I am trying to run demo_poisson.py from demo provided with dolfinx:
msh = mesh.create_rectangle(comm=MPI.COMM_WORLD,
points=((0.0, 0.0), (2.0, 1.0)), n=(32, 16),
cell_type=mesh.CellType.triangle,)
V = fem.FunctionSpace(msh, ("Lagrange", 1))
facets = mesh.locate_entities_boundary(msh, dim=(msh.topology.dim - 1),
marker=lambda x: np.logical_or(np.isclose(x[0], 0.0),
np.isclose(x[0], 2.0)))
dofs = fem.locate_dofs_topological(V=V, entity_dim=1, entities=facets)
bc = fem.dirichletbc(value=ScalarType(0), dofs=dofs, V=V)
u = ufl.TrialFunction(V)
f = 10 * ufl.exp(-((x[0] - 0.5) ** 2 + (x[1] - 0.5) ** 2) / 0.02)
g = ufl.sin(5 * x[0])
L = inner(f, v) * dx + inner(g, v) * ds
problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
but I get such error:
PETSC ERROR: Logging has not been enabled.
You might have forgotten to call PetscInitialize().
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 56.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
it occurs while invoking fem.petsc.LinearProblem(...)
I have build fenics from source and using mac OS M1.
I’m thankful for any suggestions for how to solve the problem
