How to define SubDomain in dolfin-x?
I am trying to use SubDomain in dolfin-x. Below, a simple code is presented in dolfin which I can not represent it in dolfin-x.
The proposed simple code in dolfin is:
mesh = RectangleMesh(Point(0, 0), Point(1, 1), 10, 10)
V = FunctionSpace(mesh, “Lagrange”, 1)
s=dot(grad(u),grad(v))*dx
S = PETScMatrix()
assemble(s, tensor=S)
class MW(SubDomain):
return on_boundary
ew=DirichletBC(V,(“0”),MW())
ew.apply(S)
esolver = SLEPcEigenSolver(S)
esolver.solve()
and I have a problem how to define this part in dolfin-x:
return on_boundary
ew.apply(S)
and this is the proposed dolfin-x code:
from dolfinx.plotting import plot
from dolfinx import Function, FunctionSpace, UnitSquareMesh, RectangleMesh
from dolfinx.fem import assemble_matrix, Form
from ufl import TrialFunction, TestFunction, grad, dx, dot
from slepc4py import SLEPc
from dolfinx.cpp.mesh import CellType
MPI.COMM_WORLD,
[np.array([0, 0, 0]), np.array([1, 1, 0])], [10, 10],
cell_type=CellType.triangle)
V = FunctionSpace(mesh, (“CG”, 1))
a = dot(grad(u), grad(v))*dx
A = assemble_matrix(a, )
eigensolver = SLEPc.EPS().create(MPI.COMM_WORLD)
eigensolver.setDimensions(6)
eigensolver.setWhichEigenpairs(2)
eigensolver.setOperators(A)
eigensolver.solve()
vr, vi = A.createVecs()
Thanks in advance for your help.
Consider the Poisson demo where the lambda function is replaced with
def boundary(x):
            return np.full(x.shape[1], True)
Similar to this test
Thanks for your reply dokken.
It was really helpful. but there is still an ambiguity how to write this part of code in dolfin-x after defining the boundary condition?
ew.apply(S)
Thank you
Thanks a lot dokken Now, it runs properly.
and thanks for your suggestion. I am new to dolfin-x and I am trying to solve some of my previous dolfin problems by using dolfin-x. I would keep your suggestion in my mind.
Thank you again.
