Hello, i have task:
\frac{ d \rho f}{dt} \, + \, \nabla \cdot (\rho f \; \vec{v}) \, = \, \nabla \cdot (\rho D \nabla f)
My geometry:
Boundary condition:
f|_{inlet_{top}} = \rho_1
f|_{inlet_{bottom}} = \rho_2
\frac{df}{dn}|_{wall} = 0
\rho - scalar function, f - scalar function, D - diffusion constant, \vec{v} - velocity vector
F = FunctionSpace(mesh, 'P', 1)
Rho = FunctionSpace(mesh, 'P', 1)
Mu = FunctionSpace(mesh, 'P', 1)
f = TrialFunction(F)
fi = TestFunction(F)
rho = Function(Rho)
mu = Function(Mu)
f_n = Function(F)
f_ = Function(F)
Variational formulation:
\int \rho \frac{f -f_n}{dt} fi \; dx + \int \nabla \cdot \, (\rho \, f \, \vec{v}) \, fi \, dx \;= \; \int (D \, \rho \nabla f) \cdot \nabla fi \, dx
Is there a mistake here?
Code:
D = Constant(0.05)
F4 = rho*dot((f - f_n) / k, fi)*dx \
+ div(rho * f * u_)*fi*dx \
- dot(D*rho * grad(f), grad(fi))*dx
a4 = lhs(F4)
L4 = rhs(F4)
Rho and mu - constant functions (=1)
Tthe calculation is proceeding normally,
but when i try to output field f_n an error occurs:
plot(f_n)
Error:
ValueError Traceback (most recent call last)
<ipython-input-120-5564c15e22f8> in <module>
----> 1 plot(f_n)
/usr/lib/petsc/lib/python3/dist-packages/dolfin/common/plotting.py in plot(object, *args, **kwargs)
436 # Plot
437 if backend == "matplotlib":
--> 438 return _plot_matplotlib(object, mesh, kwargs)
439 elif backend == "x3dom":
440 return _plot_x3dom(object, kwargs)
/usr/lib/petsc/lib/python3/dist-packages/dolfin/common/plotting.py in _plot_matplotlib(obj, mesh, kwargs)
302
303 if isinstance(obj, cpp.function.Function):
--> 304 return mplot_function(ax, obj, **kwargs)
305 elif isinstance(obj, cpp.function.Expression):
306 return mplot_expression(ax, obj, mesh, **kwargs)
/usr/lib/petsc/lib/python3/dist-packages/dolfin/common/plotting.py in mplot_function(ax, f, **kwargs)
150 if mode == "contourf":
151 levels = kwargs.pop("levels", 40)
--> 152 return ax.tricontourf(mesh2triang(mesh), C, levels, **kwargs)
153 elif mode == "color":
154 shading = kwargs.pop("shading", "gouraud")
/usr/lib/python3/dist-packages/matplotlib/tri/tricontour.py in tricontourf(ax, *args, **kwargs)
273 def tricontourf(ax, *args, **kwargs):
274 kwargs['filled'] = True
--> 275 return TriContourSet(ax, *args, **kwargs)
276
277
/usr/lib/python3/dist-packages/matplotlib/tri/tricontour.py in __init__(self, ax, *args, **kwargs)
33 are described in the docstring of `tricontour`.
34 """
---> 35 ContourSet.__init__(self, ax, *args, **kwargs)
36
37 def _process_args(self, *args, **kwargs):
/usr/lib/python3/dist-packages/matplotlib/contour.py in __init__(self, ax, levels, filled, linewidths, linestyles, alpha, origin, extent, cmap, colors, norm, vmin, vmax, extend, antialiased, *args, **kwargs)
853 self._transform = kwargs.pop('transform', None)
854
--> 855 kwargs = self._process_args(*args, **kwargs)
856 self._process_levels()
857
/usr/lib/python3/dist-packages/matplotlib/tri/tricontour.py in _process_args(self, *args, **kwargs)
45 else:
46 from matplotlib import _tri
---> 47 tri, z = self._contour_args(args, kwargs)
48 C = _tri.TriContourGenerator(tri.get_cpp_triangulation(), z)
49 self._mins = [tri.x.min(), tri.y.min()]
/usr/lib/python3/dist-packages/matplotlib/tri/tricontour.py in _contour_args(self, args, kwargs)
92 'triangulation')
93 if not np.isfinite(z_check).all():
---> 94 raise ValueError('z array must not contain non-finite values '
95 'within the triangulation')
96
ValueError: z array must not contain non-finite values within the triangulation
I don’t understand what(
If i ask for a task.
Rho and mu:
\mu = \mu_1 \, f + (1-f)\, \mu_2
\rho = \frac{\rho_1 \rho_2}{f\rho_2 + (1-f)\rho_1}
Code:
rho_1 = Constant(1)
rho_2 = Constant(2)
mu_1 = Constant(1)
mu_2 = Constant(2)
mu = project(mu_1 * f_n + (1 - f_n)*mu_2, Mu)
rho = project(rho_1*rho_2/(f_n*rho_2 + (1 - f_n)*rho_1), Rho)
My solution is nan from 1 iteration.
I can post the solution full.
