 = DirichletBC(W.sub(0).sub(2), Constant((0)), boundaries, 4)
    bc4 = DirichletBC(W.sub(0).sub(0), Constant((0)), boundaries, 2)
    bc5 = DirichletBC(W.sub(0).sub(1), Constant((0)), boundaries, 2)
    bc6 = DirichletBC(W.sub(0).sub(2), Constant((0)), boundaries, 2)
    bcs = [bc1,bc2,bc3, bc4, bc5, bc6]
def constitutive_law(mesh, num_variants, R, W, w, dw, wx, compression, penalty, time_step, strain_approx=None):
    #set_log_level(10)
    parameters.parse()
    # print(Compliance_monoclinic)
    # print(Compliance_tetragonal)
    # Phase field definitions
    def mar(c):
        # tot_mar = sum(c)
        # for one variant
        tot_mar = c
        return tot_mar
    def aus(c):
        return 1.0 - mar(c)
    def trans_strain(c):
        # strain = [c[i] * shape_strains_list[i] for i in range(num_variants)]
        #tr_strain = sum(strain)
        # for one variant
        strain = c * shape_strains_list
        #return tr_strain
        return strain
    def mixture_compliance(c):
        return (aus(c) * Compliance_tetragonal) + (mar(c) * Compliance_monoclinic)
    # Displacement field definitions
        return as_vector(
            [e[0, 0],
            e[1, 1],
            e[2, 2],
            e[1, 2] * 2,
            e[0, 2] * 2,
            e[0, 1] * 2]
        return as_tensor(
            [s[5], s[1], s[3]],
            [s[4], s[3], s[2]]]
        if strain_approx is None:
            e = sym(grad(u))
            return e
        elif strain_approx =='lagrangian':
            I = Identity(3)
            Fgrad = I + grad(u)
            C = Fgrad.T * Fgrad
            E = 0.5*(C - I)
            return E
        elif strain_approx =='hencky_order_22':
            I = Identity(3)
            Fgrad = I + grad(u)
            C = Fgrad.T * Fgrad
            a = C*C - I
            b = (C*C) + 4*C + I
            return H
    def epsilon_elastic(u, c):
        #u, c = split(w)
        return epsilon(u) - trans_strain(c)
    def Vstrain(u, c):
        return strain3voigt(epsilon_elastic(u, c))
    def Vsigma(u, c):
        #u, c = split(w)
        return dot(mixture_compliance(c), Vstrain(u, c))
    def sigma(u, c):
        return voigt3stress(Vsigma(u, c))
    def dilatation(c):
        return det(trans_strain(c))
    def gap(u): # Definition of gap function
        return x[2] + u[2]
        return (x+abs(x))/2
    def pN(u, c):
        return dot(dot(nRIGID, sigma(u, c)), nRIGID)
            return int32(a)
    def psi(w):
        u = split(w)[0]
        c = split(w)[1]
        #c = split(w)[1:]
        def elastic(u, c):
            elastic_energy = 0.5 * dilatation(c) * inner(sigma(u, c), epsilon_elastic(u, c))
            # approximate energy without volume dilatation (det F = 1)
            # elastic_energy = 0.5 * inner(sigma(u, c), epsilon_elastic(u, c))
        def interface(c):
            AM_surface_energy = 0.0020     # J/m^2 = Pa.m = Pa'.nm (no change in magnitude in new scaling)
            AM_length_scale   = 50.0     # nm
            MM_surface_energy = 0.00     # J/m^2 = Pa.m (no change in magnitude in new scaling)
            MM_length_scale   = 1.00     # nm
            AM_interface = (4.0/DOLFIN_PI) * (AM_surface_energy/AM_length_scale) * (aus(c)*mar(c))
            #MM_interface = (4.0/DOLFIN_PI) * (MM_surface_energy/MM_length_scale) * diffuse
            energy_cost = AM_interface #+ MM_interface
            return energy_cost
        def chemical(c):
            phi = 5.0e-3  # MPa = 1e-3 * Pa'
            chemical_energy = phi*mar(c)
            return chemical_energy
        def contact_pen(u):
            pen = (0.5 * penalty *inner(maculay(-gap(u)),maculay(-gap(u))))
            return pen
        def phase_pen(c):
            # penp1 = [inner(maculay(c[i] - 1), maculay(c[i] - 1)) for i in range(num_variants)]
            # penp0 = [inner(maculay(-c[i]), maculay(-c[i])) for i in range(num_variants)]
            #penp = sum(penp1) + sum(penp0)
            # for one variant
            penp1 = inner(maculay(c - 1), maculay(c - 1))
            penp0 = inner(maculay(-c), maculay(-c))
            penp = penp1 + penp0
            return 0.5 * (10*penalty) * penp
        # return elastic(u, c), contact_pen(u), phase_pen(c)
        return elastic(u, c) + interface(c) + chemical(c), contact_pen(u), phase_pen(c)
    time_end = 1.0
    t_curr = 0.0
        dx, ds, boundaries, bcs = sphere_boundaries(mesh, meshSIZE, R, d_step, W)
        # Total potential energy (linear elasticity, gradient-interface)
        Pi = psi(w)[0]*dx + psi(w)[1]*ds(6) + psi(w)[2]*dx
        F = derivative(Pi, w, wx)
        wmin, wmax = func_space_bounds(W)
        for bc in bcs:
            bc.apply(wmin.vector())
