Hello, I am receiving an error relating to how I am, defining my constant D in my variational formulation. The error says: "AttributeError: ‘Constant’ object has no attribute ‘ufl_function_space’ ". It seems that the constant is not defined in the right function space. However, I am very confused about this because I am in fact defining it on my mesh using D= fem.Constant(domain, 1.0). Please find the code below. Thanks in advance!
import matplotlib
from dolfinx import mesh, fem, io, plot, la
import pyvista
from dolfinx import *
import numpy, sys
from ufl import (VectorElement, FiniteElement,
SpatialCoordinate, TrialFunction, TestFunction,
as_vector, cos, sin, inner, div, grad, dx, pi)
from dolfinx import mesh, fem, io, nls, log
##cretae a rectangular mesh with quadrilateral elements
##note: here theta=x
length, height = 10, 3
Nx, Ny = 80, 60
extent = [[0., 0.], [length, height]]
domain = mesh.create_rectangle(
MPI.COMM_WORLD, extent, [Nx, Ny], mesh.CellType.quadrilateral)
##define the non-linear coeff
omega=(np.pi/2)
##define the non-linear coefficient
def vel(x):
return omega + sin(x)
##setting up the variational problem
from ufl import (TestFunction, SpatialCoordinate, TrialFunction,
as_vector, dx, grad, inner, system, equation, Constant)
V = fem.FunctionSpace(domain, ("Lagrange", 1))
u = TrialFunction(V) ##time-dep c at n+1
un = fem.Function(V) ##time dep C at n
D= fem.Constant(domain, 1.0) ##diffusion coefficient
dt = fem.Constant(domain, 0.05)
##define the variational problem
L= (un*v*ufl.dx) - (v*ufl.dx)
a= u*dx - v*dx - vel(u)*u*v*dt*dx - D*inner(grad(u), grad(v))*dx*dt + D*v*dx*dt
#variational problem stated as a=L
(a, L) = system(ufl.equation(a==L))```
