I am solving this PDE to get its steady state.
the variational form is lengthy. When I solve the problem with the NonlinearProblem of petsc, it just complains some unhelpful PETSC ERRORs. In this case, how to debug my code ?
Here are my codes,
# -*- coding:utf-8 -*-
epsilon0 = 8.8541878128e-12 #vacuum permittivity, F/m
e0 = 1.60217663e-19 #electron charge
N_A = 6.0221408e+23 #Avogadro constant.
kB = 1.380649e-23 #m^2 kg s^(-2) K^(-1)
pot = -1.200000 #electrode potential
T = 2.980000000000e+02 #temperature
pzc = 0.000000 #potential of zero charge
potential = (pot - pzc)* e0 / kB / T
delta_RP = 3.200000000000e-10 #the thickness of Helmholtz layer
epsilon_RP= 4.170000 #the dielectric constant of Helmholtz layer
epsilon_s = 78.500000 #the dielectric constant of bulk solution
n0 = N_A
D0 = 1.0e-9
lambda_d = np.sqrt(epsilon_s * epsilon0 * kB * T / e0**2 / n0)
Ld = lambda_d * 60 #the position of bulk
factor_a = delta_RP*epsilon_s/epsilon_RP/lambda_d
factor_1 = Ld/lambda_d
factor_2 = Ld*lambda_d/D0
ns_ions = 2
Length_limit = Ld / lambda_d
domain = dolfinx.mesh.create_interval(MPI.COMM_WORLD, 2048, points=(0.0, Length_limit))
V = dolfinx.fem.FunctionSpace(domain, ufl.VectorElement("Lagrange", domain.ufl_cell(), 1, dim=ns_ions+1))
right_boundary = dolfinx.mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(Length_limit, x[0]))
left_boundary = dolfinx.mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(0.0, x[0]))
bc_H = dolfinx.fem.dirichletbc(PETSc.ScalarType(1.000000000000e-04),
dolfinx.fem.locate_dofs_topological(V.sub(0), fdim, right_boundary),
V.sub(0))
bc_OH = dolfinx.fem.dirichletbc(PETSc.ScalarType(1.000000000000e-04),
dolfinx.fem.locate_dofs_topological(V.sub(1), fdim, right_boundary),
V.sub(1))
bc_phi = dolfinx.fem.dirichletbc(PETSc.ScalarType(0.000000000000e+00),
dolfinx.fem.locate_dofs_topological(V.sub(2), fdim, right_boundary),
V.sub(2))
u_n = dolfinx.fem.Function(V) #the solution of previous step.
u = dolfinx.fem.Function(V) #the solution need to solve at the current step.
u_n_H, u_n_OH, u_n_phi = u_n.split()
u_H, u_OH, u_phi = u.split()
v_H, v_OH, v_phi = ufl.TestFunction(V)
#set the initial condition
u_n.sub(0).interpolate(lambda x: 1.000000000000e-04*np.ones(x[0].shape))
u_n.sub(1).interpolate(lambda x: 1.000000000000e-04*np.ones(x[0].shape))
#initial value for the potential
u_n.sub(2).interpolate(lambda x: 7.944060176975e-03*x[0]+(-4.672608459440e+01))
u_n.x.scatter_forward()
#Define the constants for the flux.
flux_OH_at_left = dolfinx.fem.Constant(domain, 1.0e-5)
dt = dolfinx.fem.Constant(domain, 1.0e-10)
flux_H = 9.311000000000e+00*u_H*(1.0)*ufl.grad(u_n_phi)+9.311000000000e+00*ufl.grad(u_H)
flux_OH = 5.273000000000e+00*u_OH*(-1.0)*ufl.grad(u_n_phi)+5.273000000000e+00*ufl.grad(u_OH)
F_H = u_H*v_H*ufl.dx + dt*factor_1*ufl.dot(flux_H,ufl.grad(v_H))*ufl.dx -u_n_H*v_H*ufl.dx
F_OH = u_OH*v_OH*ufl.dx + dt*factor_1*ufl.dot(flux_OH,ufl.grad(v_OH))*ufl.dx -dt*factor_1*flux_OH_at_left*v_OH*ufl.ds -u_n_OH*v_OH*ufl.dx
F_phi = (u_phi - potential)/factor_a*v_phi*ufl.ds - ufl.dot(ufl.grad(u_phi), ufl.grad(v_phi))*ufl.dx + ((1.0)*u_H+(-1.0)*u_OH)*v_phi*ufl.dx
F = F_H + F_OH + F_phi
problem = NonlinearProblem(F, u, bcs=[bc_H, bc_OH, bc_phi])
solver.convergence_criterion = "residual"
solver.rtol = 1e-6
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
n, converged = solver.solve(u)
The error is
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
