Projecting subdomain solutions onto the full domain
Dear all,
I am wondering how to project solutions of 2 subdomains (which divide the full domain into two equal parts) onto the full domain, while preserving the the correct mapping of DoFs from these subdomains onto the full domain. Here is a MWE of what I am trying to say and do:
import math
# Creating mesh
mesh_trial = RectangleMesh(Point(-1.0, -1.0), Point(1.0, 1.0), 8, 8,"left")
# Marking different regions in the domain
class Top_1(SubDomain):
        return x[1] > 1.0 - DOLFIN_EPS and x[0] < 0.0 + DOLFIN_EPS
class Top_2(SubDomain):
        return x[1] > 1.0 - DOLFIN_EPS and x[0] > 0.0 - DOLFIN_EPS
class Bottom_1(SubDomain):
        return x[1] < -1.0 + DOLFIN_EPS and x[0] < 0.0 + DOLFIN_EPS
class Bottom_2(SubDomain):
        return x[1] < -1.0 + DOLFIN_EPS and x[0] > 0.0 - DOLFIN_EPS
class Left(SubDomain):
        return x[0] < -1.0 + DOLFIN_EPS
class Right(SubDomain):
        return x[0] > 1.0 - DOLFIN_EPS
class Interface(SubDomain):
        return near(x[0], 0.0)
# Marking subdomains and interface between them
domain = MeshFunction("size_t", mesh_trial, mesh_trial.geometry().dim(), 0)
for c in cells(mesh_trial):
    domain[c] = c.midpoint().x() > 0.0
facets = MeshFunction("size_t", mesh_trial, mesh_trial.geometry().dim()-1, 0)
Interface().mark(facets,1)
# Creat submeshes of subdomains and interface from the full domain
mesh_L = MeshView.create(domain, 0)
mesh_R = MeshView.create(domain, 1)
mesh_I = MeshView.create(facets, 1)
# Marking boundaries of subdomains
mf_1 = MeshFunction("size_t", mesh_L, 1)
mf_1.set_all(0)
Top_1().mark(mf_1, 1)
Bottom_1().mark(mf_1, 2)
Left().mark(mf_1, 3)
Interface().mark(mf_1, 4)
mf_2 = MeshFunction("size_t", mesh_R, 1)
mf_2.set_all(0)
Top_2().mark(mf_2, 5)
Bottom_2().mark(mf_2, 6)
Right().mark(mf_2, 7)
# Defining function spaces and intergration measure for different subdomains
# Function space
V1 = FunctionSpace(mesh_L, "CG", 1)
V2 = FunctionSpace(mesh_R, "CG", 1)
Lmp = FunctionSpace(mesh_I,"R",0)
V = MixedFunctionSpace(V1,V2,Lmp)
u1,u2,u_lmp = TrialFunctions(V)
v1,v2,v_lmp = TestFunctions(V)
# Integration measure
dx1 = Measure("dx",domain=V.sub_space(0).mesh())
ds1 = Measure("ds",domain=V.sub_space(0).mesh(),subdomain_data=mf_1)
dx2 = Measure("dx",domain=V.sub_space(1).mesh())
ds2 = Measure("ds",domain=V.sub_space(1).mesh(),subdomain_data=mf_2)
ds_lmp   = Measure("dx", domain=V.sub_space(2).mesh())
kappa1 = Constant(1.0)
kappa2 = Constant(10.0)
miu = Constant(10.0)
g = miu
a = kappa1*inner(grad(u1), grad(v1))*dx1 + kappa2*inner(grad(u2), grad(v2))*dx2
a+= inner(u_lmp, (v1-v2))*ds_lmp +inner(v_lmp,(u1-u2))*ds_lmp
L = g*v1*ds1(3)
# BCs
bc_dirich = DirichletBC(V.sub_space(1), Constant((0)), mf_2, 7)
# Compute solution
solve(a == L, u, bc_dirich)
# Splitting solution
u1,u2,u_lmp = u.split(deepcopy=True)
# Plotting solutions of subdomains
plt.colorbar(plot(u1))
plt.colorbar(plot(u2))
Running this example gives me solutions of two subdomains, which look good and has the the continuity at the interface (which is of course achieved using Lagrange multiplier).
I cannot however figure out how to project these two subdomain-solutions onto the full domain such that I get one full solution in the full domain.
Could someone please help me with that?