            bc.apply(wmax.vector())
        # initial guess
        w.vector()[:] = d_step
        problem.set_bounds(wmin, wmax)
                                "snes_solver": {"linear_solver": 'lu', #"lu",
                                                 "preconditioner": "petsc_amg", #"bjacobi",
                                                 "maximum_iterations": 10,
                                                 "absolute_tolerance": 1E-3,
                                                 "relative_tolerance": 1E-3,
                                                 "report": True,
                                                 "error_on_nonconvergence": True,
        #Solve the nonlinear problem
        iter, converged = solver.solve()
        class PhaseProblem(OptimisationProblem):
            def __init__(self):
                OptimisationProblem.__init__(self)
            # Objective function
            def f(self, x):
                w.vector()[:] = x
                return assemble(Pi)
            # Gradient of the objective function
            def F(self, b, x):
                w.vector()[:] = x
                assemble(F, tensor=b)
            # Hessian of the objective function
            def J(self, A, x):
                w.vector()[:] = x
                assemble(J, tensor=A)
        # solver = PETScTAOSolver()
        # tao_solver_parameters = {"method": "bqpip",
        #                         #"line_search": "gpcg",
        #                         #"linear_solver": "lu",
        #                         #"preconditioner": "ilu",
        #                         "gradient_absolute_tol": 1e-3,
        #                         "gradient_relative_tol": 1e-3,
        #                         "maximum_iterations": 150,
        #                         "monitor_convergence": True,
        #                         "report": True
        # solver.parameters.update(tao_solver_parameters)
        # info(solver.parameters, True)
        # iter, converged = solver.solve(PhaseProblem(), w.vector(), wmin.vector(), wmax.vector())
        _u = w.split(deepcopy=True)[0]
        _c = w.split(deepcopy=True)[1]
        print("c_max = ", max(_c.vector()[:]), "c_min = ", min(_c.vector()[:]))
        print("u_max = ", max(_u.vector()[:]), "u_min = ", min(_u.vector()[:]))
        #from vedo.dolfin import plot
        #plot(_u.sub(2))
    return w, _u, _c, mar(_c), boundaries
hex = 0
R = 100  # nm
mesh_size = 5.0
mesh_folder = "./meshes/"
if hex == 1:
    subfolder = 'hexahedral/'
    subfolder = "tetrahedral/"
mesh_folder = mesh_folder + subfolder
mesh_file = "mesh3D_R_" + str(int(R)) + "_size_" + str(int(mesh_size)) + ".xdmf"
# density = 25
# coordinates = (200.0, 100.0, 100.0)
# num_points = (density, density, density)
#mymesh, hMESH, meshSIZE, = cuboid_geometry((coordinates, num_points))
mymesh, hMESH, meshSIZE, = sphere_geometry(mesh_folder, mesh_file)
basis = 'linear'
W, W1, W2, w, dw, wx, num_variants, shape_strains_list = func_spaces(mymesh, basis)
compression = R/100.0
#dx, ds, boundaries, bcs = sphere_boundaries(mymesh, meshSIZE, R, compression, W)
penalty = 100
#E = 200  # GPa = Pa'
time_step = 5e-1
print("hMESH = ", hMESH)
_w, _u, _c, mar, boundaries = constitutive_law(mymesh, num_variants, R, W, w, dw, wx, compression, penalty, time_step)
plot(_u)
file = File("./displacement-pen-phase.pvd")
file << project(_u, W1)
print(mar)
#file = File("./phase-pen-phase.pvd")
#file << project(mar, W2)
#w, boundaries = pureElastic_constitutive_law(mymesh, meshSIZE, hMESH, R, W, w, dw, v, compression, penalty, E, time_step)
#plot(w)
#with XDMFFile("u_PEN_" + ".xdmf") as xdmf:
#        xdmf.write_checkpoint(w, "u", 0.0, XDMFFile.Encoding.HDF5, append=False)
# Savu u as .pvd
# file = File("./displacement-pen.pvd")
# file << w
Skimming through the code, it looks like you’re using a direct solver (LU decomposition) in each Newton step, which is usually insensitive to conditioning of the tangent matrix, except in really extreme cases. More likely is that the time/load steps in the outer loop are too large, so the initial guess of the Newton iteration is not close enough to the solution for it to converge. Some common strategies would be to first try a line search method, e.g., adding the key/value pair
"line_search":"bt"
to the value for key "snes_solver" in the dictionary snes_solver_parameters (which could be written on its own line as
snes_solver_parameters["snes_solver"]["line_search"] = "bt"
if the nesting of dictionaries is unclear from my wording above), then, if that doesn’t work, try shrinking the time/load step size. However, debugging nonlinear convergence can sometimes involve a lot of problem-specific troubleshooting.
Thanks for your response. I am now getting convergence by adaptively setting the time-step. Nonlinearity seems to be the likely cause behind this. I have been asked to implement hexahedral mesh to reduce the necessity of fine refinement and stability.
I generate both hexahedron-element and tetra-element mesh using pygmsh. However, using the hex mesh in the same above code makes dolfin crash.
FYI the MWE code to generate hex elements is below:
mesh_size = 10.0
R = 50.0
import pygmsh, gmsh
from math import sqrt
for hex in range(2):
    geom = pygmsh.occ.Geometry()
    model3D = geom.__enter__()
    if hex == 1:
        algo2D = 8 # Frontal-Delaunay for Quads
        algo3D = 1 # Delaunay
        algoRecom = 0 # 1. Blossom, 3. Blossom full-quad
        algoSubDiv = 2 # All hexa
        gmsh.option.setNumber("Mesh.Algorithm", algo2D)
        gmsh.option.setNumber("Mesh.Algorithm3D", algo3D)
        gmsh.option.setNumber("Mesh.RecombinationAlgorithm", algoRecom)
        gmsh.option.setNumber("Mesh.RecombineAll", 1)
        gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", algoSubDiv)
    #model3D.characteristic_length_min = mesh_size
    model3D.characteristic_length_max = mesh_size
    box =  model3D.add_box(x0=(-R, -R, R), extents=(2*R, 2*R, 1.1*R))
    #box1 =  model3D.add_box([0.5, 0.5, 1], [0.5, 0.5, 1])
    ball = model3D.add_ball([0.0, 0.0, R], R)
    union_minus_ball = model3D.boolean_difference([ball], [box])
    model3D.synchronize()
    model3D.add_physical(union_minus_ball, "union_minus_ball")
    gmesh = model3D.generate_mesh()
    if hex == 1:
        gmesh.write("./meshes/hexahedral/mesh3D_R_" + str(int(R)) + "_size_" + str(int(mesh_size)) + ".vtu")
        gmesh.write("./meshes/tetrahedral/mesh3D_R_" + str(int(R)) + "_size_" + str(int(mesh_size)) + ".vtu")
    points, cells, cell_data_dict = gmesh.points, gmesh.cells, gmesh.cell_data_dict
    print(cells)
    print(cell_data_dict)
    tetra_cells = None
    hexa_cells = None
    for cell in cells:
        print(cell.type)
        if cell.type == 'hexahedron':
            if hexa_cells is None:
                hexa_cells = cell.data
                hexa_cells = np.vstack((hexa_cells, cell.data))
        if cell.type == "tetra":
            # Collect the individual meshes
            if tetra_cells is None:
                tetra_cells = cell.data
                tetra_cells = np.vstack((tetra_cells, cell.data))
    tetra_data = None
    hexa_data = None
    for key in cell_data_dict["union_minus_ball"].keys():
        print(key)
        if key == 'hexahedron':
            hexa_data = cell_data_dict["union_minus_ball"][key]
            hexa_mesh = meshio.Mesh(points=points, cells={"hexahedron": hexa_cells},
                                    cell_data={"name_to_read":[hexa_data]})
        if key == "tetra":
            tetra_data = cell_data_dict["union_minus_ball"][key]
            # Create tetra mesh with cell data attached
            tetra_mesh = meshio.Mesh(points=points, cells={"tetra": tetra_cells},
                                    cell_data={"name_to_read":[tetra_data]})
    if hex == 1:
        meshio.write("./meshes/hexahedral/mesh3D_R_" + str(int(R)) + "_size_" + str(int(mesh_size)) + ".xdmf", hexa_mesh)
        print("Hex meshing DONE, Radius = ", R, " max_edge_length = ", mesh_size, "\n")
        meshio.write("./meshes/tetrahedral/mesh3D_R_" + str(int(R)) + "_size_" + str(int(mesh_size)) + ".xdmf", tetra_mesh)
        print("Tet meshing DONE, Radius = ", R, " max_edge_length = ", mesh_size, "\n")
Where could the issue be? in my meshing or in dolphin’s support?
Appreciate your help! Thanks.
The legacy dolfin code has very limited support for hex meshes. This has been vastly improved in DOLFINx
Thanks @dokken. Will shift to DOLFINx in a short period of time.
The above code generates a correct tetrahedral mesh, however when I open the xdmf file of hex mesh, paraview presents element type error. Not sure what is the issue here.
I have written this code referring the method explained on this link
